11-15-2011, 09:15 AM | #1 |
Rep 241
HELP! Coin dropped behind ashtray, how to take apart?
The circled small area...I dropped a coin back there and everytime I make a turn I can hear it roll to the other side. It's back behind the whole assembly (behind the ashtray) and so pulling out just the ashtray does nothing. How do I take apart the shifter assembly to get to the coin? Peter
2024 BMW M3 CS -- 2021 STO UGR TT -- 2019 McLaren Senna -- 2021 McLaren 765LT -- 1997 Toyota Supra Turbo -- 2006 Ford GT -- 2022 Lamborghini Urus
11-15-2011, 10:30 AM | #2 |
Rep 3,293
Do you have a good relationship with your dealer, service advisor or sales advisor? If so, just take it in and tell them the situation they should remove it and take the coin out on the spot.. Good luck
11-15-2011, 02:03 PM | #3 |
Rep 241
LOL, yes I do, I would just prefer to do it myself as that way I can guarantee no scuffs or scratches.
Peter
11-16-2011, 03:36 PM | #5 |
Rep 241
I tried simply pulling/tugging on the console and it didn't budge......
Peter
11-16-2011, 05:32 PM | #6 |
Rep 15,818
to take the center piece off, you need to remove the gear shift first
04-13-2012, 10:26 AM | #7 |
Rep 1
Hi- Annoying coin behind ashtray.
Pull Gear knob gaitter in the Corner and it will lift up - No need to remove gear Knob. Gently pull the Plastic Trim either side and small clicks will happen as the trim starts to Lift. Take your time working your way round until you can lift up. By turning the trim you can lift over the gear Knob and gaiter. You will have to remove wires to I-Drive unit and Cigarette Lighter. these just pull out. You will then be able to turn the Trim upside down- with a shake coin will Drop out. Mine was a £2.00 coin -- I put it on the Lottery and won £10.00 Hope this helps-- good Luck---Should only take 10mins |
04-15-2012, 09:59 AM | #8 |
Rep 8,076
Drives: 11 E90 M3 Individual
I saw the title and was thinking this guy must be a cheap penny pinching SOB. I now understand your issue.
Lol...
2018 F30 320iX Melbourne Red
04-19-2012, 04:49 PM | #9 |
Rep 85
06-13-2012, 04:13 AM | #10 |
So Kewl Guy
49
Rep 619
I had this happen. Two quarters. Im guessing they fell in front of the door/cover and try are rolling behind there. If that is the case, close the ashtray, take your hand and hit the side of your console on the passenger or driver side and the coins will lay flat. Open the ashtray and check. You can then use a paper clip or something to pull them out. Hope this helps!
2010 E93 M3 / MS Catless X-Pipe / AA Catback / Vorsteiner Vented Hood and Bootlid E93 Trunk / ADV1 7.1 Wheels GB / LS3 LED Lights / Harrop Supercharger
06-13-2012, 04:14 AM | #11 | |
So Kewl Guy
49
Rep 619
06-13-2012, 08:54 AM | #12 |
Scrappy Coco
62
Rep 447
Drives: 2012 M3 AW DCT ZCP ESS 625
If your a non smoker, you may want to consider this while you have the console apart:
Sunglass holder/ashtray replacement http://www.ecstuning.com/BMW-E90-328...nsole/ES83722/ My next DIY. Good luck!
Alpha///M
ESS VT2 625- GTS DCT Tune- Full Challenge Exhaust- Mode Carbon- Other Stuff |
06-13-2012, 09:09 AM | #13 |
Scrappy Coco
62
Rep 447
And on post#24 of this link, this guy luminated his DIY sunglass holder. Slick!
http://www.m3post.com/forums/showthr...+Holder&page=2
Alpha///M
