11-26-2011, 03:51 PM | #1 |
Rep 1,105
Best place to shift-dct
So I realized I am just not good at being able to take it all the way to 8400 without having fuel cutoff engage. I try to shift around when the needle passes 8k and usually that works but sometimes it is a bit to late and its hard to guess how much before 8400 to shift, in order for it to actually hit 8400 in manual mode? Same with the shift lights-sometimes I get it sometimes not. I am probably just inept but any tips may help!
11-26-2011, 04:09 PM | #2 | |
Rep 843
Don't the shift lights help with this issue at all? Maybe shift while it's amber? |
11-26-2011, 04:43 PM | #3 |
Rep 974
Drives: E92 M3 SSII/Fox Red ZCP DCT
its all about feel and practice...i can shift at 8400 without looking
E92 M3 SSII/Fox Red, DCT, ZCP past rides-IS350, E92 335i |
11-26-2011, 04:50 PM | #4 |
Rep 381
11-26-2011, 04:54 PM | #5 |
Rep 974
I have seen videos and my friends have told me.
11-26-2011, 05:05 PM | #6 |
Rep 751
Except as a purely academic exercise, I'm not sure I understand the focus on shifting at 8400. If you look at the hp/torque characteristics of the engine, it just doesn't make much practical difference. On the typical road course, you're usually much more appropriately focused on what you should be doing with the other controls, in order to have the car where it needs to be at about the time it needs to be there.
11-26-2011, 05:12 PM | #7 | |
Rep 1,432
11-26-2011, 05:18 PM | #8 |
Rep 1,105
good advice. Shifting at 8k or so sounds like a good goal and then you are likely to truly shift around 8200-8400 by the time it shifts. That is a good target to shoot for thanks
11-30-2011, 05:24 AM | #9 |
Never underestimate the Home-Bowl
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
Isn't this what the Shift Lights are for?
11-30-2011, 05:41 AM | #10 | |
Low Pro...
35
Rep 1,067
I make mistakes, but I'm getting there. |
11-30-2011, 08:08 AM | #12 |
Rep 3,246
This car revs so freely and quickly it's easy to just bounce off the limiter. Also, I believe you can adjust the sensitivity of the shift lights, ie. they come on earlier or later in the rev range. Don't think bouncing off the limiter is going to kill this car, at least hasn't killed mine yet I think you'll find seat time will cure all problems. The more I drive the more I love it
mods: track ready stuff
11-30-2011, 08:22 AM | #13 |
Rep 915
Why would you want to take it all the way to 8400? By the time the engine has spooled up to that level, the torque has basically long been acheived, and waiting to shift will likely have the negative effect you are attempting to avoid. Try and use your other senses (not smarts) to determine when to shift. Feel and sound should be key, and use your lights to assist in your alert to shift. As the christmas tree begins to light up, shift. Don't wait until it reaches the end, if you do, you have missed your shifting point.
vz
Previous Track Toy |
11-30-2011, 08:44 AM | #14 |
Rep 19,368
Well, D5 will shift at red, and if you do the math (or search the forum - its been posted before as I recall) you will see the car is fastest when shifted at max RPM.
11-30-2011, 09:34 AM | #15 | |
octane chick
79
Rep 1,187
Drives: ex-M
11-30-2011, 12:47 PM | #16 | |
Rep 2,000
You're pushed back in your seat at the shift not by power or torque, but by rotational inertia. The engine is forced to slow down in an instant by, say, 3000 rpm or more on the one-two shift (less as you go up through the gears), and that energy is transferred through the driveline to the rear tires. If the auto has a setting that will shift at the rev limiter, that's the one to use. Otherwise, use the one that shifts at red line. Bruce |
11-30-2011, 04:28 PM | #17 |
Rep 10,407
Guys, the simplest way to think about this is when an engine has a very linear power curve like the M3 the power you are producing is directly proportional to the rpm. Shift always at 8k instead of 8400 and you are only using
8000/8400 x 414 hp = 394 hp This is a very rough calculation but shows even an 8k shift is leaving about 20 hp off the table! Not a huge difference (5%) but if you are counting 10th's or simply want to be insured you are moving out as best a possible you have to shift at redline.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
11-30-2011, 04:57 PM | #18 | |
Rep 2,464
2011 MINI Cooper S
previous cars: E92 M3, Z4MC, Z4 Roadster, E36 328 Sedan |
11-30-2011, 06:37 PM | #20 |
Rep 856
That's what's great about raising the rev limiter to 8600rpm. I did this with the ESS tune and now I can shift at 8400 RPM without hitting the limiter. I don't even have to look at the rev gauge, just shift when the lights turn red and I get a perfect shift every time.
///M3 Mods: | Eisenmann Race Exhaust | Primary Cats Delete (TTP) | ESS Tune | 19" Advan RS | Eibach Springs | MS Air Filter | BMW Perf. Spoiler | BMW Perf. Splitters | Euro LCI Tail lights | Angel iBright v.3.0 | 20% Tint | Matte black Kidney Grills | CF Side Gills | Painted Reflectors | Black M3 emblem
11-30-2011, 06:48 PM | #21 | |
Rep 2,000
Of course, it might blow up, but that's a small price to pay for another tenth or two, isn't it? Bruce |
11-30-2011, 07:01 PM | #22 | |
Rep 856
