      07-02-2012, 11:55 AM   #1
atv12
atv12's Avatar
Russian Federation
14
Drives: ///1M Coupe
Question Air ducts
Hi!
I'm going to set up air ducts on my m and searching for cooling plates.. i've found these ones http://store.bimmerworld.com/carbon-...tes-p1412.aspx and these as a kit http://1m-raze.revozport.com/1mbrake_duct_kit.html
but they are made of carbon and too expensive.. does any one have an idea where to buy cheaper analogs?
I would be much appreciated for any advices..
      07-09-2012, 09:24 AM   #2
atv12
atv12's Avatar
Russian Federation
14
Drives: ///1M Coupe
Here are some pics of modified stock brake plates.
air intake is built under the oil radiators and air flow comes up to the center of the brake rotors and dissipates easily and also cools down the wheel hubs...
      07-09-2012, 10:58 AM   #3
shah269
Drives: 2009
cool!
this should be in the DIY right?
      07-10-2012, 07:38 AM   #4
atv12
atv12's Avatar
Russian Federation
14
Drives: ///1M Coupe
what does DIY stand for? do it yourself?))
if yes, then it is hard to do by yourself without special knowledge, tools and skills..
but in general yes, that's custom made brake air cooling ducts..
      07-10-2012, 12:18 PM   #5
VO 1M
VO 1M's Avatar
Drives: 1M Coupe
hmmm, I am not sure if I would make a hole in the airducts to the oil / secondary water cooler. If I paid attention well during physics lessons air goes the way of less resistance. In this case this means it will go through the open hole in direction of the brakes instead of being pressed through the cooler... meaning you will loos cooling capacity. Curious if after your experience on the track
      07-10-2012, 12:51 PM   #6
BrianB496
Drives: 1 ///M
2011 BMW 1M  [0.00]
Those revosport ones were designed for show not go. You want to direct the cooling air into the center of the vented disc for effective cooling. All the revosport ones do is direct cooling air at the inside surface of the rotor. Useless for actual track use.
      07-11-2012, 03:37 AM   #7
atv12
atv12's Avatar
Russian Federation
14
Drives: ///1M Coupe
i'm going to have a track day in a week.. i'll write about the oil temperature..
      07-11-2012, 03:43 AM   #8
atv12
atv12's Avatar
Russian Federation
14
Drives: ///1M Coupe
exactly! and those mine direct airflow straight to the center of the rotor.. to aluminum hub..
      07-23-2012, 06:43 AM   #9
mpiligrim
M-addict
mpiligrim's Avatar
Russian Federation
Drives: M3 e92 Laguna seca, M5 f90 Com
From what I've seen on the track, you had a certain problem with overheating, what was that exactly? Brakes or engine temperature?..
What's your impression on those ducts? Did you use stock fluid?..
In wroom I trust.
BMW M3 e92 Laguna Seca Blue '13
BMW M3 e91 Tourmaline Violet '10
BMW M5 F90 Comp Peridot Green '19
BMW 1M Valencia Orange '11 (sold)
      07-23-2012, 07:33 AM   #10
atv12
atv12's Avatar
Russian Federation
14
Drives: ///1M Coupe
Marat, neither that nor the other... it was overboost... my engine switched to safe mode, then i shut it down and started again and went normally then! oil temparature was 130-140 as usual..
finally with the brakes (thanks God) i had no problem! I put hawk ht-10 pads on the front, and hawk hp+ on the rear, goodridge braided hoses and motul 5.1 fluid...
fantastic stop and clear initial brake... and not a single hint of brake overheating..
i guess it is a myth that our brakes have a temperature sensor and overheating protection...
      07-23-2012, 10:35 AM   #11
MDORPHN
Drives: AW 1M
Quite right.
OP -- if you do a search, you'll find my thread about the Bimmerworld backing plates and how I revised my front bumper to run ducts.
Neil
      07-23-2012, 10:46 AM   #12
atv12
atv12's Avatar
Russian Federation
14
Drives: ///1M Coupe
I've already read it.. Thnx for your post, but those pics are of mine. Everything is done in my car..
      07-30-2012, 07:00 AM   #13
mpiligrim
M-addict
mpiligrim's Avatar
Russian Federation
Well it's good that there are no issues with brakes. But overboost doesn't sound nice to me. Hope that was a single matter.
In wroom I trust.
1addicts
