12-26-2009, 01:45 PM | #1 |
Rep 2,286
Owners of Multiple Versions of E9x M3's
On one of the threads I was looking at today I noticed one member has both and E92 and an E93 - just curious as to the following:
1) How many other members have more than one version of the E9X M3; and 2) for those who have the E93 as one of the two versions - how much difference in all aspects of performance (acceleration, handling, cornering) do you notice on public roads (or, if anyone actually does take their E93 to a track, which I'm sure is incredibly rare - what are your experiences there)? Thanks, |
12-26-2009, 02:37 PM | #2 |
Rep 2,872
Can't speak for the E93 as I've never driven it, but E46 M3 vert to coupe back to back the acceleration and handling in both straights and corners the difference is huge.
Even properly setup on the track they don't quite keep up with each other with comparable drivers. This year I've seen two different E93's at the track but they were all stock so they wouldn't really make a good comparison against my car at the track. One was in my group, but I didn't see him much, I'm pretty sure we were evenly spaced the whole time but either way its probably good news that neither of us could lap one another. Most every other E92 except a few have been running Rcomps anyway. It's hard to tell but the E93 is still capable of doing its thing. Since it doesn't have a real roll bar but has the roof, they were both allowed to run in NASA and Trackdaze so you should be able to run no problem if that's what you're worried about. Figured I had some input since you're probably local to me. On the street you wont be able to get close to the limits of handling unless you're driving pretty recklessly, and if you did, you will feel the body roll and weight over an E90/E92. Acceleration you will definitely tell in perfect matched conditions that it is a bit slower as well, but either way I doubt you'll come across a situation where it would matter if you're just cruising around |
12-26-2009, 03:06 PM | #3 |
Rep 249
Having owned both, I may have some insight to your question(s). I moved from the E93 to the E92 a short time ago and can tell you there are fairly significant differences in performance, even in everyday driving. My initial impression of the E92 was that the power delivery (i.e. throttle response) was much more linear, immediate and snappier. You can really feel the weight difference between the two. Steering is also more direct and you can really feel, especially on initial turn-in, the difference in chassis rigidity. Even with the top up I never felt the seamless connection to the road, especially in turns, like I do in the E92. For some reason I also like the sound of the E92 better. I can hear more exhaust than engine noise, obviously due to better roof insulation. I just passed 1200 miles and drove to Grandma's house for Christmas dinner last night and in S5 the shifts were incredible at 6500 rpm. Love this car! I kind of miss having the option for top down driving, but not that much...
12-26-2009, 03:24 PM | #4 |
Dog Listener
703
Rep 7,850
I'll echo what M3twins said and add the following.
I've had both. An E93 6MT (no EDC/no Tech) and currently an E92 DCT (EDC/Tech). Same wheels/tires on both (18s, same rubber, as I swapped kept my 18s from the E93 for my E92). Yeah, call me crazy...I like the 18s and it saved me over a grand on the price. In a nutshell there are very noticeable differences if you are on a deserted back road with lots of curves. I can only imagine that would carry over on to the track as well. In day to day driving the differences are a bit more subtle--but they are noticeable. Especially if when passing another vehicle; taking evasive action; or in sudden braking situations. The car lumbers a bit more (weight). More details below. Please note that the following are opinion and I'm not an expert driver or track/autocross veteran. In terms of 6MT vs. DCT I drove a MT for over 30 years, heel/toed very well, and had no issue being in the right gear going into a corner. So the transmission and tires/wheels should be a wash in terms of comparison for the most part (e.g. it's not as if I didn't know how to drive a stick which would cloud things more). I drive the DCT in S2 (smoother) mode pretty much exclusively and my driving style is the same (downshifting, rev points, etc.) as with the 6MT. The E93 handles quite well. In fact, IMO better than a stock E92 335 in terms of steering feel/feedback, inspiring confidence in turns, and in terms of braking feel, and in terms of ride. The LSD and suspension have a lot to do with that. BMW did a good job of hiding the weight and the springs, dampers, anti-roll bars seem to be up to the job. It's also the most solid vert I've ever been in. However, it's impossible to get around the extra weight entirely. All that follows is with the top up--with the top down I can't recommend any type of aggressive driving as the weight distribution is "off" and the car loses substantial rigidity.
Either car is blast to drive; it all depends on what your intended purpose is. If you want to hard-core canyon-carve on weekends; or think you might autocross or track the car; then I'd suggest the E90/92. If you're not going to go that route and want something that will still outrun/out-handle 95%+ of what's on the road the E93 is hard to beat. The E93 re-ignited my passion for driving and as I want to track the car; and I was able to come out okay on the trade, I moved to the E92. Bottom line, and like I said before, it all depends on what you want out of the car. Either of the three models are a hell of a car. |
12-26-2009, 04:23 PM | #5 |
Rep 2,286
Thanks for the feedback from the above-posters - nice to have objective feedback from those who have owned both, and not those who merely make assumptions without having driven both. I'm sure I'd notice the performance difference as well without the extra 450lbs - although I don't think I (or my family) would want to give up the open top option in the summertime - I do admit that sometimes I wonder how much more I might like the E92/E90 from a pure driving dynamics standpoint - esp. after reading the posts above!!
12-26-2009, 04:53 PM | #6 |
Rep 30
I understand that it can be tough deciding amongst so many choices, from multiple makers all over the globe. I shopped hard and took a great deal of time researching my options. As I wanted a convertible daily driver (6MT a must) for under $100K--the E93 was a natural choice. I believe that for the money, it is the best all-around open top combination available in the world. Most importantly for you: make your list of priorities, and if top-down capability is in the top three slots, I suggest you go for the E93. If you don't, you will be wishing you did! Good luck, enjoy, and be safe.
12-26-2009, 10:20 PM | #7 |
Dog Listener
703
Rep 7,850
Powerslide and Cytoboy, it sounds like you made the right decision since the open top is something you (plus family) really value. The E93 is a really is a good performer and there really is nothing like having the top down on nice day or warm evening while hearing the motor sing! It's great fun!
12-27-2009, 01:01 AM | #8 | |
Rep 1,804
O/wise the E93 should suffice |
12-27-2009, 05:48 PM | #10 |
Rep 627
The 4.4 liter V8... Edmunds, you smokin' crack?
12-28-2009, 02:31 AM | #11 |
8 tracks of madness
62
Rep 2,735
The only seat time I had in a an E93 was during two test drives and then a test drive in an E90 (both DCT) but the difference was night and day. The E93 just wouldn't get out of it's own way. I'm sure it's fine when up to speed but for city driving I don't think I could live with an E93.
01-01-2010, 04:03 PM | #12 |
Rep 17
E90 has more headroom
The E90 has more headroom than either the E92 or E93. My hair touched the roof of the latter two; does not touch in the former.
01-03-2010, 12:14 AM | #13 |
Rep 307
On the E93, you might need to keep switching radio stations.
E36 M3 convertible & Jazz på NRK P2 Commercial (According to YouTube user's (user name: ralphjohanson) comment (), this is Norwegian commercial for NRK Jazz radiostation..) source:
01-03-2010, 01:03 AM | #14 |
Rep 4,643
hmmmm....All this discussion makes me wonder how much more pleasure I would get when hearing my full catless exhaust note on an e93 instead.
On second thought, I think I'll keep my e90. |
01-03-2010, 02:51 AM | #15 |
Rep 2,426
“For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.”
- John 3:16 |
