ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      02-10-2011, 10:34 AM   #1
santov
santov's Avatar
64
Drives: 2007 Z4 3.0si White over Beige
37F Dashboard Warning
For the past couple of mornings I get a beeping (which always makes me pucker), and a blinking +37F. Is it common for the temp sensors to go bad?
When pulling out of my garage I seem to get an accurate read, and in warmer weather it seems to work fine. So far it's only gone crazy during a chilly morning.
I'll get under the car this weekend and double check the connection. I think I remember seeing it under the front right fender, about 2 inches long.
Any help?
      02-10-2011, 10:49 AM   #2
MZHammer
MZHammer's Avatar
45
Drives: E85 Z4M, F82 M4
2016 M4  [0.00]
2006 BMW Z4M Roadster  [0.00]
I think that is just a cold weather warning beep. Someone on here can give you more specifics about how it works, but it is normal.
      02-10-2011, 10:55 AM   #3
santov
santov's Avatar
64
Ack! I should add it was around 55F, so I'm getting a bad temp reading. It definitely wasn't 37F out this morning.
      02-10-2011, 10:59 AM   #4
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
Normal, it's just an icy conditions warning. Most likely still cold from the night before and until it adjusts to the new surrounding temp it shows the ice warning.
The Raspinator
Gruppe M CAI / Euro Headers / Rogue Engineering X-pipe / RE Diablo Exhaust
      02-10-2011, 11:14 AM   #5
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
Are you sure?
http://www.weather.com/outlook/weath...day_2011-02-10
Nikki
      02-10-2011, 11:16 AM   #6
santov
santov's Avatar
64
Originally Posted by Nikki View Post
I was wearing shorts and a 2 t-shirts with the top down.
Maybe I'm getting a reading from the cold ground?
      02-10-2011, 11:18 AM   #7
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
Shorts? Wow you're one of those guys.
LOL jk maybe it just hadn't warmed up yet?
Nikki
      02-10-2011, 11:22 AM   #8
santov
santov's Avatar
64
Hahaha! Those guys as in Californian? Hmmmm? It did happen in the same area, but the ambient temp definitely wasn't below 50F. I won't drive with the top down if it's too cold.
      02-10-2011, 11:28 AM   #9
SCHMOUPE
SCHMOUPE's Avatar
Yikes -31 on the border. How do you even function at that temperature?
The Raspinator
      02-10-2011, 02:27 PM   #10
CFoote
Drives: '22 M5CS, '00 M5, '06 Z4M
2022 M5CS  [0.00]
2001 BMW 740i  [0.00]
2006 BMW M Roadster  [0.00]
2012 BMW X6 3.5i  [0.00]
2006 BMW 325xi  [0.00]
2017 BMW 540xi  [0.00]
2000 BMW M5  [0.00]
2001 BMW X5 4.4i  [0.00]
That's a great question...I'm tired of the winter here in CT, I can't imagine -31...
'22 M5CS, '06 Z4M, '01 X5 4.4i, '00 M5, '05 Acura RL, '12 X6 3.5, '01 740, 08 335xi, '17 540xi (yes they all are still with me)
      02-10-2011, 02:35 PM   #11
bhoch
SSGT USMC - '78 - '86
bhoch's Avatar
Drives: Z4 3.0si
2007 BMW Z4  [7.33]
Heck, I'm tired of the winter here in Texas. I don't even want to think about it being below zero degrees.
Thanks,
Bill
2007 3.0si Roadster Black/Red, sport, Piano Black F14 Forgestar's
      02-10-2011, 02:37 PM   #12
arggg45
Drives: fairly quickly.
You don't... Unless you're Bear Grylls or Inuit
      02-10-2011, 02:42 PM   #13
The HACK
Midlife Crises Racing Silent but Deadly Class
The HACK's Avatar
1821
Drives: 2006 MZ4C, 2021 Tesla Model 3
If the sensor is not connected or has a bad connection the default reaction/readout is to flash the 37º thing on the dash, so it is entirely possible that the sensor is intermittently faulty, or there's damage on the wires to cause it to short out intermittently.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
      02-10-2011, 02:57 PM   #14
pwrdbym
Drives: 06 Z4M Roadster
If it works normally and reads close to what the temp should be once you get moving, then I think you are dealing with some start up pains. It seems to take a min or so for the temp to stabilize in all of my cars, especially if they are in the garage. I would agree that being 10+ off is a fairly large margin, but if it doesn't stay that way I wouldn't worry.
11 BMW E93 M3-- 06 BMW Z4M Roadster
99 BMW M Coupe -- 85 BMW M635CSI
97 M3 Coupe (Track)--95 BMW M3 Coupe
91 BMW 850i 6MT--20 Ram 1500
16 Chevy Tahoe 4WD
      02-10-2011, 03:40 PM   #15
santov
santov's Avatar
64
Hahaha!
Does anybody have a diagram of the location and connector? I think I'll disconnect it and clean it.
-V
      02-10-2011, 03:47 PM   #16
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
Well, if it keeps on doing it, your temp sensor might be bad. Otherwise, what others have said. There seems to be a slight delay in the temperature reading sometimes.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
zpost
