      05-21-2012, 06:36 PM   #1
mclemens
mclemens's Avatar
Drives: 2011 BMW 1M
Alignment specs - KW V3 + GC Camber plates
I'm looking for an alignment starting point for a setup with KW V3 coil-overs and Ground Control camber plates. Anyone have the same or similar setup and want to share your specs?
How much negative camber were you able to get at the rear of the car?
What are you toe settings for the front and rear?
Thanks
2011 1M AW, 2011 A3 TDI, 2013 Mini JCW, 2014 F150, 2016 Focus RS on order
      05-21-2012, 06:51 PM   #2
MDORPHN
Drives: AW 1M
Mike -
I'm running 3.2 degrees front with 0 toe.
Rear -- 2.2 degrees with approx. 3/16" total toe-in.
Neil
      06-02-2012, 09:50 PM   #3
bklounge
bklounge's Avatar
Drives: VO 1M
Originally Posted by MDORPHN View Post
Mike -
Neil
Was your rear camber maxed out? Are you lowered?
      06-03-2012, 06:51 AM   #4
mclemens
mclemens's Avatar
Drives: 2011 BMW 1M
My suspension changes got delayed by a broken windshield. The coil-over, camber plates and front sway bar are going on tomorrow. When things are complete I'll post the results.
      06-03-2012, 07:19 AM   #5
eeghie
Kind of a big deal
300
Drives: an 1M not often enough
Thanks
As a more general starting point, what is the stock camber & caster?
1addicts
