New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      09-09-2011, 10:18 AM   #1
ring007
ring007's Avatar
60
Drives: GT3RS & Speciale No BMWs now
M3 Brakes on a Z4?
Anyone tried retro-fitting M3 brakes (calipers and rotors) to a Z4? I have a spare full M3 brake setup in my garage from my M3. I'll take a shot at it if no one else has already tried it.
      03-02-2012, 02:39 AM   #2
persian54
persian54's Avatar
Drives: M760/G83M4
Did you ever try this? I know you don't have the car, but I was curious if you tried this or not?
      03-21-2012, 01:14 AM   #3
Cupholders
Cupholders's Avatar
Drives: E89
I recently purchased a set of M3 brakes. Can only fit the front though. Will update once it's done
      03-28-2012, 11:29 AM   #4
HK8888
HK8888's Avatar
Drives: '08 E92 M3
2008 M3 Coupe  [10.00]
      03-28-2012, 08:10 PM   #5
Cupholders
Cupholders's Avatar
Drives: E89
Totally forgot to update this page!
Anyway the rotors fit perfectly! Only problem is the caliper. It's slightly larger.. Only way to fit it in is to fabricate new brackets. IMHO, kinda unsafe..
Aborted the mission
CHEERS
      03-29-2012, 08:47 PM   #6
fre2bpowerless
India
Drives: Yes. :D
Doesn't the M3 come with single piston calipers while our Z's get four and six pots, I get the large single piston argument but more the pistons, better the heat, pressure distribution, less brake fade(?)
A simpler way to improve braking would be better tires & pads
zpost
