BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
      08-15-2011, 04:57 PM   #1
LarThaL
LarThaL's Avatar
336
Drives: 2011 M3
Hardwiring radar detector
Which empty fuse slot are people using to hardwire a V1 or other detector?
Thanks.
Audi S6 * Audi S3 * Porsche Cayman GTS
--Former BMW M3 owner
      08-15-2011, 05:03 PM   #2
tunawi7cheese
tunawi7cheese's Avatar
Drives: Power by dead dinosaurs
http://www.e90post.com/forums/showthread.php?t=97545
Melborne Red 08' E90 M3 6spd
Hockenheim Silver 20' F87 M2 CS MDCT
White 21' Jeep Gladiator Rubicon
      08-15-2011, 05:09 PM   #3
LateBraking
Drives: Relatively Quick.
Originally Posted by hvd.kevin View Post
This isn't fuse slot method, this is piggybacking off of sunroof I believe. It'll work fine, but I made a whole step-by-step photo DIY for the fuse slot method (below).
http://www.m3post.com/forums/showthread.php?t=409010
Friend is your search.
      08-15-2011, 06:23 PM   #4
warp10
warp10's Avatar
776
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
2011 M3  [10.00]
2011 28i X3  [0.00]
I used a "mini add a fuse" from a auto parts store that has two fuse slots. make sure to pick up some extra 5 amp fuses. I use the homelink fuse slot and took the fuse out and put two 5 amps in the " add a fuse" and then plug that in where the homelink fuse was.
      08-15-2011, 11:15 PM   #5
spdy330
spdy330's Avatar
Drives: 05 Tundra, 15 FIT, 17 CRV
This method worked great for me.
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
      08-17-2011, 11:15 PM   #6
tha_good_life
tha_good_life's Avatar
376
Drives: 21 X6MC
2021 BMW X6MC  [10.00]
2010 BMW M3  [8.68]
just did this mod tonight!
      08-18-2011, 08:20 PM   #7
Leo@AlpineMSS
Drives: M3
My prefered method as well.
      08-19-2011, 12:11 PM   #8
LateBraking
Thanks guys, I'm glad to see that the DIY has been of use to people. Makes having spent the time on it worth it.
      08-25-2011, 04:52 PM   #9
97X
Drives: 2020 F97 X3M Competition
Works on E93s too. I used the 5 amp fuse in slot #7.
I had wired my E90 328 the same way a few years ago. Interestingly, the torx head screw used for grounding was not present, so I ended up drilling a tiny hole in the metal support brace and used a small bolt/nut to attach the ground.
ON ORDER: 2023 G05 X5 ///M50i Carbonschwarz|Tartufo
CURRENT: 2020 F97 ///X3M Competition|Donington Grau|Tartufo
RETIRED: 2017 F80 ///M3 | 2014 F10 550i ED 2 June 2014 | 2011.75 E93 ///M3 ED 5 July 2011 | 2009 E90 328i
m3post
