02-03-2011, 07:52 PM | #1 |
Rep 97
Need Continuous Power
I need to be able to plug in an item that takes a regular wall outlet. I know they have cigarette adapters => wall adapters, however the M3 shuts off power to the whole car in about 10 minutes. I was wondering how I can directly tap the battery and create a wall unit so the item can draw power straight from the battery without getting turned off.
Thanks! OR Is there something like a big battery backup that has an internal battery that holds a holds a lot of power that I could place in my car which could be easier to do then tapping the cars battery? Something that is rechargeable that I could place in the car (like a battery backup) that includes a wall outlet plug on it... I don't know how long a battery backup will last Last edited by Drew1204; 02-03-2011 at 08:23 PM.. |
02-03-2011, 11:13 PM | #2 |
Rep 60
Depending the current draw required by what you are trying to run you really
only have a couple of options. 1) would be an enverter which plugs into the lighter port and then you would plug your 110v device into the enverter. With this it would require the car to be running. 2) A booster pak also sold as a jump start pak is a self contained power source with cables attached to jump auto batteries. They also have a 12v lighter port. They are a small self contained deep cell battery and I don't know how long you could run an enverter on it before the unit would need to be recharged. |
02-03-2011, 11:59 PM | #3 |
Rep 1,275
I'll bite....
So what are you trying to run continuously? It may help to disclose that to best refine the advice on how to proceed.
2022 M4 Competition ConvertibleDravit / Tartufo Full / Carbon Fiber Exterior...loaded
2020 X5:MW/Coffee Extended Merino, M Sport, B&W....loaded 2007 X3: Sapphire Black / Black loaded 6 speed Gone: M3 E93 Silverstone II over Bamboo |
02-04-2011, 11:02 AM | #6 |
Rep 803
Many of the inverters now also come with battery post clamps. Those should work if this is a once or occassional need. If you want it well intergrated and always available you'll probably want to find something more elegant than that.
Objects in mirror are slower than they appear.
02-04-2011, 01:55 PM | #7 |
Rep 117
Not Cheap, but looks like what you are thinking of?
Can use it to jump your car should your battery die, can recharge it at night, powers three outlets... Oh, and you can charge it from the plug in your car as well. Seems like what you are looking for.
2011.5 E92
Last edited by kibosh; 02-04-2011 at 01:58 PM.. Reason: newer version of the link |
02-04-2011, 05:15 PM | #8 |
Lurker
78
Rep 812
I bet you can find a 12V adapter for it that would be easier to set up.
It's probably got a standard 5V, 1A wall wart, possibly with a funky cable that I bet you could hack onto a standard auto/air adapter, which then just needs the plug chopped off and hardwired (with a fuse!) into a continuous power circuit on the car. I assume this camcorder has motion detection or compression to actually be able to store more video than you could normally shoot on one charge? If you want something more purpose-built they make game cameras folks set up to see what animals visit the watering hole at their ranch...they're usually even equipped with infrared/low light capability. |
