      01-13-2012, 02:40 PM   #1
Detailer
Drives: BMW F80 M3
Carbon fiber wrapped interior trims (3M di-noc vinyl)
Wrapped my wood trims today using 3M di-noc vinyl
I think it turned out good. I hated the wood so much!
Afam28298.00
      01-13-2012, 02:43 PM   #2
gkmunch
Drives: 2016 340i
That looks fantastic!
      01-14-2012, 06:46 AM   #3
Swederinger
Sweden
Drives: BMW 130i E81
Wow! Great job! How long did it take?
      01-14-2012, 07:00 AM   #4
chachacha28
NCOIC of Kickin It
chachacha28's Avatar
Germany
78
Drives: 08 135i "Simona"
looks great!
      01-14-2012, 07:32 AM   #5
Detailer
Drives: BMW F80 M3
Thanks for the good comments!
Removing the trims with proper tools: 5 minutes or less
Removing the center console: 20 minutes (followed this thread: http://www.1addicts.com/forums/showthread.php?t=213833 ) I had to improvise a bit as this DIY is for cars without ashtray, so I had to struggle with connectors. I also discovered 2 connectors behind the cover that's facing the rear seats, that were connected to nothing?!!
Cleaning the trims with alcohol and applying the vinyl took maybe 2-3 hours. It was my first time with vinyl so it took me quite a while to figure it out. The door handles were the most tricky part because of the curvature. The center console trim also required attention to make sure all the lines would line up perfectly.
Installing back the trims took 2 minutes and the center console, maybe 30 minutes. I had a bit of issue installing it back properly.
      01-14-2012, 08:06 AM   #6
Swederinger
Sweden
Seem like quite the job =)
Connectors not connected? Can it be for the Nav maybe?
Looks great though! The work paid of!
I getting some CF-vinyl, and im gonna try to do the same. Hopefully it will look as good as yours =)
      01-14-2012, 08:54 AM   #7
Detailer
Drives: BMW F80 M3
Oh, you are right. They must be for iDrive equipped cars. I guess they are all pre-wired for it.
Honestly, it is all worth it. Doesn't take that long, doesn't take much skills either and geting rid of the wood is priceless.
All you need is a few basic tools, a brand new rasor blade and a heat gun. I ordered 1'x4' and I'm left with two small pieces of 6"x8". So, cut carefully. I suggest you leave at least 1" extra around the pieces to easily lift and pull after heating to get a smooth surface. Use patience, don't rush things.
      01-14-2012, 10:25 AM   #8
Swederinger
Sweden
Thats right, you had the woodpanel. Its great if you like the late 80ies. But I understand you on getting rid of it. =)
Iw got the rugged alu-look. It looks nice, but im having a lot of exterior changed to CF to so I would like it to match all around.
Thanks for the tips!
      01-14-2012, 10:41 AM   #9
Swederinger
Sweden
Oh! I can probably not do it... Because of the "bumby" texture on the trim... darn it....
      01-14-2012, 10:46 AM   #10
chachacha28
NCOIC of Kickin It
Germany
78
offer to trade trim with someone. Im doing that right now.
      01-14-2012, 10:49 AM   #11
Swederinger
Sweden
Good thinking!
I actually saw a thread about that. Ill see if its worth it. Might be able to live with it anyways =)
      01-14-2012, 10:58 AM   #12
chachacha28
NCOIC of Kickin It
Germany
78
Good thinking!
it might have been mine. lol.
      01-14-2012, 10:58 AM   #13
Carolinagirl
Southern Belle
Carolinagirl's Avatar
Drives: 2015 BSM 428i
Looks awesome
2015 BSM F32
      01-14-2012, 11:48 AM   #14
Detailer
Drives: BMW F80 M3
You are right, it will not work over the textured aluminium trim. I'm sure you can trade and even make money out of a trade like this.
Originally Posted by carolina1ergirl View Post
Looks awesome
Thanks!
      01-17-2012, 03:16 PM   #15
SV Concepts II
SV Concepts II's Avatar
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
Nice work! Looks great.
      02-19-2012, 02:45 PM   #16
HIPSI
Drives: 08 135i
Does anyone know, is there any trick to removing the i-Drive knob, or is it just grab tight and pull up?
08 135 Coupe SGM/Terra
15 Porsche Macan S- Family Hauler
22 C8 Corvette 3LT HTC
      02-19-2012, 02:56 PM   #17
Rikx1M
MSgt (ret)
Rikx1M's Avatar
Germany
563
Drives: VO 1M #739/740
Looks amazing...professional especially the way you lined up the textures on the center console and ashtray lid.
Any other tips? By chance did you do a DIY procedure recording while you did this?
      02-20-2012, 12:48 PM   #18
Detailer
Drives: BMW F80 M3
Thanks!
Sorry, don't really have any tips or DIY, it's pretty straightforward. Thing you always need to remember your self is that di-noc when heated up, will be super soft, so you will be able to remove any defect by heating and stretching it.
Look at di-noc DIY on youtube, you'll see people wrap easily some very complex pieces.
      02-20-2012, 02:02 PM   #19
716
Lurk No More
Drives: Currently BMW-less
Absolutely gorgeous. Well done!!
      02-28-2012, 02:29 AM   #20
MITE82
MITE82's Avatar
Drives: 08 135i 6AT BSM
How can you get all the pieces of the center console to line up just so ? Cover everything with one big piece and cut them at the same time around the edges ? I been watching YouTube vids everywhere trying to figure this out but still no luck yet :/
BMS JB4 PnP / RPI scoops / BSH OCC / BMS DCI / H&R Super Sport Springs / Nitto INVO 225f 255r / CP-e axle back / BMWPerf. CF rear spoiler, iCarbon CF sideview mirror covers / CF grills / BMWPerf. Front rotors / EBC slotted rear rotors / SS Braided lines / StopTech performace pads / E93 M3 Front Sway / BERK resonated mids / BMS 12mm spacers
      02-28-2012, 05:50 AM   #21
Detailer
Drives: BMW F80 M3
Exactly, apply one big piece over the center console, then cut each piece leaving equal part of vinyl on both side and heat the edges and pull the vinyl to it covers completely the edges.
I must admit that the cover of the ashtray is not perfect, there was not enough vinyl to cover completely the edges. But you don't notice it when it's closed. I guess if it was covering light wood or light color, it would be noticeable though.
      02-28-2012, 07:27 AM   #22
135IS
Drives: 09 LMB 135I / AW 1M
2009 135i  [7.00]
Hopefully this lasts you through the summer!
LMB 135i: Gone
AW 1M: Current #211 of 220
1addicts
