04-07-2012, 05:18 AM | #1 |
Rep 693
Cleaning Intake Manifold
Hi,
Awaiting arrival of a new OCC; I'm looking at how I can get rid of the carbon build up on the intake. I've done some reading, people are suggesting things from seafoam, carb cleaner all the way to walnut blasting. ... I am thinking of giving this a go... can anyone see a reason against this? http://www.aircooledtech.com/tools-o.../soda_blaster/ |
04-07-2012, 05:42 AM | #2 |
Rep 122
Need to let it soak a while to get out the excess soda, and maybe change water out a few times...
Although it depends on location and mileage, I wouldn't think there isn't anywhere near as much carbon build up on a MY10 intake as the ones in those before / after shots |
04-07-2012, 07:25 AM | #4 | |
European Editor
10596
Rep 22,992
YuP! I was just gonna suggest this product. I think Seafoam would work well... but I can't find it over here. I just bought a can of this Liqui Moly Klappen Reiniger (LM throttle body/intake manifold cleaner) to use in my (new to me) '99 e39. |
04-07-2012, 08:22 AM | #5 | |
Rep 2,438
I believe this one is diesel? |
04-07-2012, 01:16 PM | #6 | |
European Editor
10596
Rep 22,992
Noop! 535iA, 3.5L V8 automatic with sport seats and lots of extras. Lots of kms though. BMW AG used to own the car by chance - so it is very unusual - in that it has cloth red sport seats and some nice options. But I have almost gone thru the entire car making it all new. Funny thing is... even though its a V8 with 245 PS it gets BETTER gas mileage than my 135i! lol I can get 11L/100kph with it vs 12 to 14L in my 135i. lol I enjoy both cars though. |
04-07-2012, 07:47 PM | #7 | |
Rep 1,792
Pics??? |
04-08-2012, 04:09 AM | #8 |
European Editor
10596
Rep 22,992
Here you go... (sorry to thread-jack!)This was before I got the car and cleaned her up... |
04-08-2012, 09:22 PM | #11 | |
Rep 1,792
Congrats! |
04-09-2012, 09:03 AM | #12 |
European Editor
10596
Rep 22,992
^^Thanks guys.
Getting back on topic... I ran a bottle of this Liqui Moly Klappen Reiniger thru my old 5er this weekend. Really makes a difference in smoothness at idle. I sprayed down the throttle body and then flipped it open and used the 1m long tube to spray down inside the intake manifold. Then I put the MAF boot back on and started the engine. I then used a vacuum port just before the throttle body and rev'd the engine and sprayed the rest of the can into teh engine. Reving to 5K and back down to 3K and back up... the engine would pop and bang some... but its all good. Some smoke will also come out the exhuast. I then changed the engine oil and took her out on a test drive. I am happy with the results. You can't beat this stuff for ten euros a can. I also use LM fuel injector cleaner and valve deposit cleaner as well. I bought a LM spray can that cleans the MAF hot wire sensor. Some say it makes the engine feel more powerfull and use less fuel - after you clean the MAF sensor. I'm gonna use that in a day or two on my ne-used ride. Dack |
04-09-2012, 09:58 AM | #13 |
Rep 2,938
Cool car Dack. I've driven my fair share of e39s and just love the way they overheat! Hehe... hope yours never develops the same issue
On topic: This thread is pretty interesting - http://www.e90post.com/forums/showthread.php?t=673527 |
04-10-2012, 03:12 AM | #14 |
Rep 5,530
I believe the manifold itself is the plastic part which doesn't get any carbon buildup on it, more so the cylinder head where the injectors are is where the carbon is??
Do you need to remove the whole cylinder head to perform this procedure? If you walnut blast the carbon off the cylinder walls won't the bits of crap just get consumed by the engine? |
04-10-2012, 05:39 AM | #15 | |
Rep 1,883
Buildup isn't on the cylinder walls. It's on the; inlet track, valve heads, valve stems etc. Yeah, when you blast/clean it up you don't want the engine "consuming" it. You want to clean it up with the valves closed and vacuum it out before the valves are opened and the gunk falls in. Taking the head off may be the best solution but a PITA to do. |
04-10-2012, 05:56 AM | #16 | |
162
Rep 1,460
Best to take it to your Mechanic and just pay the money wont be cheap but you could save a heap in the long run |
04-10-2012, 07:53 PM | #17 | |
Rep 286
Modded 135i RHD Bumblebee |
04-10-2012, 08:05 PM | #18 | |
Rep 9,156
04-10-2012, 08:12 PM | #19 | |
Rep 2,934
if you ever did do it i'd wager you'd never do it again and laugh at why the fark you thought it was a good idea in the first place. |
04-10-2012, 08:39 PM | #20 |
Rep 645
i usually just run a can of carb cleaner through once in a while. Pull one of the vacuum line off the bov and get someone/ something to keep the car at around 2k rpm and spray into the vacuum line in pulses. Will probably do nothing to the hardened build up but at least it seems to do enough to smooth out the idle and give slightly better throttle response after.
04-10-2012, 08:43 PM | #21 | |
Rep 9,156
In the case of DP's, I took that to a workshop to have that installed. IMHO, it should be left to the professionals unless you have access to a hoist, at the very least. This job looks like it's very tedious and it's hard to access everything. Also, making a mistake could be very costly, so lots of research needs to be done. |
04-10-2012, 08:46 PM | #22 | |
Rep 9,156
