XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
Register FAQ Calendar Today's Posts
      08-02-2010, 06:05 PM   #1
mozdal
mozdal's Avatar
Turkey
19
Drives: E84 & F20 & F10
DIY: Kidney Grille Removal and Custom Silver Painted 23d Kidney Grilles :)
Hello everyone,
This weekend I was working on changing my kidney grilles to 23d ones. Since the original parts are 66 Euros in dealer and a lot more for installation i thought that I can do it myself. And since the operation was successful i wanted to share my experiences with you.
Tools needed:
Torx T30
Silver Metallic Spray Paint
Spray Varnish
There are two ways to remove the grilles. 1st is to remove the bumper and 2nd is my way
There are 4 T30 screws that holds bumper. Those have to be removed.
After that, if your car is equipped with the headlight washers, you also have to remove the covers of the nozzles. You have to be very careful while removing the covers. Nozzles have to be pulled straight up, or else there is a great possibility that you might brake them. Just pull straight, remove the covers without moving nozzles up and down, and slowly leave the nozzle to its original place again without moving up and down. If you get help from someone at this stage, it should be much more easier.
Nozzle covers removed:
After that, you can stretch the bumper from upper side and release the 3 latches with the help of a screwdriver.
After that you have to release the latch on the outer side. (Near the headlight).
At this point you again have to be careful not to screw the paint of the bumper. The reason is that, that latch can only be removed with the help of a long screwdriver. As you can see in the picture, the latch is right behind the rubber where it has a curve because I've loosened it. You can also see what I've done to the bumper paint No worries, the other side was perfect, just be careful
After that you can loosen the grille since it is half removed and release the other latches with hand. You might think that it might get broken bot no worries, bumper is so elastic Just be careful not to hurt your hand.
The grilles are removed, now it comes to paint them. To paint the them, it is better to remove the chrome lining from the grilles. You can also secure them with blue tape.
You may have difficulty releasing the latches of the chrome lining since there are too many and they are very tight. I come up with an idea. I insert screws to latches so they didn't snap in again when loosening others.
Then paint the grille with the spray paint. Apply 3-4 thin layers. If you wait 10-15 minutes between each layer it will be better. 3-4 thin layers are better than one thick layer. Before starting paint job don' forget to wash and clean the grilles carefully.
And lastly you have to carefully insert the chrome lining back. While doing this do not completely snap-in one side or you'll be in trouble. Try to equally snap-in from both sides.
And here is the final product.
Hope that helps!!!
      08-02-2010, 06:29 PM   #2
Zirenz2006
Zirenz2006's Avatar
Drives: G80 M3 Comp IOMG
Looks good!
Current: 2021 ///M3 Competition Isle of Man Green
Ordered: 2024 ///M2 Zandvoort Blue
Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i
      08-03-2010, 07:54 AM   #3
STE92VE
STEVIL Empire
STE92VE's Avatar
Drives: Fast
Good write up!
Are the roads in Turkey that bad or do you do lots of off-roading? Your engine compartment looks like you just completed the Dakar Rally!
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD)
2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD)
      08-03-2010, 02:45 PM   #4
mozdal
mozdal's Avatar
Turkey
19
Originally Posted by STE92VE View Post
Good write up!
The dirt is not because of the roads The neighborhood is dusty because of the climate, I used the car several times off-road one was completely on mud and haven't touched the engine compartment since I bought the car in november.
By the way I washed the car myself today after reading your post I spent 2 hours just for the exterior. Tomorrow I'll do the interior and the engine
      08-03-2010, 05:14 PM   #5
superX1muts
Netherlands
Drives: BMX X1 xDrive23
Hi THats simpler then I expected. Good work! I Think the Marakesh brown is the nicest color but a little dark. With extra silber like accents the color is even more beautifull.
For the lack of silber on the 'smaller'engines I decided to order the 23D
      08-07-2010, 10:34 AM   #6
Park2670
Park2670's Avatar
Drives: Tesla Model 3
Im starting to really like the look of these. Hope we get them in the US sometime soon
      08-07-2010, 07:12 PM   #7
Nash
Drives: X1 xdrive 2.0d
Amazed at your ingenuity. Well done because it looks good! And yeh, there's a lot of dust around in your neck of the woods. Does it get into the interior of the car?
