      05-16-2012, 05:55 AM   #1
VO 1M
VO 1M's Avatar
Drives: 1M Coupe
fitment VOLK RE30 club sport
I have a quote for VOLK RE30 Club Sport in 9.5x18 ET22 / 10.5x18 ET18
will these fit with Michelin Pilot CUP or Pirelli Trofeo 265x35 / 295x30 ?
The ET18 wories be a bit
thanks
      05-16-2012, 04:28 PM   #2
Julius@Style77
Julius@Style77's Avatar
Drives: Mini Cooper S
It will be a better fit with 265/35 and 285/35 tires.
Also, the rear 18 - 10.5 et18 may rub and something that will work with lowering and by introducing some negative camber. With so small of a margin, the slightest variables like even tire brand can introduce contact.
      05-16-2012, 06:27 PM   #3
VO 1M
VO 1M's Avatar
Drives: 1M Coupe
the normal RE30 have an offset of 25 front and back. that is probably a better choice.
Suspension is KW clubsport with about -2.8 degrees of camber in front
      05-18-2012, 12:06 PM   #4
OAM
OAM's Avatar
Drives: Sitting
I have those wheels, these are the specs I run on my car. Stock tires and suspension.
front : 19 x 9 +25 offset
rear : 19 x 10 +15 offset
      05-18-2012, 03:27 PM   #5
bklounge
bklounge's Avatar
Drives: VO 1M
Looks good man. Those offsets are spot on.
      05-24-2012, 01:21 PM   #6
VO 1M
VO 1M's Avatar
Drives: 1M Coupe
but consider a half inch wider wheel and 3cm wider tires in the back. Tat will come out 1.5cm to the outside, not sure looking at the pictures if there is room for that.
      10-18-2012, 09:05 PM   #7
nachob
Drives: 2004 330i ZHP, 2022 Cayman T
VO, did you end up getting the RE30s? I have an AW IM and thinking of these. Can you PM me your quote and let me know how it worked out and maybe pics? Thanks
      11-09-2012, 12:00 AM   #8
datbimmerdoe
datbimmerdoe's Avatar
siiick
#datbimmerdoe #thatbimmertho
FOLLOW @datbimmerdoe on INSTAGRAM
1addicts
