11-13-2011, 04:35 PM | #1 |
Rep 1,105
F1 gear box v. our DCT
Just watched the dubai grand prix and was thinking that the dct does not "sound faster" in how it shifts and I do not know how you can really continue to get any faster than our dct given there is already absolutely no loss in power with the change and it is instant changing. Obviously there are probably a million other differences such as I just heard a piece how they actually have 2 clutches that they can operate independantly manually or have it in the computerized clutch mode. Did not know this but in their launches
they actually manually operated their foot clutches or something as it was an interested piece on why there is such variation in webbers piss poor starts but great driving! ANyone else knows what their tranny do differently or are they a totally different animal? Other than being way stronger obviously |
11-13-2011, 07:06 PM | #2 |
Rep 1,202
F1
Crap, I forgot to set the DVR for the race.
20 M340xi White Mocha
17 340i/M235i/E92 M3/135i All 6spd Chicago-Lake County-Milwaukee-Shorewood |
11-13-2011, 07:36 PM | #3 |
Rep 2,536
good question.. i guess this is something to consider.. when SMG came out, everyone thought it was amazing. DCT came out, and now SMG is ass in comparison.
I'm basically saying DCT could be ass compared to whatever those boys are pushing... |
11-13-2011, 07:36 PM | #4 |
Rep 979
In F1 they are required by the rules to interrupt the power between shifts. When Williams first devolped the tranny it had no power interruption but got banned.
It is hard to know the details between the two but I would think they are close enough in design....
2011 E92 M3 | JEREZ BLACK | EXTENDED BAMBOO NOVILLO | EXECUTIVE PKG | M-DRIVE | EDC | M-DCT
MODS | KW S/O | HRE P40SC | Akra Evo |ESS Akra Tune | ESS DCT tune | BMC drop in | StopTech Trophies | TMS Pulley | LUX V3 | BE Bearings and BE ARP rod bolts |
yifuqiao40.00 |
11-13-2011, 07:52 PM | #5 | |
Rep 3,293
11-13-2011, 08:30 PM | #7 | |
RawAutos.com
29
Rep 476
So the DCT is technically faster, but it's not, simply by the design of the cars the DCT goes in to versus the sequential gearboxes F1 use. Here's a picture of the F1 wheel with the clutch and shift paddles present.
2009 E90 M3| Jerez Black | Extended Silver Novillo with Brushed Aluminum | 6MT | EDC | Premium Package II | Convenience Package | Enhanced Premium Sound | HD Radio | Heated front seats | Fold down rear seats | Moonroof | 19" wheels | RawAutos.com |
11-13-2011, 08:44 PM | #8 |
Rep 183
There are two manual clutch levers on the F1 cars, both only used during the start, and both on the steering wheel. One clutch is carefully manipulated and the other one dumped during the start. The tolerances are extremely tight and the clutch bite points are set during the recon lap before the start. Any fluctuations in ambient conditions will change the bite-point and therefore compromise the starts. While the driver has a lot of influence on the F1 start, the background technical wizardry needs extremely careful setup.
During the race, the gearbox shifts seamlessly. There are no clutches. You can't say how long it takes to shift gears in F1 because it's seamless, but "the total travel of the dog ring between a neutral state and an engaged state takes around seven thousands of a second." Design, testing, and production of an F1 gearbox takes 3-3.5 million pounds for the eight gearboxes for the season, additional ones are estimated at 200.000 pounds. |
11-13-2011, 11:16 PM | #9 |
Rep 4,318
Great summary. To the OP F1 boxes are more akin to a traditional sequential manual - the only thing they have in common with DCT is paddle actuation.
GT3 RS | Desperately seeking the next great M car...
11-13-2011, 11:31 PM | #10 | |
1M advocate
214
Rep 878
As for shifting the gearboxes are often able to seamlessly shift (no clutch movement) which is performed faster than a DCT box can complete a shift action, although occasionally the system can fault and a clutched shift is performed which is probably equal speed to a DCT shift. BTW in terms of strength you have to remember that a modern v8 f1 engine only makes ~225lbft of torque and given the drive to reduce weight and reduce packaging volume I would bet the gears themselves aren't much if at all higher strength than the ones in any modern sports car. The biggest difference outside of the actual design is probably the construction materials within the boxes themselves. Probably lots of titanium and exotic alloys.
2012 BMW S1000RR
2011 BMW M3 Last edited by Serious; 11-13-2011 at 11:43 PM.. |
11-14-2011, 06:59 AM | #12 | |
Rep 19,368
Regarding the F1 gearbox, I am curious now. Does anyone know: - how many speeds they have - if they are wet clutch or dry clutch - if the clutches are concentric like a DCT (I have to assume yes) - if they can skip gears |
11-14-2011, 08:04 AM | #13 |
Rep 5,548
Here's a video by Mercedes GP discussing a modern F1 gearbox:
The gearbox uses a "conventional" dry multi-disc carbon clutch plates (a total of seven, i think) with an outside diameter of ~4". The transmission design is a lot closer to a motorcycle sequential gearbox than a road car (conventional or DCT) and, no, they cannot skip a gear. Other than using paddles to shift gears an F1 gearbox is nothing like our DCT. |
11-14-2011, 11:00 AM | #15 | |
RawAutos.com
29
Rep 476
11-14-2011, 11:05 AM | #16 |
Rep 1,105
That video also says there "is no interuption in power" so whoever said that is not allowed is clearly wrong. I actually thought they used a Dual clutch gearbox all race so this is also new to me. I knew there was some funny business about the start which makes sense since if it was as simple as "launch control" there would not be such a variance consistently among good starters and bad. Poor webber is plagued by the start. Must be so frustrating being vettel's teamate.
All is interesting to me though, I guess it is not so senseless that the new lambo has a classic SMG and not dct as that is truly more race tech than the dct. Learn something on these boards every day! |
11-14-2011, 11:20 AM | #17 | |
1M advocate
214
Rep 878
2012 BMW S1000RR
2011 BMW M3 |
11-14-2011, 12:11 PM | #18 | ||
Rep 19,368
11-14-2011, 12:18 PM | #19 | |
Rep 4,318
11-14-2011, 01:49 PM | #20 |
1M advocate
214
Rep 878
here is a breakdown of how the 'zeroshift' boxes work...
http://www.zeroshift.com/pdf/RcarN6V15_Zeroshift.pdf I assume this is similar to the method the F1 teams are using to operate the seamless shift boxes.
2012 BMW S1000RR
2011 BMW M3 |
11-15-2011, 06:56 AM | #21 |
Lurker
78
Rep 812
FYI, most (I'm not sure about F1) racing gearboxes have tougher (louder) straight-cut gears that can take shifting without use of the clutch. That's been true for over 20 years. Still, the revs have to be matched on any shift (up or down) and making that fast depends on lightened components (flywheel, clutches, crankshaft, pistons, etc) and carefully tuned software.
Most racing gearboxes I've seen make more noise than a street car's engine :-)
