10-12-2010, 12:41 AM | #1 |
Rep 1,149
Feeler: WTT Active Autowerke E9X M3 Signature Exhaust
Just bored...want something diff. Will trade + cash for Akra. Or make me a reasonable offer This is a recent pic. Please note the in following vid the AA exhaust is paired with a gintani catless x-pipe: And here is a vid my friend made this is just the aa rear section: http://www.m3post.com/forums/showthread.php?t=378251 http://store.activeautowerke.com/act...xhaust-p5.aspx True performance, durability, and attractive weight advantages with innovative features places the Active Autowerke E9X BMW M3 exhaust in a class of its own. This system is constructed from 100% polished 304-stainless steel and features adjustable Active Autowerke double walled tips, making it ideal both for 2-door and 4-door models (also allows for cleaner fitment with diffusers). This system uses factory style flanges making it a complete bolt on system that requires no cutting or welding. The system is a straight-through design providing substantial improvements to gas flow over the factory exhaust. The sound is unobtrusive, with a rich mellow tone and delivers a solid 15+hp, with key gains in the mid-range. In addition, the Active Autowerke E9X M3 Signature Exhaust system features large 3" piping for maximum exhaust flow while maintaining enough back-pressure to result in horsepower increases across the entire RPM range. The factory E9X M3 muffler features a Noise Canceling Chamber inside the muffler and Active Autowerke has retained this feature by adding two custom Active Autowerke noise canceling chambers (NCC)on each muffler to reduce/eliminate all drone (the 'booming' noise some muffler emit at cruising speeds, ~3500 rpm). The Active Autowerke E9X M3 Signature Exhaust System provides increase in horsepower, great sound and appearance making it a must for the true M3 enthusiasts. Key Features: -Large 3-inch mandrel bent piping for maximum flow -Durable, polished 100% 304 stainless steel -Double-walled 76mm Signature stainless tips -Revolutionary NCC -Noise Cancelling Chamber -Adjustable Tips with Embossed Active Autowerke Logo -Improved power & torque throughout entire RPM band -Gains of 12-15 HP over stock configuration; Additional HP with our programmed software -BMW factory style hardware makes a truly easy installation with no need for cutting or re-welding -Weighs 44 Lbs vs. the factory of 78 Lbs. -Fitment for Coupe,Convertible and Sedans -Complete illustrated instruction manual -Two year warranty Last edited by baarii; 10-18-2010 at 05:18 PM.. |
10-14-2010, 08:08 AM | #7 |
35
Rep 543
10-18-2010, 10:16 AM | #8 |
Rep 1,149
