07-10-2010, 01:49 PM | #1 |
Rep 2,138
Drives: Me
Found an issue with my Cool Carbon Brake Pads
Installed my alarm today. While under the car, I noticed that the left rear inner pad was not right. It seems that the backing plate that is riveted to the pad got all fubar...
Pulled the caliper off. Cleaned everything off and removed the backing plate. Regreased everything and put it back on, minus the backing plate. We will see how this holds up. First image is the pad with the issue. Second image is a good pad on the right side, rear. Third image is the pad off the car. |
07-10-2010, 08:16 PM | #3 |
Rep 11,667
Thanks Ship, I'll keep an eye on mine.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
07-11-2010, 07:40 PM | #4 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
So is the backing plate loose and shifted? Darn that could be really bad.
[URL=http://imageshack.us/photo/my-images/153/071jt.jpg/]
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings |
07-12-2010, 01:39 PM | #5 |
256
Rep 4,048
This is not the backing plate that has shifted but only the anti-noise shim. As stainless steel is used, this shim also provides a heat barrier that is roughly 3X that of a conventional steel shim. The CC shim version is both staked on in 2 places and additionally bonded on. The final bonding takes place with the heat generated during the bedding process. The shim coming loose is not a usual occurrence, but can happen rarely on any manufacturers product.
This is by no means a safety concern but it can be a nuisance. Each time the brakes are applied, there is always a slight rotational force between the piston and the brake pad/Shim interface. It appears that there may not have been noise coating or caliper grease applied to the piston contact surface (as recommended) which would minimize the rotational forces between the surfaces during the final bonding process. Please PM me and we can discuss further. |
07-12-2010, 04:53 PM | #6 | |
Rep 2,138
Drives: Me
Thanks for the quick update. |
07-12-2010, 05:47 PM | #7 |
256
Rep 4,048
Sure thing. Let me know if everything works out in the future w/ those pads
