09-29-2011, 08:23 AM | #1 |
Rep 83
What is that noise at 3200 RPM
Can anyone tell me what this metallic/tinny vibration sound is? It only happens right around 3200 rpms. Sounds like it's coming from under the hood. Kinda sounds like a thin piece of metal is being sheared off. It happens in all gears and only when the engine is warm. It never goes away as long as you hold 3200 rpms. Thanks for any advice.
09-29-2011, 08:35 AM | #2 |
Rep 1,002
Drives: 2007 Z4 M Coupe 2012 e93 M3
Most likely coming from the VANOS Upper valve train assembly.That is norma so get use to it (or get louder exhaust and Intake to drown it out;_)
09-29-2011, 02:20 PM | #4 |
Dog Listener
707
Rep 7,850
+1 on both follow ups to the OP.
It's just part of what the engine sounds like. You'll get used to it! I just tend to avoid that RPM range and don't sit around 3.2K. |
09-29-2011, 03:17 PM | #5 |
Rep 380
Vanos..
Z4MC_Black Sapphire/Imola-_-DMS ECU ll H&S cat-back ll H&R coilovers ll CF Lip ll Lamin-X ll Matte black kidneys ll Afe drop in ll Afe intake elbow ll RPi scoop ll LeatherZ imola shift boot ll ZHP knob...
09-29-2011, 07:15 PM | #6 |
Rep 784
Drives: 2011.5 E90 M3
It reminds me of an S52, makes me miss and hate my e36 all at the same time.
09-29-2011, 07:19 PM | #7 |
Rep 516
Drives: E85 Z4M, F82 M4
This noise used to scare the hell out of me, when I first heard it after reading about Vanos issues on this forum. Thankfully, I learned from others that it is absolutely normal.
09-29-2011, 07:20 PM | #8 |
Rep 784
Speaking of the vanos bolts, at what RPM do those like to sound off?
Or...what are the symptoms if they don't have an RPM associated sound? |
09-29-2011, 10:39 PM | #9 |
Rep 16
i was really worried about this too, then i stumbled across this on bimmerfest a few months ago:
i actually kinda like the sound. Last edited by EM-KOOP; 09-29-2011 at 10:41 PM.. Reason: added info |
09-30-2011, 01:31 PM | #10 |
Rep 335
Yep, get used to it. It's an inherent S54 characteristic. I hate the sound personally, but I've learned to tune it out. The Inspection II (including valve adjustment) I just got done has minimized it somewhat.
2007 ///M roadster |
