02-05-2011, 02:03 AM | #1 |
Rep 1,110
m coupe front passenger hub
so i'm finally getting around to this thread. wont be getting home to the car until may anyways:
my front passenger hub was stripped out so bad i cant get a wheel bolt into it. i imagine it was the guy who painted the wheels because i havent had to personally take the wheels on or off since i got the car. this was discovered when i got my winter tires put on. and it wasnt them who did it, i was there when they put the tires on. i'll also buy a couple new wheel bolts since the one in the stripped location was in pretty rough shape also. looks like i can buy the hub for 213.06 off of tischer. 2 questions: 1.) anywhere i can get it cheaper for? part# 31222229501 2.) anyone ever do a removal and replace of this part? don't want to pay the stealership or any shop for that matter if it is not that hard of an install. Thank you, Dave
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 * '14 Jeep Grand Cherokee Overland Hemi... No more snow for the M! |
02-05-2011, 07:06 AM | #2 |
Rep 1,002
Drives: 2007 Z4 M Coupe 2012 e93 M3
I had the same problem with one of my front hub as well! Thankfully i was able to re-tap it. My next try would have been Heli-coil. I dont think it would be that bad to have just one or two bolts done (with Heli coils). Never done a wheel replacement on the Z4MC but i would imagine it is not that easy.
02-05-2011, 10:28 AM | #3 |
Rep 331
I buy parts from the Canadian equivalent of Auto Parts Way.... Here is the front hub from their U.S. website for $155
http://www.autopartsway.com/PartList.../pagenum1/tabS
02-06-2011, 07:40 AM | #4 | ||
Rep 1,110
Thanks for the input guys
2007 TiAg ///MCoupe
02-06-2011, 09:31 AM | #5 | |
Rep 331
Here it is, if you need it... http://forum.e46fanatics.com/showthread.php?t=610725
02-06-2011, 10:58 AM | #6 | |
Rep 1,110
one last noob question, just so i dont order the wrong thing. looking at the diagrams, obviously the rotor goes over the hub, but the hub itself is where the wheel bolt directly screws into?
2007 TiAg ///MCoupe
02-06-2011, 04:11 PM | #7 |
Rep 331
Yes, that is correct.
02-06-2011, 04:24 PM | #8 |
Rep 1,373
My brother had screwed up one of the holes in his hub and we just re-tapped it. Give the tapping a chance first then if that doesn't work try something else.
07 Z4 M Coupe AW/IR |
02-06-2011, 04:34 PM | #9 | |
Rep 331
With regards to heli-coils, you need to do some research on how much torque a heli-coil can handle. This is a common solution for stripped threads on low torque applications like spark plugs or even head bolts but I haven't heard of it being used on a wheel hub. It will be nice to know if it will work or not so let us know what you find out, if you do look into it.
02-07-2011, 03:23 AM | #10 | ||
Rep 1,110
thanks for all your help
2007 TiAg ///MCoupe
02-07-2011, 06:09 AM | #11 |
Rep 2,736
Well if its anything like the non M z4's then you will have to remove the steering knuckle and have the hub pushed out of the bearing, this may destroy the bearing when done so a new bearing will have to be pressed in then a new hub reinstalled its kind of like our audi totally sucky job. I wish it was like our mini which has a bolt on hub wayyyy easier to fix. Is try retapping it before anything else.
05-25-2011, 03:47 PM | #12 |
Rep 1,110
the hole is stripped too bad to tap. also, after further research, heli coils are not recommended for wheels. so a new hub it is. im going to order the hub thanks to quickid's recommendation
2007 TiAg ///MCoupe
05-26-2011, 09:11 AM | #14 | |
Rep 2,431
If you want to have a thrifty fix you can tap it to the size of an x5 lug nut. It's slightly thicker
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
05-26-2011, 10:02 AM | #15 | |
Rep 615
2013 Audi TT RS (Tech Pkg, Sport Exhaust, Heated Seats, Sirius)
Retired--2007 Z4 M Coupe (Imola Red/Black, Premium Pkg, Heated Seats, XM, Bimmian stubby antenna, CDV delete, Apex EC-7--Anthracite, Goodyear F1 Asymetric 2. |
06-02-2011, 03:30 PM | #16 | |
Rep 1,110
i already bought the hub though and i have my mechanic doing it for me on the side. correct it was one sealed unit, and didnt look too complicated but i had him take care of that while some warranty work needed to be done anyway.
2007 TiAg ///MCoupe
