11-09-2010, 06:45 PM | #1 |
Rep 180
eibach pro kit with FSDs pic
Just installed the eibach prokit with the koni FSDs....
Here my impression... Dropped more then I though on the fronts. Rears sit ok I'm happy with it... The ride is firmer then stock, bumps are not harsh but I do get a lot more noise when I hit pot holes or bumps.. probably due to the RFTs (gonna go non RFTs after these wear out) I also change the bumper stops to the e36 bumper stop instead of cutting the stock ones... I have the Dinan rear upper shock mount on order (I guess its on backorder cause I been waiting for 3 weeks.. anyone else waiting for that part?) handling is way better then stock, I can take corner at a greater speed then when it was stock. Feel more stable... next up would be the m3 front sway bar... pics of the setup |
11-09-2010, 06:50 PM | #2 |
Rep 2,233
That's what I run on my 128 with non-runflats and I just added the M3 front swaybar this weekend. My drop is pretty dead even front to back and I describe the ride as very compliant. But then my last car was a lowered Cooper S.
11-09-2010, 07:01 PM | #4 |
Rep 180
11-09-2010, 07:08 PM | #5 |
Rep 2,233
11-09-2010, 10:10 PM | #7 |
Rep 627
From the pictures I've seen, the eibach springs on a 135 result in a slightly raked stance (front lower than rear). The 128 on eibachs looks like equal wheel gap front and rear.
Black is a 128, White is a 135. You tell me if the difference is noticeable.
E46 M3
11-09-2010, 10:41 PM | #9 |
Rep 627
i believe eibach uses the same part number for both cars. not impressed by that.
not a fan of rake or fenders sitting right on top of tires. that why i went with bmw performance suspension. greater drop in the rear to eliminate the slight factory rake. even stance, 1/2" drop, love it.
E46 M3
11-09-2010, 10:48 PM | #10 |
Rep 7,408
above black car is my 128i, as of right now the spring has settled.
by their data, front and rear have same drop rate, but as to me, front seems more dropped than rear. (Probably 1 series rear have higher sitting than front maybe) Another reason it looks even is because it could be the ground issue, my driveway isn't 100% flat. So dont judge by the photo. |
11-09-2010, 11:00 PM | #11 |
Rep 180
11-09-2010, 11:01 PM | #12 | |
Rep 180
11-09-2010, 11:02 PM | #13 |
Rep 627
thanks for the follow-up e90sexion.
you should post some pics of the car now on a flat surface. ive seen several other pictures of 128's on eibachs, and as ulrichd reports, the drop is about even.
E46 M3
11-09-2010, 11:06 PM | #14 | |
Rep 627
http://www.1addicts.com/forums/showthread.php?t=412549 These pictures and seeing another member's car in person sold me on the BMW performance springs.
E46 M3
11-10-2010, 12:12 AM | #15 | |
Rep 180
11-10-2010, 12:36 AM | #16 |
Rep 2,757
Drives: 2017 Audi A4
Any comparison pics between this setup and FSD's with H&R OE Sport Springs? Those seem to boast around .7" F .5" R drops.
11-10-2010, 11:07 AM | #17 |
Rep 180
11-24-2010, 03:40 PM | #18 |
Rep 31
hay guys new to here but have ordered the eibact pro kit springs for my 1 coupe but its a 123d and i see you say about the weight and i am worried about getting the rake look because i dont want that look! do you think it be has heavy like in the white 135 because dont want that look atall thanks ??
11-24-2010, 03:59 PM | #19 |
Rep 7,408
I doubt you will have that look.
I seriously think the white one rear hasn't settled or ground issue *not flat or tires sizes. I have 225 in the front now, and the drop on the front looks more lower than I had 215 in the front. |
11-24-2010, 09:42 PM | #20 |
Rep 2,757
Eibachs will be about 1/4" or so lower in the front, and they are lower than the BMW perf suspension or H&R oem sports.
11-24-2010, 10:31 PM | #21 |
Rep 177
With the eibach pro-kit spring, my 130i has a similar stance to the white 135i above. Front is too low and rear too high. Interestingly, the same spring (same parts number) fitted on 323i and 325i gives an even ride height front to rear.
For the record, the same set of eibach pro-kit spring (you can check parts number on their site) are used for most 1-series and 3-series (even the convertible). Given the different total weight and different weight distribution, the resulting ride height will differ on different model. These spring are not designed for 1-series (at least that's what I believe, why would you fit a spring that could take the weight of E93 rear axle and fit it on 1-series? which weight far less?), they just happens to fit, there is no engineering involved. And as such, I will never, never buy any eibach product again. Last edited by Kubricks; 11-25-2010 at 02:30 AM.. |
11-25-2010, 04:17 AM | #22 | |
Rep 2,757