Nash
      08-10-2010, 04:47 AM   #8
mozdal
mozdal's Avatar
Turkey
19
Nash
Thanks Nash I was so obsessed with removing grilles, luckily everything went well And no, there is no dust in interior. I'm hoping that someone will write up a how to clean your engine compartment DIY
      08-10-2010, 06:20 AM   #9
mario486
Mario
mario486's Avatar
Scotland
26
Drives: X1 XDrive 2.0d, Mini Cooper
Originally Posted by mozdal View Post
Thanks Nash .....I'm hoping that someone will write up a how to clean your engine compartment DIY
Actually quite easy, something I do as I tend to hyper-clean (detail-ish) my cars. The are a number of products on the market that go some way to helping you clean out an engine bay. Not sure if you can get them in Turkey (my brother lives in Istanbul and always complains about how difficult it is to source things) but the engine cleaners made by Meguiars and AutoGlym are very good. You can normally just use the water from a hose with the cleaners but they do work better if coupled with a steam cleaner. I have a Karcher that I use around the house that works very well.
      10-20-2010, 12:47 PM   #10
meric88
Drives: e92
Tek kelimeyle muthis. Ellerine saglik
      10-21-2010, 04:57 PM   #11
mozdal
mozdal's Avatar
Turkey
19
Sağol kanka: Thanks pal
      12-05-2010, 02:37 PM   #12
BIMMER UK 76
BIMMER UK 76's Avatar
Drives: BMW F25 X3 20d SE
Looks like you did a good job and the grille looks much better now
Did your dealer quote a fitted price?
BMW F25 X3 xDRIVE 20d SE
Black Sapphire | Oyster Leather | Fineline Sienna Wood | 307 V Spokes | Auto | Prof Multimedia Package | xLine Package | Xenons | Business Radio | Sports Steering Wheel | Sports Seats | Panoramic Sunroof | Sun Protection Glass | Sun Blinds | Folding Ext. Mirrors + Titanium Grille | Chrome Exhaust Trim | Mudflaps
      12-08-2010, 02:15 PM   #13
mozdal
mozdal's Avatar
Turkey
19
The grille itself was 66 Euros, didn't even bother to ask for the labour Dealer removes the bumper to change the grilles.
      12-11-2010, 04:06 AM   #14
jaxxsson
A man's reflection
Belgium
Drives: BMW X1
I asked my dealer to install the silver grills on delivery, the cost was only 70€ so I think it is not worth for doing yourself risk to damage something and all those things
      05-22-2011, 10:01 AM   #15
BIMMER UK 76
[QUOTE=jaxxsson;8481349]I asked my dealer to install the silver grills on delivery, the cost was only 70
      04-11-2012, 07:22 AM   #16
technostar
looks really really nice with those silver painted grills
      04-12-2012, 07:33 AM   #17
danintas
Australia
11
Drives: 2015 BMW X3 30d Xline
I have a 23d with silver grills ... but I would like to change them to black!!!
      05-07-2012, 06:31 PM   #18
Tim_78
Duke
Tim_78's Avatar
Drives: F30
Guzel bir DIY.
Long Gone: 2004 E46 325i - 2006 E90 325i
Current: 2014 F30 328i Mineral Gray Ext.- Saddle Brown Int
      09-08-2012, 10:07 PM   #19
Neraky71
Drives: Future X1 owner
Is that a sparkling bronze or merrakash brown color?
      10-09-2012, 12:50 PM   #20
ozanerbektas
ozanerbektas's Avatar
Turkey
Drives: BMW X1 2.0d xDrive
My work!
Hello everyone.
I luckyly found out this topic. Similar to the work above, i have done the same thing to my lovely BMW X1 and almost every single person who saw it, loved it.
Its the same process. After removing four screws on top of the bumper, i relased the 8-9 clips that hold the kidney grill. And then i started to do it myself.
So that is the result. I uploaded the photos of it. It has been 3-4 months since this application. And there was no peel off or anykind, still same lovely bright colors, still same lovely looking.
I just wanted to show you all guys. I hope you'll like it as well.
Thank you.
      12-04-2013, 05:38 PM   #21
Yarvis
Yarvis's Avatar
11
Drives: 2024 BMW X3 SDrive 30i
Hello everyone,
Tools needed:
Torx T30
Spray Varnish
Hope that helps!!!
Great write up and pics. I have asked here and elsewhere if those covers for the headlight washers have to come off and you answered the question in your DIY. But I'm still a bit confused as to how you take those covers off and NOT break the lines or whatever for the washers?
"Life is what happens to you while you're busy making other plans"......John Lennon
      12-11-2013, 10:12 AM   #22
Teutonic
Teutonic's Avatar
It is easy: just lift them with your fingers (they are a little bit tight) and remove them. They have two small holes, once you lift them up with your fingers you will see what to do.
xbimmers
