02-02-2012, 10:29 PM | #1 |
Rep 3,201
What I'm testing...
Not configured completely yet... hoping to get it working tomorrow...
Mobridge DA2 MOST to analog/MOST to Toslink gateway: - MOST input - 8 RCA outputs (2 pair fading, 2 pair non-fading) - Toslink S/PDIF digital output - internal DSP EQ controlled by 7-band EQ UI in BMW head unit - 24-bit Burr-Brown DACs - 4V RMS analog outputs - USB programming (no more SD card!) |
02-03-2012, 11:17 AM | #2 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Now if I just knew what this does.
02-03-2012, 11:48 AM | #3 |
Rep 446
You can configure this thing to allow the EQ in the BMW UI to adjust the EQ in this unit??? I suppose that would make sense if the signal processing is done in the factory unit as well, but that is awesome!
Can you assign different frequencies and Q's to the eq bands? I would assume you woulnd't be able to change what it says on the screen though... This thing looks seriously promising for a badass system. |
02-03-2012, 07:20 PM | #4 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
Maybe now I can find some used mobridges for sale
02-03-2012, 10:11 PM | #5 | |
Rep 3,201
This weekend I will test exactly what that means, with the RTA. It isn't customizable at all... But it's better than bass and treble controls. The head unit recoded today, not sure how it happened or what I did "right". But I have EQ on the iDrive now and my analog outputs are dead, and I have output from the DA2 now. I currently have the Toslink out feeding a Helix DSP, feeding an Arc amp. No noise, no hiss, clear as day. |
02-04-2012, 06:41 AM | #6 | |
Rep 13,001
02-04-2012, 10:09 AM | #7 |
Rep 3,201
02-04-2012, 10:37 AM | #8 |
Rep 2,339
In this configuration, is it basically acting as a MOST to toslink converter? Since you have a DSP downstream, would you be EQing the signal 2x? Would the OEM volume control still work when using the toslink output?
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
02-04-2012, 12:20 PM | #9 | |||
Rep 3,201
Now as far as why, I'm not sure. The original Sony/Philips specification for S/PDIF doesn't define volume control specifically. There are some "words" reserved for some possible volume state data, and perhaps those have been defined in a later version of the specification which I haven't read. It's also possible that they are doing some transform where they are changing the amplitude of the signal in the digital domain based on some algorithm they have created, which looks at the volume knob state of the HU. If they do that, they are essentially compressing the dynamic range of the digital signal, but that's not a horrible thing, since in a car - especially a moving car - the dynamic range of a CD is useless, and Ken Pohlmann - an early advocate of digital audio - long advocated a "compression" button for CD players for cars for this reason. But it seems great so far. |
02-14-2012, 06:28 PM | #10 |
Rep 3,969
OK, so the weekend is over...
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
02-14-2012, 10:34 PM | #11 |
Rep 3,201
I have not yet received a firmware version which would allow the device's RCA outs to be used with any degree of fidelity. I do not knows for certain if the issue is firmware or hardware. Wish I had different news, but I will keep you posted. I would like to use these in that manner too...
02-15-2012, 05:21 AM | #12 | |
Rep 13,001
02-15-2012, 08:13 AM | #13 |
Rep 665
I shouldn't have clicked on this thread...my head hurts now.
Current - 2018 Tesla Model 3 SOLD - 2008 135i CR, 2010 135i LMB, 2012 M3 MR, 2008 M3 JZB |
