02-03-2011, 11:03 AM | #1 |
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Question on (fixed) Camber Plates?
First, is anyone here using them (especially non-M)? If so what brand did you go with? Did you see a change in front ride height?
Also what has been your long-term experience with them, assuming you're still on the stock suspension? Can the stock suspension handle increased negative camber from these plates over the long-term? I'm considering Rogue Engineering given it's low cost and their reputation for quality. I know UUC also makes a pair, but it's 2x the price and their shipping / ordering process is a nightmare. Plus for that much, I'd go with race adjustable plates. http://www.rogueengineering.com/rogu...es/CAMPLT.html |
02-03-2011, 11:16 AM | #2 | |
'Entwicklung 85 - Zukunft4'
26
Rep 238
Nonetheless, good luck |
02-03-2011, 11:20 AM | #3 | |
Rep 12,565
02-03-2011, 07:36 PM | #4 |
Rep 231
If you are ever going to get a coilover setup, I would suggest going with conventional camber plates since they will better integrate with a coilover. If you plan on keeping the oem type springs, and really want camber, then do this.
The thing is that camber is for combatting body roll at the tire, and normally people get stiffer springs and/or sway bars to combat body roll in addition. By getting these, you seem to be committing yourself against future coilovers. I know this is not what you asked, but I had to say it. My bad. Also, real camber plates get you more camber than these.
FS: Leather Recaro Pole Position Seats & Hardware |
02-03-2011, 08:28 PM | #5 |
Car Guy
31
Rep 796
Have you looked at Vorschlag?
http://www.apexraceparts.com/Vorshla...ches_p_73.html You can buy different perches for different springs so you're not boxed into a corner.....not fixed but adjustable.
02-03-2011, 08:51 PM | #6 | ||
Rep 12,565
Understood but truth is I'm pretty content with the oem setup and decided it might be best to stay that way while I'm still under the factory warranty. As I compete more maybe I'll then consider a nice set of coils but the need isn't quite there yet. And because I'm leaning towards stock suspension, I thought "real" plates would be too much, thus the reason I asked the effects of adding neg camber to an otherwise stock ride. Quote:
I'm aware of the Vorshlag plates and if I were looking to spend that much it'd be first on my list but this seemed like a good compromise between cost and value. Last edited by 3002 tii; 02-03-2011 at 08:58 PM.. |
02-03-2011, 09:27 PM | #7 |
Rep 341
Just picked mine up from the shop after getting a track alignment--neg 2.75 degrees without moving the tops of the struts, using just the E36 shim kit. Fits our cars, easy to install, cost just $25. And I'm running otherwise stock suspension and the OE wheels and Contis. Obviously, I haven't spent a ton of time with it yet, but my first impression is that it's a whole new car. Now, we'll see what it's appetite for tire is . . .
http://store.bimmerworld.com/e36-fro...-kit-p610.aspx Edit: Might need to confirm they'll fit on the non-M Z4. |
02-03-2011, 10:33 PM | #8 | |
Rep 12,565
02-03-2011, 11:27 PM | #9 |
Rep 231
Jaime or Gary at Bimmerworld can help you. I order E46 (non M3) stuff all the time and have no problems.
In fact, the new AST 4100 suspension on the way to me is for an E46 but will work. I did the same for the GC Race plates i got last year. No problems. Same for several things. ....If you change your mind on suspension, I am still driving on the Koni/GC coilovers that I will be selling soon. If you want to drive it and see, we can meet up. The rear ext. adj. shocks will brand new from Koni and I could install the whole setup for you at same time as installing my new setup for myself at the DIY shop in VA. Just an idea on the table. I found too much body roll on oem springs and even H&R springs. If you go your intended way, I would contact Bimmerworld and see what they can tell you about a suitable camber plate, perhaps one from the E46 non-M that would suit your desire. Good Luck
FS: Leather Recaro Pole Position Seats & Hardware Last edited by nlink720; 02-04-2011 at 11:22 AM.. Reason: addition (part dropped off from mobile device) |
