XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > X5 Members Classifieds : For Sale / Wanted / Group Buys
      02-01-2011, 04:04 PM   #1
Cal@Sonic MS
Cal@Sonic MS's Avatar
Drives: bmw
♦ Sonic MS | RS Technik Ultra Lightweight Wheel Spacers + Bolts
None
Sonic Motorsports
1045 West El Camino Real
Mountain View, CA 94040
tel: 650-733-6506
fax: 650-691-9009
email: info@sonicms.net
Give your car an aggressive stance and fine tune its handling characteristics with RS Technik Wheel Spacers. Utilize wheel spacers to optimize your tire track width, improving lateral stability and grip. Additionally, spacers give your vehicle a more aggressive look, by filling out the fender gap generally associated with conservative stock wheel offsets and suspension setups. Each spacer is optimized for ultimate strength while maintaining the lightest possible weight. Made from T6-6061 aircraft grade aluminum and machine finished to absolute perfection. Each spacer is proudly made in the USA.
Pricing:
12mm - $135 shipped
15mm - $137.50 shipped
18mm - $139.99 shipped
*Price is for a set of two spacers and includes 10 extended lug bolts.
  • Made from 100% billet aircraft grade T6-6061 aluminum.
  • Finished to last. Anodized zinc coating ensures each spacer is resistant to corrosion, wear and provides a beautiful fit and finish.
  • Stuck spacers are a thing of the past. Each spacer features a chamfered inside edge that allows easy removal using a standard flat head screw driver.
  • Designed and manufactured specifically for your vehicle. Hub-centric design means you get a safe and perfectly fitting spacer.
  • Includes matching corrosion resistant wheel bolts. Each bolt is made specific to match your selected spacer size.
  • Made in the USA.
For ordering information, please call me at 650.733.6506, email at cal@sonicms.net or shoot me a PM.
      02-01-2011, 05:02 PM   #2
icenutz
Drives: 2011 X5
wow those are really nice!! I think I will have to order a set of those soon!!! Hopefully by April the snow will cease here!?!!?
      02-01-2011, 08:54 PM   #3
Cal@Sonic MS
Drives: bmw
Let's hope so.
Let me know when you need a set, I'll be here
      04-01-2011, 02:14 PM   #4
Cal@Sonic MS
Drives: bmw
      05-06-2011, 12:30 AM   #5
mach330
You don't know JACK!!!
mach330's Avatar
43
Drives: 2011 X5 35i
which ones do i need to fit an x5 ///m wheel on my x5 35i?
Rated /// M
      05-06-2011, 12:26 PM   #6
Cal@Sonic MS
Drives: bmw
In order to do that, you'll need to get hubcentric ring adapters from 74.1mm to 72.6mm. I believe the E70 X5M uses different centerbores for the front/rear wheels.
      05-27-2011, 12:21 AM   #7
DNGRTOM
Drives: F90, G05 M50i, 991.1 TTS
what sizes would you recommend on an x6 50i with 336's if i just wanted to bring the wheel flush with the fenders?
      05-27-2011, 12:17 PM   #8
Cal@Sonic MS
Drives: bmw
I would recommend 15mm front and 18mm rear.
xbimmers
