06-12-2007, 11:25 AM | #1 |
Booyakasha!
40
Rep 413
Drives: '13 Mini Cooper S Coupe'
Dim M angel eyes
Ive noticed that my angel eyes are really dim compared to the 3 and 5 series. I have mine set as DRLs and they are really difficult to see. Anyone else notice this? I just want them to be brighter as DRLs. Is there a way to modify the light intensity???
--Chad
'08 M Coupe--AW/IR--SOLD!--My M Coupe Obsession
'13 Mini Cooper S Coupe - My Maui Mobile '13 Mini Cooper S Paceman- My Maui 'Stuff Hauler' |
06-12-2007, 12:17 PM | #2 |
My favorite sign.
169
Rep 4,333
probably have to get some new xenons.
06-12-2007, 12:22 PM | #3 | |
Rep 11,667
The E92 335 has a great set up, you just have to swap out the bulbs & they're mega bright. I haven't heard of anyone doing anything with ours yet......
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
06-12-2007, 01:36 PM | #4 |
Rep 1,068
I told you: lasers. Trade up the xenons for laser beams. Then you don't actually have to see everything in front of you because it will just be vaporized.
06-12-2007, 02:22 PM | #5 | |
Rep 506
I think I also will look into increasing visibility with some brighter ones. |
06-12-2007, 03:43 PM | #7 |
My favorite sign.
169
Rep 4,333
New lamps...
06-12-2007, 05:03 PM | #9 |
My favorite sign.
169
Rep 4,333
06-12-2007, 07:33 PM | #11 |
Rep 412
Well, after a little digging. Finding data on the Z4's is downright difficult unless you open up the assemblies yourself. From what I have been able to scrounge up, the M's use a bi-xenon system for the headlights and what appears in the drawings to be an H7 12v 55w bulb for the "corona ring". The H7 bulb appears to be common across all Z4 platforms, so I would think that just upgrading to a brighter H7 should do the trick.
Source of additional data here: http://www.realoem.com/bmw/ Now, for the disclaimer: I did not personally pull the panel under the wheel well and check the bulbs located in the headlight assembly, mine are fine and I don't feel like crawling around in there. If you are wanting to go to a brighter bulb, double check what YOU have in the lamp assembly before blindly following advice on these forums. In regards to a previous statement; I try to provide the best information that I can instead of just sending people on a wild goose chase with the . If I can find it, I will post a link or do what I just did here, explain what I found and let the individual make their own decisions. YMMV. Cheers! Last edited by ovrkll; 06-12-2007 at 07:54 PM.. Reason: Added extra source of data for headlight assembly. |
06-12-2007, 07:48 PM | #12 |
My favorite sign.
169
Rep 4,333
www.google.com
Works for me as well as the next guy. And I've actually put in a good day of work today
06-12-2007, 07:49 PM | #13 |
Rep 11,667
Great work ovrkll
06-12-2007, 07:53 PM | #15 |
My favorite sign.
169
Rep 4,333
Shouldn't your local dealer be able to give you specs on the lamps...and upgradability...
06-12-2007, 07:55 PM | #16 |
Rep 11,667
Yeah right.... ask a dealer
06-12-2007, 08:04 PM | #17 | ||
Rep 412
A little jovial banter is okay when people are asking for advice on how to fix a problem, but I think this is a little excessive. From what I have found out, it seems like a very valid question for those that do their own repairs. Not all people have easy access to a dealer or time to waste. End of rant. Flamesuit on. |
06-12-2007, 08:39 PM | #18 |
Rep 332
Screw the brighter bulbs - I NEED the lasers for the idiots who dare to hang out in front of me actually doing the speed limit!
2010 328ix Sports Wagon
06-12-2007, 08:50 PM | #19 |
Rep 403
A wise man with a wise plan!
back by popular demand... |
06-12-2007, 09:28 PM | #21 |
Rep 1,210
There is very little documentation on the Angel Eyes that come on the Z4s. Not even a mention in the manual and RealOem.com has nothing on it as well. The H7 bulb mentioned above is actually the high beam // flash2pass (on cars with bixenons) not the Angel Eye bulb. I've replaced my low beam HID D2S bulbs as well as the H11 Fog Light bulbs and saw firsthand the H7 pair of inner bulbs.
Previously BMW used an H8 bulb which sat in a housing that reflected the light into optical wiring, the optical wiring lit the ring. However, I have been unable to find any documentation stating that the Z4 also uses this technology. As of right now I dont think there is a solution to the dim angel eyes. Also at least on my car the angel eyes are ONLY on the two inner rings (flash2pass) |
06-13-2007, 12:28 AM | #22 |
Skull Squadron Leader
306
Rep 2,031
I wish my Zed had all 4 coronas lit (like they do on the 3 series). But I guess 2 is better than none!
