ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      12-23-2009, 04:24 PM   #1
elude
elude's Avatar
Do I need to Bleed Brakes?
Guys,
I just did a brake-pad change (for the first-time) on all corners with some Akebono Ceramic pads, and noticed that there is more "play" in depressing the brake pedal. It doesn't seem to have the "sensitive bite" that it had before changing pads.
I'm assuming I need to bleed the brakes? The brake fluid in my lines is brand new from the dealer about 2K miles ago, and I really don't see the necessity in completely flushing and bleeding out the brakes.
Any input helps, and thanks in advance.
      12-23-2009, 05:24 PM   #2
1st_Knight
'Entwicklung 85 - Zukunft4'
1st_Knight's Avatar
Drives: 04 Z4 SMG DINAN S1
Originally Posted by elude View Post
Guys,
Son, if the dealership already serviced the brakes. IMHO, I am sure that you do not need to bleed the brakes. Just curious, have you check the brake reservoir level?
BTW, I just had the brakes redone on X3, and did not have them bled and there bite is still good. It may not be an M, but the bite is still good.
Also, check out this link...
http://www.garageboy.com/bmw/bleeder.html
      12-23-2009, 06:22 PM   #3
jmillet
jmillet's Avatar
64
Drives: 2023 Hyundai IONIQ 6 SEL AWD
Guys,
Did you open the bleeder valves in order to compress the caliper pistons? If you did shame on you as that is a good way to introduce air into your brake system. If, on the other hand, you compressed the caliper pistons with a C-clamp or a compression tool or with your fingers then your problem is most likely that the new pads are not fully bedded. You need to get the rotors properly coated with the new pad material. Go to StopTech http://www.stoptech.com/tech_info/wp...contents.shtml
or Zeckhausen http://www.zeckhausen.com/bedding_in_brakes.htm
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
zpost
