BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
BPM
      11-20-2011, 06:34 PM   #1
PGabriel
Drives: M3 E90
M3 suspension too stiff for some streets?
I noticed that driving the M3 in some paving-stoned streets is just unbearable, the whole car shakes (along with the passengers) as if it would fall apart. Even driving slowly in D1/Power on normal/DCT to comfort won't make it better.
Is that normal for the model?
      11-20-2011, 06:49 PM   #2
GIdriver
GIdriver's Avatar
Drives: 2014 E63 AMG-S
In my opinion ride is firm but not unbearable even in sport. Don't know for how long you have had the car but may want to check if it still has the shipping blocks in place. Do a search about it in the forum.
      11-20-2011, 06:51 PM   #3
bobbyd1961
Drives: 2009 M3 sedan LeMans Blue
what are shipping blocks
      11-20-2011, 06:51 PM   #4
SeeYaLater
Drives: F10 535i
My street is bumpy as hell, so i always turn off the M button when i turn on my street, but its still no Camry soft ride (thank god).
      11-20-2011, 06:52 PM   #5
-=Hot|Ice=-
Been There, Done That.
-=Hot|Ice=-'s Avatar
Drives: 2013 BMW M3
They're white blocks over the suspension to prevent damage during transport. I don't think the drive on the M is all that bad.
      11-20-2011, 07:01 PM   #6
gthal
gthal's Avatar
Drives: 2018 340i xDrive
My car is not at all uncomfortable but that is somewhat subjective. Maybe you are just overly sensitive to a firmer suspension... maybe you still have the shipping blocks in? I don't think you can easily see them and would have to take the car to the dealer to check. IMO, the car is NOT overly firm and is actually fairly comfortable in "comfort" mode on the EDC.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery
2016 M2 | Long Beach Blue | 6MT
2015 M4 | Austin Yellow | DCT
2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3
      11-20-2011, 08:12 PM   #7
Foodle
Drives: 2011.75 E90 M3
Drive faster and skim over them
      11-20-2011, 08:54 PM   #8
rye m3
Switzerland
33
Drives: 2011.75 E92 M3
The threads here are endless... Why did you buy an M3 in the first place? Did you test drive it before you bought it? Really, useless threads like this just pollute this forum...
E92 M3 MR on Red/Black ZCP Sound
Carbon
2007 997S - sold
2003 E46 M3 Steel Grey on Red- sold
1997 E36 M3 Arctic Silver on Black- sold
      11-20-2011, 08:56 PM   #9
piloto
Drives: 2011 E90 M3 - AW/FR
I find the ride to be quite good in comfort mode, and that's on a zcp equipped car fwiw. As someone said, maybe it's due to still having shipping blocks in there or anything this side of an old school Caddy or Buick is not for you.
      11-20-2011, 09:10 PM   #10
BMW Fanatic
Drives: slow
Post a side-view pic of your car from a distance where you can actually see the whole car, we should be able to determine if still have shipping blocks or not.. If it's the latter then BRO this car is not for you. Maybe you should take a pic of the road you're describing too.. Hmm..
      11-20-2011, 10:52 PM   #11
Ateam
Drives: M3
People are missing the most obvious and likely answer which is tire pressure. Especially if you just got the car many dealers forget to drop the PSI from 50 which is used to ship down to 35 on all 4 corners which is reccomend. Change psi to 35 first.
Second shipping blocks can be checked for and they are in the front. You simply have to crank your wheel all the way to one side so you can get a good look at your front suspension/strut. You can then look UNDER the rubber cover that the shipping blocks fit into. They will be white or white green
      11-20-2011, 10:54 PM   #12
smmmurf
Drives: E92 M3 DCT 353k+ miles
Tires are key. The car is rough on bad streets. Just think about what kind of streets the car was designed on/for. The f-ing Autobahn. During European Delivery I realized this. A car optimized for stability and response at 140MPH regularly is going to make some sacrifices in comfort to a Camry or something designed for pedestrian speeds in the USA.
FYI If you switch to all seasons the NVH is GREATLY REDUCED.
But so is the grip and steering response in the dry
      11-20-2011, 11:53 PM   #13
MienAce
gotAWD?
Drives: E85EvoIX
buy a Camry, you'll have a smooth ride.....1 of the best.
CornFedEvo
      11-21-2011, 05:12 AM   #14
LarThaL
LarThaL's Avatar
336
Drives: 2011 M3
Agreed. If the ride is truly "unbearable" the shipping blocks might have been left in. Happened to me. Also, your front end will be sitting a little high by about and inch. There is no way to see the blocks from the outside. They are located INSIDE the rubber shroud of the front shocks. They can be popped out easily in a few seconds, however.
Audi S6 * Audi S3 * Porsche Cayman GTS
--Former BMW M3 owner
      11-21-2011, 11:08 AM   #15
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [10.00]
2013 X5  [0.00]
2013 335i F30  [8.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
comfort mode is still way stiffer than a sport package non-M 3 series
      11-21-2011, 11:25 AM   #16
knifegun
knifegun's Avatar
Drives: M4
Are you kidding me? If you are on a stock suspension and think the ride is stiff, then you may want to consider a different car. I think the stock ride while stiffer than others is way within a comfortable margin.
      11-21-2011, 11:28 AM   #17
gblansten
gblansten's Avatar
1977
Drives: 23 Tesla S Plaid
The M3 is pretty comfortable to me. I just changed over from a C63 which had a stiffer suspension. Didn't mind the C63 suspension either though.
      11-21-2011, 12:41 PM   #18
rhouck
rhouck's Avatar
Drives: 2008 E92 M3
The car was not designed for paving-stoned streets. /thread
      11-21-2011, 12:58 PM   #19
gthal
gthal's Avatar
I agree... the comfort setting is still sporty and firm but by no means rough or uncomfortable. It is actually surprisingly comfortable... unlike Richpuer's comments above, to me, it is very similar to a 335i with the sport suspension. One thing to remember, tire choice and tire pressure play a BIG role in ride comfort too. A set of PSS at 35PSI and it's like driving a Caddy... well, kind of.
      11-21-2011, 01:24 PM   #20
saeyedoc
Drives: 2013 Carrera S, 2013 Panny GTS
I totally agree, alot has to do with the run-flats on the non-M cars.
      11-21-2011, 05:40 PM   #21
PGabriel
Drives: M3 E90
Ok took some pics and did measurements. Front fender clearance to ground is 27.48". Rear is 26.57". I can stick just about four fingers in the front fender gap. In the rear gap a bit over one finger.
Here go the pictures. I´m bringing the car in for the 1,200 miles service next week.
Does it look like the shipping blocks are still in place?
BTW in the last pic, the rubber cover seems to be dettached from the structure above it. I checked the right wheel and it´s totally closed. Is that something I should worry about?
      11-21-2011, 05:49 PM   #22
Black Gold
Drives: M3
I never had shipping blocks on my car, or seen it in person. But what I can tell you is that doesnt look right to me.
My car looks identical to yours, but my gap is maybe two fingers in the front, not four and looks much lower than your car.
Tags
shipping blocks
m3post
