01-19-2010, 01:04 AM | #1 |
Rep 403
shifting with DCT, whats the proper way?
i know, this question is not as dumb as you guys might think, but i was told by a friend of mine that when shifting the gear knob from R -> N -> D i should pause for 3 second from R -> N then another 3 second N -> D because the car that click sound when the gear is engaging, and that failure to do so would fuck up the transition, is this true? i honestly thought it was the dumbest thing i have ever heard, but i thought I'd check with you guy for confirmation. since when i reverse i go from R N D in one shot. i did the same with my SMG M5 and never had a problem. so i just wanna be on the safe side and ask you guys, is this true?
01-19-2010, 01:20 AM | #2 |
Rep 4,567
I don't pause at all when changing from reverse and back. Often times the car keeps rolling (albeit at very slow speeds). The manual recommends that you come to a full-stop, but I'm sure it's fine. That's how I transitioned from reverse in my previous two manual cars. A three-second pause sounds a bit unnecessary.
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
01-19-2010, 02:11 AM | #3 |
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
Go with your first instinct.
When I'm done backing up, I pop the lever out of reverse and into S mode in one motion while brushing the brake pedal without necesarily coming to a complete stop, then give it a little gas and it stops rolling back and starts forward... just like most drivers do with automatics or manuals. I'm not saying this is the proper thing to do, but after awhile it just became the way I did it, kind of without thinking about it, again, much like you would do in a manual. I don't see how it would be damaging in any way, in fact, if it was, it wouldn't allow it. Yes, the book says to come to a complete stop, blah blah blah, but so does every book for every car no matter what kind of transmission it has. There is a software requirement that the brake pedal be pressed in order to put it in gear, but like I said, that can be met by just brushing the brake pedal. In any case, the short answer to your question is no, there is no 3 second pause requirement. |
07-28-2010, 10:53 PM | #5 |
Rep 61
I know this is an old thread but my question is...
Is the clicking sound changing to N -> R and back normal? I just picked up my car last week. I drove e46 M3 with SMG for a while and never experience this before. That clicking sound makes me feel like its about to break. Does everyone else experiece this? |
07-29-2010, 01:40 AM | #8 |
Rep 403
On the topic of shifting, my friend tells me that when shifting from D to R i need to stop the shifter have way through(left, pause, then up) or else I risk damaging the tranny, is this true?
07-29-2010, 02:09 AM | #9 |
Rep 1,887
07-29-2010, 05:22 AM | #11 | |
Loves FFDP
49
Rep 781
Does your buddy own a E9X M3????
Glory may be fleeting, but mediocrity ensures anonymity...
07-29-2010, 08:23 AM | #13 | |
Rep 264
Reverse. Stop. Pause three second. Slip into drive. Inch forward. Stop. Pause three second. Reverse. Inch backwards. Stop. Pause three seconds .... |
07-29-2010, 08:49 AM | #14 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
When you change gears from R to forward... is it supposed to go into D or S mode? Mine usually goes into D but sometimes into S.
07-29-2010, 09:14 AM | #15 |
Rep 483
Drives: e92 M3 DCT
it depends on the last mode you left it in before switching out of gear, if it's 1st time starting the car with a US spec vehicle it goes into S3 by default...also, the car is smart enough to slip the clutch or not engage the gear until it is safe to do so, don't worry about it
2006 e53 X5 4.8is (sold)
2009 e92 M3 2008 E63 AMG |
07-29-2010, 09:54 AM | #16 |
Rep 4,167
Ask your buddy where is ridiculous information is comming from? Legitimate resource MIGHT be tolerated
Audi R8 v10 Ford Raptor m3e46freak@yahoo.comfor all euro parts!! ebay/craigslist verified/ m3post/e46fanantics/m3forum/zpost/bimmerforum |
07-29-2010, 11:18 AM | #17 | |
Rep 19,368
But, ever since I have gotten the new software, mine has begun doing the same thing. Of course, I cannot be sure that the new software is the culprit. It could be that this particular switching mechanism in the shifter is wearing out and is now registering twice when I only move the shifter once. At first I thought I was crazy but its happening more than 50% of the time. I have been debating starting a seperate thread about this - maybe I should. |
07-29-2010, 11:39 AM | #18 | |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
07-29-2010, 11:47 AM | #19 |
514
Rep 1,437
I have a question. Is there a way to engage P when you come to a stop, say in your driveway? If Im not shutting off car and I want to run into the house or the garage or something, Ive been engaging N and pulling up e-brake. Is there another alternative Im not aware of?
2022 Individual M5 Comp
Venetian Violet 2021 X6M Comp 2024 i4 M50 on order IG @purpleM5Comp_NY |
07-29-2010, 11:51 AM | #20 |
Rep 89
i am wondering why sometimes when i started the car up and then reverse the car out then put it into drive, why it sometimes it is in s1 and sometimes it starts out in d1? i never put the car into s mode since its in break in. but it is really confusing cause randomly it will be in s mode and then i come back and start the car over again its in d mode?
07-29-2010, 12:19 PM | #21 |
Rep 260
I have had the same problem since the day one. I guess it's normal. It's '11 e92 zcp btw.
07-29-2010, 11:55 PM | #22 | |
Rep 61
