03-01-2011, 05:03 PM | #2 | |
430
Rep 4,650
Remove OEM bolts from underneath the front bumper, apply 3M tape on the front lip and adhere to front bumper - make sure to test fit first. Screw in the OEM bolts and you're good to go ! Here's a pic for your reference |
03-01-2011, 05:10 PM | #3 |
Law Enforcer
25128
Rep 22,290
Drives: '22 Chalk Gray Porsche C2S
The lip is actually light enough that you don't even need the double-sided tape. Mine is attached without the use of the tape, and it's firm.
03-01-2011, 06:20 PM | #4 | |
Putcha ang ganda...
281
Rep 5,441
once you put the screw dont tighten them. screw each side and make sure they are loose and put the rest of the screws and once you have put all the screws (LOOSE) make your adjustment to make them fit perfect.... and tighten them one by one while someone is holding the lip to have the best fitment.
03-02-2011, 12:49 AM | #6 | |
Rep 6,094
Please be sure to install it with the 3M Double-Sided Tape! If you drive around with it just bolted at the OEM locations far back, front lip will move when the air pushes down on it at speed. Don't want to see anything happen to it. Hope this help |
03-02-2011, 02:58 PM | #7 |
Putcha ang ganda...
281
Rep 5,441
LOL just PMD the OP and said exact the same thing... cause i had a friend followed me and he said exact the same thing so i put so much 3M tape on my akrym and now its solid as a rock..
03-02-2011, 05:14 PM | #8 |
Law Enforcer
25128
Rep 22,290
Well I haven't noticed any adverse effects myself. I also check to make sure that it's secured properly on a daily basis. I purchased mine used, so it didn't have the double-sided tape attached.
03-02-2011, 05:19 PM | #9 | |
Putcha ang ganda...
281
Rep 5,441
apparently my friend was able to noticed when he was following me at 70-80 miles an hours that the lip looked like it was tilting and a bit flapping up and down. i dont know maybe its just me...
03-02-2011, 05:31 PM | #10 | |
Law Enforcer
25128
Rep 22,290
03-03-2011, 08:05 AM | #11 |
M-Flight Member
38
Rep 1,085
Also, be sure to use the 3M adhesıve prep stuff to ensure a long lastıng bond wıth.
2011 Le Mans Blue M3// Black extended Novillo w/ Blue Grey Aluminum trim/DCT/ZTP/ZCW/ZPP/ZCP Premium Sound ///Akrapovic Evolution Exhaust
2015 Audi S4 Prestige, Brilliant Black S-tronic 2012 Le Mans Blue 135i M Pkg DCT |
03-03-2011, 09:36 PM | #12 | |
Rep 561
Does the lip come with all the tape you need? I didn't open mine yet |
03-04-2011, 12:15 AM | #14 | ||
Rep 6,094
Hahaha ~ |
03-04-2011, 04:07 PM | #15 | |
Rep 561
Sent you a PM Eric.
03-04-2011, 04:09 PM | #16 |
Rep 561
anybody have a specific one to get(3m tape)? I went to Lowes and saw only one "double-sided duct tape" and it wasn't made by 3M. I did see "mounting" tape by 3M but it said it was permanent and removing it could cause damage. Any suggestions would be appreciated. Thanks.
03-04-2011, 04:19 PM | #17 |
Putcha ang ganda...
281
Rep 5,441
^ just get the 3M double sided tape from pepboys or autozone.... make sure its made from 3M... its red and black
this but get the FAT ONE..
03-04-2011, 04:24 PM | #18 |
Rep 561
03-04-2011, 06:14 PM | #19 | |
Law Enforcer
25128
Rep 22,290
You have no idea! |
03-14-2011, 01:24 PM | #20 |
Rep 112
I find that adding large washer to the pre-existing oem bolt (just stack it) spreads the force of contact adding more stability. of course this is in addition to the double sided tape.
03-30-2011, 10:58 PM | #22 | |
Rep 327
GL with the install. |
