BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
Mporium BMW
      10-18-2011, 03:47 PM   #1
M4 Cab
Drives: 2015 M4
2015 BMW M4  [0.00]
BMW Apps & Pandora
I have really enjoyed using Pandora with my Iphone 4 in my M3 when I am note listning to the engine, but now with the new Iphone 5.0 software uopdate, my pandora is not working. It trys to connect to the BMW, but then says to check to make sure that my Pandora is the latest version. Help! Any ideas would be appreciatted. I called BMWUSA CS & they suggested I turn off my bluetooth briefly. Obviously didn't help. I have reloaded Pandora without success. Thanks.
2015 M4 Mineral Grey/Black extended leather/-speed/Executive package/19" silver rims/HK stereo/Enhanced Bluetooth-USB/-speed/Moon roof/LED lighting package/HEX tuning stage 1
Sold -2011.5 M3 Convertible/Space Grey/Black
Sold - 2002 M5 with Dinan springs & exhaust.
      10-18-2011, 04:03 PM   #2
Technic
Technic's Avatar
2288
Drives: 2021 i3S, 2024 i4 M50
Pandora does not work with iOS5 and BMW Apps... expect an update soon.
      10-18-2011, 04:09 PM   #3
M4 Cab
Drives: 2015 M4
2015 BMW M4  [0.00]
How do you know? Where will the update come from? Thanks for the quick response.
      10-18-2011, 04:19 PM   #4
Technic
Technic's Avatar
2288
BMW Apps/Pandora has been broken since iOS5 beta.
      10-18-2011, 06:16 PM   #5
jphughan
jphughan's Avatar
Drives: '16 Cayman GT4
This will likely be an update from Pandora. In the meantime, try using Pandora through Bluetooth streaming. I know it's not ideal but now that iOS 5 includes AVRCP 1.3 you can actually see song metadata, so it's much nicer. However, I'm not sure Pandora supports metadata transmission over Bluetooth since I haven't tested it since updating to iOS 5. The bummer is you can't plug your phone in to charge that way (since that kills Bluetooth audio), but at least you'll have music.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten:
'11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015)
      10-18-2011, 06:44 PM   #6
Technic
Technic's Avatar
2288
It does not, but the steering wheel forward button works.
      10-18-2011, 07:29 PM   #7
M4 Cab
Drives: 2015 M4
2015 BMW M4  [0.00]
Thanks - I couldn't figure out why my BT audio wasn't working.
      10-18-2011, 09:02 PM   #8
m3keash
Drives: E93, JB/Bamboo, Adv.1 8.3 20s
Guess I'm not upgrading to version 5.
JB, Bamboo, every option, 20" Adv.1
      10-18-2011, 09:37 PM   #9
tlp
Drives: 991 GT3, Sold:'11 e92 M3 SG/FR
FYI: BMW Apps with my iPhone 4S on iOS5 works fine with the web radio app. I did not test it with Pandora. Also, normal iPod navigation via the idrive works fine as well. I also have it plugged into the iPhone 4 media adapter.
991 GT3, Sold: '11 e92 M3 SG/FR ZCP|ZCV|ZP2|2MK|494|415|6NR|752
      10-18-2011, 09:46 PM   #10
jeff@autocouture
BimmerPost Supporting Vendor
jeff@autocouture's Avatar
966
Drives: 2002 E53 X5 4.6is
i had that message also, close out the pandora app in the task bar section of the phone, keep doing it till iit works, took me about 3 times
      10-18-2011, 10:46 PM   #11
flitcroft
Drives: MY11 M3 Sedan
Slightly off topic but how do you get Pandora to work in BMW Connected? I see web radio, Twitter, Facebook, Last Mile, and Calendar but no Pandora.
      10-18-2011, 11:06 PM   #12
dagolfpro
dagolfpro's Avatar
Taiwan
248
Drives: 2011 E90 M3
Yeah, iOS5 has screwed up many of my apps as well. I used V1 Golf for all my golf lessons and it's @$%@#$ up!!! I wish I hadn't upgraded. I'm sure other apps has been jacked up as well.
      10-19-2011, 04:56 AM   #13
Technic
Technic's Avatar
2288
Start Pandora and plug iPhone. In that order.
      10-19-2011, 04:42 PM   #14
M4 Cab
Drives: 2015 M4
2015 BMW M4  [0.00]
I think you have the order reversed - in order to connect the pandora & the bmw. the phone has to already be connected by the iphone cradle.
      10-19-2011, 04:43 PM   #15
M4 Cab
Drives: 2015 M4
2015 BMW M4  [0.00]
While changing topics - I tried taking my phone out of the cradle & using BT audio, but it styill does not work. What am I doing wrong. I have BT audio checked on the car. Thanks.
      10-19-2011, 04:44 PM   #16
M4 Cab
Drives: 2015 M4
2015 BMW M4  [0.00]
Thanks - I will try it.
      10-19-2011, 04:44 PM   #17
Technic
Technic's Avatar
2288
The iPhone cradle is not required for BMW Apps, much less for Pandora. It is only required for iPod Out.
Start Pandora and then plug iPhone... once Pandora is fixed in iOS5.
      10-20-2011, 09:21 AM   #18
jphughan
jphughan's Avatar
It doesn't matter what order you do this in. You can open Pandora before or after you connect it to USB or the cradle, makes zero difference at least in my car.
      10-20-2011, 09:22 AM   #19
jphughan
jphughan's Avatar
That's because every time you plug your phone into the cradle or USB port while Bluetooth is enabled, BT audio is disabled and it does not get re-enabled when you disconnect it. You should get an alert on the iDrive screen about this when you connect it. You just need to disconnect the phone, go into the options for your Bluetooth phone, and select the Audio checkbox again.
      11-02-2011, 03:49 PM   #20
tma1c
tma1c's Avatar
Drives: 08 E93 6MT M3
Pandora update is up and works!
      11-02-2011, 04:08 PM   #21
aus
Drives: Odysse
Anyone try MOG instead of Pandora? It's suppose to be supported now.
I never saw the appeal of Pandora. MOG lets you pick what ever songs you want in your play list.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
      11-02-2011, 04:11 PM   #22
SamS
Drives: Tesla M3 Perf + '18 X3 M40i
Was it the Pandora app that got fixed, or the BMW App?
m3post
