BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
BPM
      04-22-2009, 02:30 AM   #1
VanM3Lover
VanM3Lover's Avatar
20
Drives: 4.0 V8
LSD Break in procedure with picture!
Would you like to drive as described in the picture for 30 minutes?
My diff makes rubbing noise and chattering noise on very tight turns, maybe it's just not broken in.
      04-22-2009, 05:12 AM   #2
Gladius
Two Wheels or Four?
Gladius's Avatar
Drives: '18 Perf Edition m240i
I don't know about this procedure, but what you are describing is a known issue. Take it to the dealer and ask them to look up the TSB on it. They will replace the diff fluid with a new fluid that will "fix" the issue. I had mine done last week.
Current: '18 AW Performance Edition m240i
Gone: '15 Mineral Grey m235i || '07 Silver Grey M Coupe || '11 Space Grey 328i XDrive || '08 SparkG M3 || '01 LSB M3 || '01 TiAg 330ci
      04-22-2009, 07:45 AM   #3
foosh
foosh's Avatar
Drives: 2008 M3 E93
For everyone who experiences this noise and has it quieted with a diff fluid additive, don't be surprised if the noise comes back. To some extent, it is the clutch packs in the LSD doing what they are designed to do. The noise is not indicative of any damage being done, and you can ignore it indefinitely.
Many will never hear it because they don't routinely make prolonged tight turns at low speeds (e.g. looping up or down in a multi-deck parking garage or as in the diagram above).
This noise is relatively common in all autos equipped with LSD and large tires. The LSD clutch packs are there to allow the inner tire to barely rotate, while the outer tire is rotating at a much greater relative rate. In tight turns at higher speeds, the relative difference in wheel rotation between inner and outer tires is minimal.
MAKH 588.50
      04-22-2009, 10:33 AM   #4
MyKmYk
BMW Individual Junkie.
MyKmYk's Avatar
Drives: Mora E46, Tanzanite G20 M340i
Fantastic answer.
///MYKE
      04-22-2009, 11:00 AM   #5
GT3 Tim
GT3 Tim's Avatar
Drives: 2014 MB E63S
Originally Posted by MyKmYk View Post
Fantastic answer.
Yep. Great answer.
If you want to hear LSD noise, jump in a 996 GT3! LOL. That phucker sounded like a Mr. Coffee machine on overdrive. LOL. perk perk perk...that's how I described it to a fellow owner....and it does sound like a coffee maker "perking", but x1,000. lol
LSD noise is what it is. They make noise. If yours doesn't, THAT is when I would be worried!
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket
2014 F30 328i -- Kids car
2008 E90 M3 -- Sold
2004 GT3 -- Sold
1997 M3/4 -- Sold
1995 M3 -- Sold
      04-22-2009, 12:42 PM   #6
Kobaiyashi
Drives: 08 E90 M3 (JetBlack/FoxRedExt)
Just to be clear, is this the click, click, click noise (like a stick rubbing across a bicycle wheel) that I hear when I am turning in the parking garage or on a onramp?
      04-22-2009, 04:01 PM   #7
GTM
GTM's Avatar
Drives: E92 M3
That procedure is recommended by aftermarket clutch type LSD manufacturers.
      04-22-2009, 04:57 PM   #8
Dascamel
Dascamel's Avatar
48
Drives: 2008 e92 M3, 2010 e91 328i
30 minutes seems very excessive? Your LSD probably doesn't see that much wear from a few track days.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options
2007 Montego Blue 335i (retired)
      04-22-2009, 05:00 PM   #9
erio
erio's Avatar
Drives: e92 JB M3, 2012 GTR
Mine started making a rubbing type sound at about 3000 miles and only with slow sharp right turns. It does it very sporadically and really sounds like it's something coming from the front of the car. In fact, I had to take it to the service center 3 times because it was so inconsistant. It does seem to fade when the car is warmed up a bit. I took it to the head tech thinking it was the LSD and he said it doesn't sound like a differential and has no idea what it could be.....? Anyone think this could be the LSD and why only with right turns?
