12-21-2009, 10:00 PM | #1 |
Rep 13,114
Driver Hump...rattle?...no?
Does anyone get this weird noise from the hump (not navi hump) but the speedometer one when hitting bumps hard?
It doesn't sound like a rattle but more like something is loose...
12-22-2009, 01:17 AM | #2 |
yodog
197
Rep 5,025
Mine sounds like it's coming from the center hump/idrive/I'm not sure.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
12-22-2009, 03:29 AM | #5 |
yodog
197
Rep 5,025
What's the cluster case?
12-22-2009, 07:28 AM | #6 |
Rep 15,818
the car definitely makes creaking and rattling sound more in cold weather compared to summer times. I dunno why
IG:d.violet.m3
12-22-2009, 09:06 AM | #7 |
Rep 46,029
yes, it sounds like there's something lose. my car right now has all kind of rattles, and i only realized it ONE day when i turned my music down. i thought the M3 had no rattles whatsoever
and it's not going over bumps hard, i get the sound over the little LA freeway bumps |
12-22-2009, 10:58 AM | #9 |
Rep 753
Cluster case would be the instrument cluster area. I believe the tach and speedo are housed in a unit that becomes loose sometimes. The felt tape will keep it secure.
12-22-2009, 01:55 PM | #11 |
Rep 4,318
I have the same thing, it is either the cluster or a part in the steering column. I can make it stop by wedging my fingers in between the top of the column and the bottom of the cluster. Taking it in for a fix after the holiday and will report back on the cause.
12-22-2009, 01:56 PM | #12 |
Dr. Octagon
260
Rep 1,919
Rattles? Did someone say rattles? I can't hear you over all of this rattling.
Yes, this car definitely rattles. Here are the notorious locations I've found over the last two years:
The dealer can install felt as others have mentioned...this does work where applicable.
OC ///M
2013 E92 M3 Individual Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB |
12-22-2009, 02:19 PM | #13 |
Rep 5,012
Yeah, me too. That dash rattle (rattles, really) is one of the many I have. I tried pressing everywhere but doesn't stop. Will try between steering column and cluster next time, but we still need to reach that area to investigate further. I definitely won't let a dealer mess with that, so it'd have to be me. Has anybody removed the cluster from the top? A DIY (or just some instructions) would be great. It's much better (and convenient) to insulate everything from the top than from underneath.
Looking forward to hear from somebody who has removed that thing, so we can quiet those rattles. At least the ones who want to DIY . That's the most annoying one, but the one inside the door is getting on my nerves too. Was trying to avoid having to remove the door panel, but seems like I'll have no choice. The tweeter cover was contributing, and I removed it and wedged a piece of electrical tape to eliminate the gap, and it reduced the ratting by 50%, but something else is rattling inside. Possibly the door lock rods; can't think of anything else, but could be a speaker too. Need to get inside. Thanks gang. |
12-22-2009, 02:38 PM | #15 |
Rep 4,318
Cluster removal DIY.
12-23-2009, 07:24 AM | #16 |
Faster
Rep 132
Drives: M3 Coupe Melbourne Red/Black
Had the same issue to include a slight rattle in my NAV area. The wierd part is the speed-o area rattle was really only noticable when the outside temp was really cold. Not really sure what the dealer did, but its gone now....
12-23-2009, 07:41 AM | #17 |
I Drive Slow To Save Gas :D
26
Rep 464
I hear rattles in the center of my dashboard under the navi. The exhaust just rattles everything in my car. But i do get occasional rattles from the Navi hump as well.
12-23-2009, 10:15 AM | #18 |
Rep 468
I have the rattle with the window into the instrument cluster, if I hold it, it stops. So where do you put the felt tape to fix it?? Would love to get this resolved without a trip to the dealer.
12-24-2009, 03:59 AM | #19 |
Rep 1,275
+1 on the center stack rattle....my winter Honda is quieter with a lot more miles on it.
2022 M4 Competition ConvertibleDravit / Tartufo Full / Carbon Fiber Exterior...loaded
2020 X5:MW/Coffee Extended Merino, M Sport, B&W....loaded 2007 X3: Sapphire Black / Black loaded 6 speed Gone: M3 E93 Silverstone II over Bamboo |
12-24-2009, 10:29 AM | #20 |
Still waiting...
25
Rep 887
My car, obviously a lot older than all of your cars, rattles way more in the winter than in the summer. I am guessing its because the cold weather is causing the parts to shrink ever so slightly. This may open up more room for parts, that were previously snug, to move about a wee bit more.
12-24-2009, 10:37 AM | #21 | |
Rep 46,029
12-25-2009, 01:51 AM | #22 | |
Rep 5,012
