02-15-2011, 04:58 PM | #1 |
BimmerPost Supporting Vendor
966
Rep 13,780
Recaro pp vs recaro sportster cs
Does anyone have know the weight of the pole positions and the sportster cs seats with all proper mounting hardware, I want to see what the difference in weight is with all hardware and seats ready to be mounted
Thanks for any help |
02-15-2011, 07:07 PM | #2 |
8232
Rep 18,829
Not much, you're looking at approx ~8lb difference.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
02-15-2011, 07:12 PM | #3 |
966
Rep 13,780
That's it? Because I know the seats alone-
Rpp are about 18 and the sportsters are 33, I know the sportsters don't use the side mount but I didNt realize it was only 8lbs, not bad Sportster make more sense then |
02-15-2011, 07:23 PM | #4 | |
8232
Rep 18,829
The Sportsters do not require a side mount as these are already built into the seat (steel mounts are heavy), which accounts for most of the difference. We are an authorized Recaro retailer, let me know if you have any questions.
02-16-2011, 05:47 AM | #5 |
Rep 148
you don´t have to use steel side mounts... you can use aluminium thus maximising wheight gains with the PP... however if you need the backseats the CS is obviously the way to go...
By the way Tom... is it possible to get a CS seat covered in the oem Bamboo Beige leather? |
02-16-2011, 10:17 AM | #6 |
966
Rep 13,780
which did you find more comfortable, which held you in better, i used to dd with rpp in my e46 and loved them but figured if there isnt much of a weight difference then why not get sportsters
02-16-2011, 11:06 AM | #8 |
966
Rep 13,780
The sportsters aren't? So does that mean I can't use the seats on the track? I don't track yet but plan on starting this year, any info is good
02-16-2011, 11:39 AM | #9 |
8232
Rep 18,829
As well as the side mounts, aluminum are not FIA cert - only steel versions from Recaro.
02-16-2011, 11:49 AM | #10 | ||
8232
Rep 18,829
Fixed back shells are best suited for track use. The Sporster CS seats are the same as the BMW performance seats (sans airbags), and better suited for everyday driving.
02-16-2011, 05:14 PM | #11 |
chris
278
Rep 12,144
if you need back seats then go for the CS... with recaro PPs, the back seat will be almost impossible to get into.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
01-16-2013, 06:39 PM | #13 |
Rep 2,792
I don't have an exact answer but it has to be at least 20 lbs. Tom said the Sportster CS is 33 pounds with brackets and the OEM is probably 60+ lbs. The E46 seats were 65 lbs with power, heat, and memory.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
dozaiya236.00 |
01-17-2013, 12:31 PM | #14 |
Rep 356
Recaro CS with bases, sliders and seat belt receiver are 39lbs each. I just threw mine on the scale.
...and they just happen to be for sale here: http://www.m3post.com/forums/showthread.php?t=780970 (shameless plug) -M |
01-20-2013, 10:48 AM | #15 |
Apex Everything!
976
Rep 4,378
Drives: 2007 Honda S2000, 2017 GT350
Do the sportster cs' provide more lateral support over OEM? I want lighter, more supportive seats for the track but I need to be able to add remove a child seat in the back when I'm not at the track. Any advice?
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com |
01-20-2013, 11:09 AM | #16 |
11817
Rep 23,187
this sir is why they invented the e90 m3.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
01-20-2013, 11:33 AM | #17 |
Rep 3,178
I found them to be a big improvement over the OEM seats, I'd probably attribute some of that to the Alcantara as well. Brief moments on the track of wanting more lateral support on very tight corners but otherwise no complaints.
///M3 | E90 LCI | Space Grey | Fox Red with CF Structure | 6MT | 260M | My build
01-30-2013, 05:40 PM | #18 |
Rep 2,792
Yes.
04-17-2013, 11:24 AM | #19 |
Rep 43
Hi everyone , quick question for anyone who knows. Do you know where I can get the seat railings for the recaro sportster cs to fit in the e92 m3? I've had these seats for about 2 months now and can't seem to locate these dam items so I'm stuck with the seats still in the boxes and not where it should be, in my car.
2012 Bmw M3 Aw
2012 landrover Evoque 2012 Acura Tl 2010 Mazda 3 |
04-17-2013, 11:33 AM | #20 | |
8232
Rep 18,829
03-12-2021, 08:42 PM | #22 |
Rep 1,096
7+ years thread revival: is the Recaro PP way better in terms of lateral support than CS? I got an e90 that is mostly daily driven (more so 2nd car than daily) but some track days. I want to change my seats. I'm about 5'9 175-80 lbs tops and pretty fit. Which one would y'all recommend? I also want to retain may seat heating functionality. Should I look in other brands? Thank you
2011 MR e90ZCP, 6-mt
2011.75 e90 M3 ZCP, DCT, ZP2, ZCV, JB w/ 2Toned FoxRed/Black Interior - SOLD |
