08-19-2009, 05:03 PM | #1 |
All of your tracks are belong to me
Rep 50
Dunlop Star Specs 235/40R18 and 255/35R18 on Stock Wheels Fitment?
Is anyone running this setup on their stock width 7.5" Front and 8.5" Rear wheels? Or is anyone running one of either size on either end?
From what I've read and looking at the room in the wheel wells, the rears should fit easily, but I'm not so sure about the front. Does anyone have the 225/40R18s Star Specs on the front that can tell me what kind of clearance they have, since I'd only need and extra 5mm inside/outside, and .2 inches in diameter? Anyone have pics of their Star Specs on the car?
Joe
SCR-SCCA SOLO Novice Co-Chair SCR-SCCA Time Trial Director 1996 Miata 2009 BMW 135i |
08-19-2009, 06:18 PM | #3 |
Rep 1,477
According to the specs, the 235/40/18 requires a 8-9.5" rim. Tire is too big for a 7.5" rim.
http://www.tirerack.com/tires/Spec.j...irePageLocQty= |
08-19-2009, 07:06 PM | #5 | |
Rep 50
larryn, do you know if he had to run a spacer to make it fit to avoid any clearance issues on the inside?
Joe
08-19-2009, 07:14 PM | #6 |
↓↓↓ Ex-Con ↓↓↓
34
Rep 1,874
I believe the 235/255 fitment is what pretty much everyone is going with in regards to the star specs. I plan on going with them in a couple thousand miles.
08-19-2009, 09:55 PM | #7 |
Rep 2,474
No spacer
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks! |
08-20-2009, 10:16 AM | #8 |
Member
33
Rep 392
This is not true. MOST people have chosen 225 fronts, especially with the star specs as they are wider than most other tires. Some have put 235s in the front, but with a spacer. Some even still say there is rubbing and need to add negative camber to make it work. If you plan on lowering the car at all the 235s won't work without a ton of camber and fender rolling, which would not be ideal for the street. Keep this in mind if your plans include a suspension change.
2009 135i
Dinan Stuff |
08-20-2009, 12:10 PM | #10 | |
↓↓↓ Ex-Con ↓↓↓
34
Rep 1,874
08-20-2009, 04:04 PM | #11 |
Member
33
Rep 392
yes, i was talking about the inside. Then, with the spacer people have used either fender rolling, or camber to prevent rubbing on the fender. I'm surprised people are able to fit the 235 in front with no mods, i was sure I heard that it wouldn't work.
2009 135i
Dinan Stuff |
08-20-2009, 04:27 PM | #12 |
↓↓↓ Ex-Con ↓↓↓
34
Rep 1,874
I just checked the clearance from the stock tire to the strut body and it is slightly less than 0.50". According to Tire Rack the sectional width is 9.1" on a 225 RE050A RFT and 9.6" on a 235 Direzza Star Spec.
With those numbers, the 235 will either not fit or be extremely close to the strut tower. |
08-20-2009, 04:27 PM | #13 |
Rep 2,474
It works, just looks poofy. I have seen BDH21's car with my own two eyes
08-20-2009, 04:28 PM | #14 | |
Rep 2,474
08-20-2009, 04:36 PM | #15 |
↓↓↓ Ex-Con ↓↓↓
34
Rep 1,874
I hear you about squeezing the tire on a smaller wheel which will suck in the edges just a tiny bit.
Now I am wondering how much more under steer we are getting with a 225/255 set up. Maybe Gill can chime in on this one once again. |
08-20-2009, 04:44 PM | #16 | ||
Rep 50
I am actually looking for a bit of balooneyness(new word), since even with the alignment pins removed, we can't get alot of negative camber. The extra width should provide a bit of an angled surface so that I don't destroy the outer sidewall/tread surface of the tires. The 235 is only .4" taller than stock, or .2" top and bottom, so it will only raise the car .2" and only be .2" closer to anything along the outside of the tire. I am staying at stock ride height, so I should be ok. If there is enough clearance on the outside to the fenderlip, I plan on running 1/4" spacers to help get rid of some of the understeer the car has. I'll try to take pictures with my digital calipers out so show what the clearance is when I get everything mounted. Pictures don't lie, well not usually at least.
Joe
08-20-2009, 04:46 PM | #17 |
Rep 50
Oh, almost forgot, I ordered through Gill at Tirerack, our forum sponsor. He recognized me as the person who started this thread. Its nice to have someone like him at the other end of the phone. It only took us 5 minutes to get the order in, and the tires may be here as early as tomorrow. Thanks Gill. Highly recommended.
Joe
08-20-2009, 04:50 PM | #19 |
Rep 50
As soon as they get here.
Joe
08-21-2009, 06:11 AM | #20 |
Rep 2,474
Don't forget to post pictures so we dont have to have this discussion again!
08-21-2009, 06:27 AM | #21 |
Rep 98
Drives: X6 XDrive35D
If your tyre (uk spelling ) is close to the strut when unloaded it may still contact the strut when its loaded up as the tyre carcase deflects under load. I had this on my lotus europa at the rear where there was clearance static but after some use there was evidence of tyre rub on the chassis from the inside edge of the rear wheels sidewalls I assume from deflection whilst cornering.
08-21-2009, 11:22 AM | #22 |
Member
33
Rep 392
Just a note. Clearly adding some tire at the front will help reduce the understeer issue by reducing the stagger, but I've found that camber plates go a long way towards helping understeer, especially on the street. Initial turn in with more negative camber is wonderful.
On the track, the front tires push a lot if you're not carefull, so the only real solution for a good track setup is getting some wider rubber up front.
2009 135i
Dinan Stuff |
