01-07-2010, 02:08 AM | #1 |
Rep 13,114
Is something wrong with my clutch?!
I know this car has a twin disc clutch and a performance flywheel and what not...
but recently I've noticed this weird sound coming from my clutch when I put it in N and clutch out, it's like a scraping noice... it's not that "tupperware warming" noise *yes I did search* it's like someone stuck something in between the clutch and flywheel and it's scraping...almost like a whistle can someone check their car and let me know
01-07-2010, 03:20 AM | #2 |
I like cars
329
Rep 5,052
Sounds like your throwout bearing
Dealer time
My photostream: http://www.flickr.com/photos/racelap/
01-07-2010, 12:22 PM | #3 |
Rep 5,012
You need to record it to know what exactly you're talking about. The clutch gets pretty clunky when modulating the clutch at slow speeds, like reversing out of your garage. And even worse if going slightly uphill, since drivetrain is reversing direction every time you depress clutch pedal enough to disengage clutch.
Oh, and if you're idling with the clutch pedal out, it's noisy too, but shouldn't be too loud. Again, only a sound file will allow us to help you better. Good luck. |
01-07-2010, 01:13 PM | #5 | |
Rep 13,114
01-07-2010, 02:05 PM | #7 |
Rep 1,314
Drive around at 6k rpm and completely let go of your throttle but don't clutch in. If the sound continues all the way down and goes away once you clutch in, it's your throw-out bearings.
01-07-2010, 02:13 PM | #8 | |
Rep 13,114
Thanks man Rennspec ftw
01-07-2010, 03:10 PM | #12 |
trollololol
148
Rep 878
This would probably be my fault...
01-07-2010, 03:15 PM | #13 |
Rep 1,570
Drives: 2013 LRP M3 Coupe
The throwout bearing is only like a $40 part but you have to drop the tranny to swap it out..
Did they put a new throwout bearing in when you put in the clutch? as a rule you should always put a new one in when changing your clutch.. |
01-07-2010, 07:55 PM | #15 |
Rep 442
Van...Don't know if you caught my recent post...but I think I have the same thing! My M3 is at the dealership & they checked out the clutch, flywheel, throw-out bearing & all tolerances were good & the clutch & flywheel looked fine. That said, they are replacing the clutch, flywheel, throw-out bearing & "Y" fork & hopefully by next Tues the parts will come in & by Wed. this will fiz the problem & I get my M3 back...if not, they said replacing the tranny is next.
08 E90 M3, JrzB/BB, 360 Forged 8 Mesh, H&R Springs, RPI Scoops, Eisenmann Sport Exh, VRS Lip, CF Decklid, CF Diffuser, OSS LED AE, Rear Headrest V1, '09 iDrive Controller, Euro Rear Fog, OEM BlackLine TL, MRTM Design E90 Pedals & Door Lock Studs
01-08-2010, 12:31 AM | #16 | |
Rep 13,114
okay you know what I'm just going to run the damn thing to the ground when it stops moving, that's when I'll call bmw...towing or w/e and have them fix it
01-08-2010, 12:35 AM | #17 |
Rep 13,114
thanks leeeeeeeon
my clutch is the original clutch
01-08-2010, 04:22 PM | #18 |
trollololol
148
Rep 878
Maybe it's my turn to drive again then.
01-10-2010, 07:34 PM | #19 |
Rep 365
i had a weird scraping sensation/sound that kind of felt like it when you scrape ice off your windshield when shifting into second. happened the first time i shifted but after that didnt have anything like that again. dunno if its the same thing you had
01-12-2010, 03:24 PM | #22 |
Rep 803
To OP and kiloil -
Would you mind sharing your total miles with us, please? Thanks!
Objects in mirror are slower than they appear.
