ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Track / Autocross / Dragstrip / Driving Techniques
  TireRack
      06-17-2012, 10:13 PM   #1
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
BW vs Turner Shim Kits + Questions
I realize metal is metal, but has anyone had better experience with either or?
I'm just concerned with the tolerances the metal washers would provide versus the actual thickness for the BW shim kits.
I'm looking to go around -2.0" in the front after it's said and done. I understand I'm going to have to get a front wheel alignment in order to correct the toe, yes?
How much would the toe be affected if I didn't get an alignment?
Many Thanks,
      06-17-2012, 10:27 PM   #2
dorifto88
Drives: 88 Nissan Pathfinder
offtopic, but i have the bimmerworld shim kit, and i didnt use the "medium" and "small" sized spacers, if you want them.
      06-17-2012, 11:11 PM   #3
seank
enthusiast
seank's Avatar
48
Drives: e30 m3,e90 wagon,sprinter,z4m
I installed the turner kit and used all of them and gained 1.2 degrees camber. Increasing camber increases toe slightly. I have not measured it to what degree, since it depends on the cars geometry. Its only a front wheel alignment. It should be cheap. If you don't want to pay to measure toe, buy your own kit at home depot and measure it yourself. Most of the racers still use a string and pole.
      06-18-2012, 06:52 AM   #4
Kgolf31
Kgolf31's Avatar
460
Yea im not concerned about the price, but i may be driving around 150 miles before i can get an alignment.
Looks like i cant go wrong with either
      06-18-2012, 07:10 AM   #5
Trev
Drives: Z4MC
If you go the hardware store washer route. Better buy a box and patiently measure thickness of each. Match all washers to the same thickness.
Also as many These washers are punched out they have slight curvature. Flatten them out in a vice.
If all that sounds like to much work buy the pre-made kit.
      06-18-2012, 07:37 AM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^if you are going off the shelf hardware get them case hardened.
Yes, you want them as close to the same size as possible but its not a huge deal because you can still fine tune at the tower slots.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      06-18-2012, 02:12 PM   #7
Kgolf31
Kgolf31's Avatar
460
I just ordered turner camber bolts for making life easy.
Next question. How do I remove the alignment pin? Any easy way?
      06-18-2012, 02:32 PM   #8
Finnegan
Dog Listener
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Use a hex key IIRC (removed so long ago not sure). Or use a vice grip since they can just go in the trash once they're out. They're only there so the robot doing the alignment at the factory has a reference point.
      06-18-2012, 07:14 PM   #9
seank
enthusiast
seank's Avatar
48
If your car is toed in (like most in the front), it may drive better afterwards. You will be fine for 150 miles.
zpost
