11-27-2011, 07:54 AM | #1 |
Rep 217
Anystream Bluetooth in pre 2011.5 M3?
I miss BT audio streaming in my 2011 M3 and stumbled across the Anystream device. It is a little Bluetooth dongle that plugs in to the iPod connector (eg in center console of an M3) and then allows you to stream music through A2DP. Was wondering if anyone had experience with this thing in an m3?
http://www.cartronics.com/POM.html Thanks! |
11-27-2011, 10:12 AM | #3 |
Rep 2,874
I'd say just buy it and see if it works.
11-27-2011, 10:41 AM | #4 |
Rep 217
11-28-2011, 10:30 AM | #7 |
Bored all the time
382
Rep 2,173
i bought one of those for my old S5... didn't work as for some reason Audi decided to cut the power off to the device if it doesn't sense sound coming from one of the pins on the ipod.
I don't know if i still have that thing laying around, but i'll see if it'll work on M3.
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3... It all started with an RX-7 (FD). |
12-01-2011, 07:30 PM | #8 |
Rep 217
So as promised, I'm reporting back after getting the anystream. Unfortunately, the news is not good. It does not work with the proprietary BMW Y cable (that hooks up to USB and mini stereo) or with a standard (white) Apple USB cable. Very low signal level, lots of static and disconnects constantly. So it appears to be a no go. apparently BMW reverse engineered a very non-standard cable for our early 2011 and earlier M3s.
Boostin FD - any better luck on your end? |
12-01-2011, 07:52 PM | #10 |
Rep 653
I have an '08 and use this Blackberry bluetooth stereo gateway. Plugs into the USB for power, the headphone type jack for the sound. I can wireless stream everything from my phone straight through it to the car audio. I put car in the AUX mode.
http://docs.blackberry.com/en/smartp...Gateway-US.pdf |
12-01-2011, 09:28 PM | #11 | |
Rep 217
12-01-2011, 09:37 PM | #12 |
Bored all the time
382
Rep 2,173
Same like s5... It keeps cutting power... So no go.
12-01-2011, 09:39 PM | #13 | |
Bored all the time
382
Rep 2,173
12-02-2011, 09:49 AM | #15 |
Rep 16
I have one in my 08 G37 which did not come with A2DP, works like a charm. Ironically I paid $20 for it so I bought 2 in the event one should ever stop working. It did require some major searching on the internet to find one though as they are no longer made.
Search for this - Anycom fipo |
12-02-2011, 09:59 AM | #16 |
Bored all the time
382
Rep 2,173
how is the sound quality on it? Any noise, static or crap like that?
12-02-2011, 11:40 AM | #17 |
Rep 217
Since I have one of these as well I can tell you the sound quality is very good. No noise or static. I do not know if it can work a dual profile the way the Anytream can (when it works). What I mean by this is that the Anystream is only seen by the iPhone as a music channel and it allows the option to still be connected in parallel to the car for phone use. This may not matter to everyone but I liked this about the Anystream - if it had worked, I could listen to music in my car via BT but if a phone call came it, the car would then switch seamlessly to the phone BT connection. I don't know how the bberry gateway works in this respect since I use it in an airplane which does not have phone BT connectivity.
12-02-2011, 12:10 PM | #18 |
Bored all the time
382
Rep 2,173
I'll give it a shot. Thanks bud
12-02-2011, 12:40 PM | #19 |
Rep 217
Also, the bberry is only a passive sound pass through. No skip track, pause or back button thought the steering console. Not really a big deal, but in the interest of full disclosure compared to a full A2DP profile
12-02-2011, 02:38 PM | #20 |
Rep 653
12-14-2011, 09:37 PM | #21 |
BMW Nut
50
Rep 452
Very interested to hear if anyone has developed a solution to this problem. Having direct track control would be fantastic, but I'll take great quality sound with no wires streaming from Google music on my galaxy nexus any way I can get it.
subscribed
12 X5 xDrive35i | Platinum Gray | Oyster | Burl Walnut | Premium | Convenience | 3rd Row | Apps
13 Audi S4 | Misano Red | Black 04 S2000 | Berlina Black | Black |
01-08-2012, 09:16 AM | #22 | |
M - Lover!!!
169
Rep 720
Drives: E36 M3, E92 M3, F90 M5
Apparently it gives it more power to the Y-cable wondering if anyone has tried this option? The current audio Y-cable which is supplied with cars equipped with a USB/Audio interface (SA 6FL) will not charge an iPhone 3G or 4, under many circumstances. As a result, this new charging cable was developed to use in conjunction with the existing audio Y-cable. The charging cable is used in series/inline with the audio Y-cable. (also on special above) This charging cable is required due to the fact that the USB port only supports charging at a rate lower than many iPhones require. Note: Some cars produced from 9/2010 will not be equipped with an audio Y-cable. The white Apple cable may be used on these vehicles for connectivity, but this cable will still not charge the device properly. Therefore, the charging cable is applicable to these vehicles as well. * Allows charging for Apple iPhone and iTouch models while that device is connected through the vehicles USB/Audio interface. * A must when streaming internet music which tends to deplete the iPhone’s battery fairly quickly. * Tested and approved for automotive application. * Fits conveniently in the center console storage compartment.
Current : - 97 E36 Estoril Blu M3 - 11 E92 Space Grey M3C - 21 F90 Aplina White M5C Previous :- 18 F85 Donington Grey X5M - 17 F80 Macau Blu M3 Jahra Edition - |
