06-26-2012, 11:38 AM | #1 |
Opus Angelus
426
Rep 1,267
Something odd
Went out to my car after work yesterday afternoon. I keep it covered in the parking lot to hold down the extreme heat. As I walk up, I use the fob to unlock and roll down the windows to start getting the hot air out, then pack up the cover.
After that was done I used my fob to open the trunk. Nothing happens. I do see that the car is unlocked and the windows are partially rolled down. I open the car to hit the trunk button inside, nothing happens. Starting to get worried now. Fortunately, my car still has a manual key unlock for the trunk, so I use that (for the very first time), load the cover and apprehensively put the fob in the slot. Everything starts fine, the engines fires immediately, no codes or warnings, and I'm on my way. Everything normal since then. Only thing I can think is somehow the electronics got locked after I unlocked the car, maybe because of the heat. Anybody else ever have something similar happen? |
06-26-2012, 04:46 PM | #2 | |
Rep 7,047
I'm guessing it's working now? Now, about this car cover thing, are you using an actual FULL car cover to protect from the heat? Man, in that AZ summer sun and heat it I would think you're creating an even hotter interior for that car than may be good for it. I KNOW it get's extremely hot in cars out there. I've been to Phoenix and Tucson during the 4th of July, and in the Saguaro forest of Tucson it was 115F in the shade. Getting into a hot car feels like you've touched the sun's surface if you grab that steering wheel in an uncovered car. YEEEEOUUCH! I'm thinking a traditional full car cover is not helping with air circulation, and the heat buildup in the car has to be way hot. Have you taken a temp reading of your interior right before you open the windows and remove the cover fully? |
06-26-2012, 05:54 PM | #3 | |
Opus Angelus
426
Rep 1,267
06-27-2012, 10:32 AM | #4 |
Loves his G20
265
Rep 2,507
Wow I've thought about purchasing a cover for this as well, here in TX we're currently seeing temperature of 106 this week. I park in the shade and use the BMW windshield shade and it makes a huge difference but I wonder if a car cover would be better??
2020 330ix-Msport Past- 2013 135i 2011 135i Last edited by doublevanosrc; 06-27-2012 at 10:41 AM.. |
06-27-2012, 03:54 PM | #5 |
Opus Angelus
426
Rep 1,267
Shade is always going to be better than a cover. Unless it's under a tree with birds.
06-27-2012, 09:09 PM | #6 | |
Rep 7,047
I'm just curious if that full cover is trapping too much heat underneath where the car sits. I've seen those sun reflective sun blockers that you can put against the windshield and even against the rear window, and they work very well as they reflect the suns energy away. Granted, they don't help against the suns rays on the paint. Do those not work as well or better than a full cover? |