      04-22-2009, 06:05 PM   #10
foosh
foosh's Avatar
Drives: 2008 M3 E93
There is a clutch pack for each half-shaft on each side of the diff. Slight differences in lubrication on one or the other clutch pack could cause one to make more noise than the other.
      04-22-2009, 06:59 PM   #11
LateBraking
Drives: Relatively Quick.
I saw the picture, read the title, too lazy to read through the rest.
This noise is normal in M cars, it's the clutch plates in the differential. The same noise comes out of my M3, and every other M3 really, if you try to listen for it.
If it really bothers you, then you can get an additive put inside your differential oil at the dealership. It will eliminate the noise by 2-3 days once added.
But really, it's not harmful to your differential, and it's all just a part of the M experience. If you wanted something without any quirks, you probably got the wrong car. M car's have a history of being quirky.
      04-22-2009, 07:07 PM   #12
nusevad
O! So Sour!!
nusevad's Avatar
Drives: Fast 240z / Slow M3
1971 Datsun 240z  [0.00]
2008 M3  [9.60]
My car doeant have that noise? Should i be concerned? Lol seems like having that noise is a good thing?
      04-22-2009, 07:21 PM   #13
VanM3Lover
VanM3Lover's Avatar
20
Drives: 4.0 V8
What's your milage? I started hearing the noise 300 miles after the 1200 miles break in service.
      04-22-2009, 07:24 PM   #14
foosh
foosh's Avatar
Drives: 2008 M3 E93
Correct, you're likely to start hearing it after the LSD has gotten fully broken in. However, you may never hear it if you never do very tight, very slow and sharp turns.
      04-22-2009, 07:45 PM   #15
nusevad
O! So Sour!!
nusevad's Avatar
2008 M3  [9.60]
5000.
      04-22-2009, 08:37 PM   #16
LateBraking
Like I said, if it's the cause of concern, sleepless nights, and countless nightmares, go ask for the additive to be put in. However, just keep in mind that whenever any oil services are done to your differential, you will have to ask for the additive every time.
Not like you change your diff oil every 1k mile or anything ridiculous, but still something to keep in mind.
Personally, I like the noise. Reminds me that the M is an M.
      04-22-2009, 09:06 PM   #17
consolidated
consolidated's Avatar
205
Drives: F80 M3
Mine moaned like mad until I took it to the track, all gone except for the first tight turn on colder mornings.
      04-22-2009, 09:58 PM   #18
jbeene
jbeene's Avatar
Drives: 16 435i GC
I wondered what the hell that noise was. I hear it every morning in the parkade because naturally I leave my window open to listen to the V8.
16 435i xdrive Msport MPerformance 2 Ind Azurite on Opal
      04-23-2009, 08:14 AM   #19
ersin
ersin's Avatar
Drives: 17 YMB F80 M3
This just means you're taking sharp corners too fast. Slow down and maybe you'll hear it.
2017 F80 YMB.
      04-23-2009, 08:30 AM   #20
gr8000
gr8000's Avatar
Greece
72
Drives: E92 M3 - DCT
I never had the diff noise - my car is a Jun '08 delivery with 15,700km.
As a matter of curiosity, are there any drawbacks when using the diff additive? If for instance will the discs slip smoother after using the additive (thus getting rid of the irritating sound), which could lead to a different LSD performance / behaviour?
      04-23-2009, 10:04 AM   #21
SenorFunkyPants
SenorFunkyPants's Avatar
Drives: 2019 M5
Doing anything other than the BMW recommended change of diff oil would not be wise...especially adding aftermarket slip additives.
      04-23-2009, 10:11 AM   #22
LateBraking
It's not aftermarket. It's warranty-covered service done at the dealership, using a BMW-created-and-approved additive.
As far as I MYSELF know, there is no change in performance, although you cannot perform differential oil services WITHOUT the additive from the time that you put the additive in.
If you drive it hard (AKA enthusiastically in a demanding, winding road) it should make a rapid ticking sound, like when your body is full of static electricity and you touch something metal over and over. If you drive it slowly in a tight circle with your steering wheel fully locked in a parking lot (or parking structure, the enclosed area will help you hear it) it should make a groaning sound, like the sound that sinking oil tankers make in movies. Try that if you WANT the noise.
m3post
