      07-14-2010, 11:11 PM   #1
jaf89f
Drives: 2008 128i
Clicking noise when I initially press the gas pedal and also when I release it
Hey, I was hoping someone around here could help me out. When I press the gas pedal, probably about 1/3 throttle or more, I hear two clicking sounds then when I release the pedal I hear another clicking sound.... Is the sound from something engaging and disengaging because I have a manual...or is it something worth taking the car in for? Thanks.
      07-14-2010, 11:16 PM   #2
B_2_B_P
B_2_B_P's Avatar
Germany
18
Drives: 128i Sport /w PDC and ComAcc
2009 128i  [0.00]
Do you have any mods?
Black Badge - Hankook Ventus V12 evo K110 18" - ASA AR1 18" - B&M Short Shifter - aFe Stage 2 CAI Pro 5 R - Gloss Black Kidney Grills - Performance Pedal Kit - CDV delete - Custom Tint - Bastuck Exhaust w/o Silencer - Custom Tune
      07-14-2010, 11:45 PM   #3
jaf89f
Drives: 2008 128i
nope not a single mod
      07-14-2010, 11:49 PM   #4
jaf89f
Drives: 2008 128i
Just to clarify...I push the throttle in about 1/3 or more and the two clicking sounds happen...I release the throttle and I hear one clicking sound....then I switch gears and when I push on the throttle again I hear the clicks again. The clicking sound is loudest when I am in 2nd gear and I push the throttle down and release it relatively quickly. Just wondering if this is normal because that's what the dealer told me.
      07-15-2010, 12:33 AM   #5
jksgoh
jksgoh's Avatar
Australia
141
Drives: M2
2008 E82 125i  [0.00]
i know exactly the sound you are talking about. I get it as well, and is substantially more noticeable in enclosed environments, e.g. an underground car park or tunnel.
I always assumed it was the throttle body??? but i could be totally wrong.
did the dealer tell you the cause of the sound?? or just said it was normal?
      07-15-2010, 12:54 AM   #6
jaf89f
Drives: 2008 128i
they told me it was just normal...just weird that a loud clicking sound is normal. I have never noticed this on any other manual car before.
      07-15-2010, 01:45 AM   #7
B_2_B_P
B_2_B_P's Avatar
Germany
18
2009 128i  [0.00]
Sounds like throttle body, but thats a weird sound. I mean I can hear mine but I have an after market intake and it's an awesome sound when I press the pedal...not clicking. How long has it been doing it. Did something happen and this sound started afterwards? Maybe excessive aggresive driving =P.
      07-15-2010, 02:02 AM   #8
jksgoh
jksgoh's Avatar
Australia
141
Drives: M2
The noise in my own car has pretty much been there since delivery.
I must admit i only notice mine in enclosed spaces and mostly when i quickly let go of the accelerator, with normal outside driving i dont notice it unless i am driving next to a wall.
      07-15-2010, 04:06 AM   #9
Stealth135i
Turbo Lover
Stealth135i's Avatar
South Africa
17
Drives: N55 135i 2010
I've noticed this as well, but im pretty sure its just the valve in the exhaust opening and closing.... Havent tried the golf tee mod to see if the noise stops as the valve will stay open.. But that's my assumption..
Black Sapphire 2011 135i MT6 (Comfort Access, Professional Nav, Heated Seats, Performance Steering Wheel, Performance Shift Knob and boot, and more )
      07-15-2010, 10:16 AM   #10
Trowa
Jack Bauer
Drives: 2019 330i xDrive, 2016 S1000RR
I've noticed this as well. I'm taking my car in for first service next week. I'll ask them to look into it .
      07-15-2010, 10:35 AM   #11
B_2_B_P
B_2_B_P's Avatar
Germany
18
2009 128i  [0.00]
BTW the valve in the exhaust only opens when above 3krpm and closes when you go below that.
      07-15-2010, 10:41 AM   #12
jaf89f
Drives: 2008 128i
I notice it more in enclosed spaces, but I can still here it otherwise. And I can hear it when below 3krpms. And yes, I hear it more when I quickly press or release the accelerator.
      07-15-2010, 02:07 PM   #13
Last NA 6
Drives: 2009 128i
It stopped on mine when I replaced the muffler, so I assume it was the valve on there opening and closing.
      07-15-2010, 04:53 PM   #14
Evice
Evice's Avatar
194
Drives: E92M3
I am pretty sure that you are hearing the golf tee thingy in the exhaust which kicks in around 2.5-3k RPM and changes the exhaust note. Now I am not sure why 2 clicks when you step on the gas, because mine is single click all the time.
      07-15-2010, 06:25 PM   #15
jksgoh
jksgoh's Avatar
Australia
141
Drives: M2
as the OP said he hears it below the 3krpm mark, and so do i, which is not really in keeping with the exhaust flap.
also my noise also seems to come more from the engine bay, or at least the front half of the car.
      07-15-2010, 08:57 PM   #16
jaf89f
Drives: 2008 128i
Yeah, I feel as though the sound is coming from the front as well.
      07-17-2010, 12:25 AM   #17
supraking
supraking's Avatar
49
Drives: 128i Coupe 6MT
2009 128i Coupe  [0.00]
It's most likely your exhaust flap. Had the same "issue." Took my car to BMW, they changed my entire exhaust system. Same thing started happening again.
Get yourself a twist tie, and crimp and tie off the vacuum hose connected to your exhaust pipe. This is equivalent to the exhaust tee mod, removes the clicking, and makes your car growl more at lower RPM
Remember not to work on your car after it's been running (exhaust gets HOT). I recommend having a friend start your car cold while you look into the left exhaust pipe. You'll see the flap close. Turn off the car (the flap is open when off), perform the mod, and then start it up again. If done correctly, it should not close this time. You can remove the tie at any point in the future, it won't harm your car in any way.
      07-17-2010, 04:35 AM   #18
socaltuner
Mod-raider
Drives: Murrrrrrrrd out space ship
you would have been better off with a ford.
      07-17-2010, 09:32 AM   #19
jksgoh
jksgoh's Avatar
Australia
141
Drives: M2
Hmm if it is the exhaust flaps why are the op and I both hearing it from the front? (I assume this flap is quite far back as you can see it throgh the end of the pipes)
      07-19-2010, 11:39 AM   #20
supraking
supraking's Avatar
49
When you're listening outside your window(s) while driving you may not be able to pinpoint the exact location of the sound. I didn't know where it was coming from either at first (front, back, etc.) but it did sound louder on the left side. It's only when I did some research online that I figured out it was probably the exhaust flap.
Try the twist-tie mod, it takes about 3 minutes and you can remove it if it isn't in fact the exhaust flap.
      07-20-2010, 01:01 PM   #21
lib
lib's Avatar
141
Drives: <This space for rent>
I have the same sound. It isn't the exhaust flap. If it was, it would stop when you unplug the vacuum line that drives the 2-stage flap.
My SA replaced my muffler thinking there may have been a problem with the flap but that didn't change anything.
      07-25-2010, 10:12 PM   #22
supraking
supraking's Avatar
49
As I said, so did mine, and the sound was still there. I tied off the vacuum (or you can unplug it if you'd like) and it stopped.
Are you saying that you unplugged the vacuum line and it had no effect on the noise? Wasn't explicitly stated in your post, just want to clarify.
1addicts
