ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      03-05-2011, 09:58 AM   #1
FOUR FLUSHER
FOUR FLUSHER's Avatar
Drives: 2013 328 Convertable
tire question?
I need to replace the rears on my new '06 Z4m ASAP, going with stock size,
the fronts are newish, Conitsport contacts, thinking about Hankooks to save a little $ in case I end up going to 19" in the future
Finally the question?
Any issues with mismatch fronts and rears?
Guy at tirerack said "no problem" since they'd be the same type tire
ps any general comments on the Conti's?
2013 328 VERT MSport Grey/Oyster 6MT
2013 Q5 3.0T S-Line white/black
      03-06-2011, 12:18 PM   #2
tman53
Drives: 2006 Interlagos M Coupe
That doesn't sound like a good idea to me. But, I guess if the handling characteristics are similar you may get away with it.
      03-06-2011, 12:24 PM   #3
Vertigo//SD
Vertigo//SD's Avatar
39
Drives: X1 xDrive28i (temporarily)
I've always heard that you shouldn't mix brands but never got a definitive answer as to why not. I'm a bit OCD so I would keep the same brand of tires.
      03-06-2011, 12:38 PM   #4
Skelekitty
Skelekitty's Avatar
42
Drives: '07 Imola Red Z4 MCoupe
2007 M Coupe  [10.00]
I swapped out my stock Contis last year for the Dunlop Direzza Star Specs and never EVER looked back (except to occasionally turn my nose up at the Contis). They're much better street tires than the stock Contis - stickier and not as hard. I'd bite the bullet and buy four new ones - all the same.
p.s. Finnegan will agree with me and then some. I think he's having a secret love affair with those tires.
~Krissi~ '07 Imola Red Z4 MCoupe
Eisenmann Sport Exhaust | RE X-Pipe | RE Transmission Mounts
      03-06-2011, 09:14 PM   #5
pokeybritches
pokeybritches's Avatar
Drives: ESS/G-Power Z4M, VF Z4, 996tt
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
It's not ideal, but I wouldn't throw away two perfectly good tires. I've mismatched tires numerous times. You'll probably use up the new rears before the fronts are worn. Get the Hankooks, accept the understeer, and replace all four next time around. If you don't like the results, replace the fronts sooner.
VF Engineering Z4 3.0i, ESS Z4M, G-Power Z4M, 996 Turbo
      03-07-2011, 08:33 PM   #6
santov
santov's Avatar
64
Drives: 2007 Z4 3.0si White over Beige
You could try it for a week and if you find the difference between the fronts/rears too great you could just replace the fronts.
I'm curious why nobody has tried BFGoodrich TW KDA2 as a cheap non-runflat. I had them on my Infiniti G35 and loved them. When my current runflats die I'll get them.
      03-07-2011, 09:08 PM   #7
Finnegan
Dog Listener
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Personally, I'd go with new rubber (Hankooks, or Star Specs) all around and try to sell the newer Contis to someone on the forum.
If that's not an option then what Pokey said.
      03-07-2011, 09:20 PM   #8
cmark8
M52, M62TU, S50US, S54, S65
cmark8's Avatar
75
Drives: E90 M3 6MT, E36 Touring MT
if you're just thinking about upgrading to 19", there's no reason to switch out all tires if the 2 front ones are still useable. But if you're planning to stick with your current wheels, go for yokohama advan ad08, it'll excel any other tire meant for street/track.
1995 E36 M3 USA / 2002 E46 M3 SMG / 2008 E90 M3 6MT
1996 E36 328i Touring 5MT / 1998 E36 323Ti M Sport 5MT
2002 E39 540i Protection
      04-09-2011, 05:28 PM   #9
davidoc
Drives: BMW Z4
Toyo Tires
I went with Toyo T1R tires after test riding several friends cars and the normal internet due diligence. Ride and road noise is a vast improvement over the OE Bridgestones. Since I changed over from run flats, I bought the ContiComfortKit from Tire Rack for confidence to keep in the trunk.
Price is higher than the Hankook, but those tires are real low end round bricks I don't think you would be happy with. Save them for your uncle's oldsmobile, not a vehicle like our Z4s.
Mainly I am really enjoying the improved handling with the Toyo's. Tires have tons of grip and are very predictable. When they do break away at extreme cornering, it is smooth and progressive, so recovery is easy. Haven't had a tank-slapper-on-four yet.
zpost
