BMW M3 Forum (E90 E92)
      02-02-2011, 09:46 AM   #1
F82_SID
F82_SID's Avatar
Drives: 2020 M2C 6mt HK Silver
DIY help for vinyl wrap?
Hey guys I am trying to do something a little different with my car. I want to apply some type of glossy black vinyl wrap material to the vrs lip and inside / bottom of the two front side air intakes on the bumper. The point is to have the front center air intake gap still red but the rest of the stuff around it including the VRS lip glossy black. I know I probably should do this by painting it but I want something that is more easily reversible in case I dont like it.
Can anybody give me any suggestions or pointers as to where I could get the material and ease of install? Do you think this is something I should be able to do myself?
2011/E92/M3/MR/BB/ZCV/ZP2/EDC/2MT
      02-02-2011, 10:03 AM   #2
PKL
PKL's Avatar
848
Drives: 2020 M4, 2022 X6
Vinyl wrap the car yourself? I dont understand do you have any experience doing something like this? It doesnt sound like you do, I would never consider doing this myself.
      02-02-2011, 10:12 AM   #3
F82_SID
F82_SID's Avatar
Not the whole car, just the 6in or so on the inside rim of the front bumper.
      02-02-2011, 10:12 AM   #4
PKL
PKL's Avatar
848
I would still have someone else do it if its such a small area the labor shouldnt be that expensive
      02-02-2011, 12:19 PM   #5
1sikbmr
1sikbmr's Avatar
145
Drives: F80 M3 6MT
I dont see why you cant do it yourself... Are you a diy guy? All i can say is it really depends on the material you get... Do not buy precut sheets they never fit properly and when cutting make sure your lines are straight and even because uneven lines will cause it to peel at high speeds...
Now for the most part you are supposed to use a soap and water formula so that it doesnt stick right away... Then you heat it with a blow dryer if you dont have a heat gun to shrink it and dry the liquid out so it sticks...
Good luck
F80 ///M3 6MT Avus Blue ZCP
      02-02-2011, 09:29 PM   #6
MosesEMMMY
Drives: 09vert
if you have any skill and the right tools for trimming the vinyl you should be fine, oh and some patients for WHEN you mess up.
this is all i could find in gloss black. Plenty of matte black everywhere. this should give you more than enough to work with as well.
http://cgi.ebay.com/ebaymotors/3M-Gl...item41567fd4dd
Kris.
      02-03-2011, 01:12 PM   #7
Raptor251
ESS Dreaming
Raptor251's Avatar
Drives: 2011.5 e92 m3/Ford Raptor 6.2
Its worth a shot, I have played around with vinyl quite a bit and its very forgiving. If you dont like how something turns out peel it off and try again, its that simple.
      02-03-2011, 02:39 PM   #8
MikeSaso
Drives: 2007 E92
As long as you use a good quality vinyl you will be fine. Most 3M vinyl is designed with air release channels which make installation much easier. I’ve ordered vinyl from http://downshiftgraphics.com quick shipping and awesome products.
      02-26-2011, 10:38 PM   #9
emthreeboy
emthreeboy's Avatar
37
Drives: E92 M3 & E46 M3
A small area like that should be no biggie, but it will take time to get perfect. I remember seeing a video about a guy wrapping his hood somwhere. I'll see if I can find it again.
-09 e92 SPACE GRAY/// m3 w/ m-dct!
-06 E46 JET BLACK/// m3 6MT!
m3post
