09-01-2010, 02:42 AM | #1 |
Rep 7,408
Navigating drops on eibach spring
it clearly states it drops all around 1.2" for our car application,
looking at the drops are all varies............why's that??? I am installing my eibach/koni combo next week or so... I just dont want to be surprised with the outcome.... |
09-01-2010, 05:29 AM | #2 |
Rep 2,474
I think it will depend on the shock and if people have camber plates or not. As with any product, there is always a margin for error. but I would doubt it would be anymore than +-.2 inches. I had them on my car at one point. Didnt drop it too much.
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks! |
09-01-2010, 07:15 PM | #3 |
Rep 150
OT: i think i've read somewhere you are from Surrey. Where are you getting them installed? Are you getting an alignment right away?
09-01-2010, 07:37 PM | #4 | |
Rep 627
I'd like to retain the factory stance. It scares me a bit to pay for the install and wind up with an uneven or unexpected drop. I'm wondering as well if reusing the factory bumpstops is appropriate and if it has an effect on final height. Suspension experts? |
09-01-2010, 08:49 PM | #5 | |
Rep 2,474
09-01-2010, 09:58 PM | #6 |
Rep 2,757
Drives: 2017 Audi A4
It was my impression that most people removed the bumpy stoppers when moving to aftermarket springs n shocks...
09-01-2010, 10:26 PM | #7 |
Rep 627
ah, i think I have a better understanding of the bump stops now. It seems they are hard pieces of rubber that sit on the shock's piston rod. They prevent the shock from bottoming out (complete spring compression) by absorbing more energy than the spring can at the end of the travel (hence the term 'auxiliary spring'). By reducing the height of the bump stop, you allow the spring to travel more before bump stop absorbs energy. it probably doesn't feel very good when you hit a bump stop. although, better than bottoming out im sure.
Am I catching on? I can see now how this has no effect on ride height.
E46 M3
09-02-2010, 04:43 AM | #8 | |
Rep 2,474
09-02-2010, 05:01 AM | #9 |
Rep 7,408
09-03-2010, 04:27 PM | #10 |
Rep 345
I think one of the reasons there are folks reporting different drops is that they are supposed to lower non-sport cars 1.2" lower than stock....but if you have factory sport suspension which is about .5" lower than non sport it will only drop it about .75". (at least that is how it was with my 535i, the same spring lowers the non-sport more from stock than the sport cars but the overall drop ends up being the same)
'09 135i - Step - Sport - M.Blue - JB3 - Eibach Drop -Alufelgen SF-71 for 1 Series
'08 535i - Step - Sport - JB3 - BMS Air Filter - HKS BOV/Pipe - Aquamist water/meth injection - EuroLights Yellow ION Foglight Bulbs - |
09-03-2010, 04:45 PM | #11 | |
Rep 627
So if eibach states 1.2", you would think that every 135i lowered on eibach springs would see approx. 1.2" (+/- .1") after the springs have had time to settle. We are seeing greater variances than that. Of course, measurement technique may have something to do with these variances as well.
E46 M3
09-03-2010, 04:57 PM | #12 | |
Rep 293
Drives: '21 M2C 6MT, '21 Charger Scat
128i withOUT sport/Msport are ~0.5in higher. The Eibach springs fit both cars and are probably rated at the non-sport height of the 128i. (Marketing BS) My best guess (as I don't have these)..... 128i non-sport 1.2" drop 128i sport/MSport 0.75" drop 135i all cars 0.75" drop |
09-03-2010, 05:10 PM | #13 | |
Rep 345
Eibach uses the same part number - 2097.140 - for 128i non sport, 128 sport, and 135i. It will definitely lower a non-sport more from stock than a sport.
09-03-2010, 05:11 PM | #14 |
Rep 345
+1...
09-09-2010, 06:11 PM | #15 |
Rep 1,334
I was on the newer 2011 135i Sport Suspension (which uses linear springs now rather than the former progressive ones) and the car was actually .2 inches, or so, lower than 2010s and earlier sports suspensions. Here is my eibach, spring only, setup with 18s on 40 rubber...It's a touch lower than I'd like..maybe I need to go to 35s.
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
