03-17-2009, 08:25 PM | #1 |
Rep 810
Clanging/shuddering noise at shut down/turn off- solved (Park car in gear)
Took delivery of my 1er with 1 mile on the odometer yesterday afternoon in Spartanburg. No problems on the drive home. I was careful not to go above 4500 RPM. No full throttle. I was even slowing down to 40 on the highway to smoothly bring it up from 2000 to 4000 RPM and through a few gears. I made sure not to run the car at the same RPM for too long. I thought everything was fine, but today I'm noticing a more a more prevalent clanging noise when I turn off the ignition. Anybody else experienced this?
03-17-2009, 08:33 PM | #2 |
Cruising Daily
11
Rep 209
Exhaust ting?
2008 BMW 135i - AR Catless DP - Agency Power Mids - Corsa Exhaust - KW v2 - Performance Side Skirts, Pedals, Steering Wheel, SSK. - CF Spoiler, Diffuser, Mirror Caps - Injen Intake - JB3 2.0 - CPE BOV Kit (HKS) - 6k HID AE - 6700k D1S - Evolution Racewerks FMIC -
03-17-2009, 08:38 PM | #3 | |
Alpine Master
111
Rep 1,310
Alpine White with Taupe Leather 135i, Sports Package, Heated Seats, Comfort Access, iPod Adapter
Fastness: http://www.1addicts.com/forums/showthread.php?t=252727 |
03-17-2009, 09:15 PM | #5 | |
Rep 810
Also, I am positive it's not just the car snap/crackle/pop-ing while cooling down. My dad's Cayman S does that a lot so I'm very familiar with that sound. |
03-17-2009, 09:23 PM | #7 |
Rep 62
u gotta change the "what u drive" part of ur avatar, its not on order anymore U HAVE IT
Black Sapphire 135i Coupe, Savanna Beige, Aluminum Trim, M Sport Package, Split Second Turbo Tuned
03-17-2009, 09:32 PM | #8 |
Rep 2,067
In the cars user manual, it states to shut off the car in 1st or reverse. I know the exact sound you are talking about, it sounds like a rattling down sound when you shut off the car in N. Turn the car off in 1st or reverse and you won't hear it for sure.
2020 X3MC
2009 135i: AW/CR Aluminum Trim, 6 speed, M-Sport, Premium, Heated Seats, Ipod, BMW Performance Pedals, BMW Performance SSK, BMW Performance Exhaust, BMW Performance Grills E93 M3 FSB Last edited by new2the3; 03-17-2009 at 10:27 PM.. |
03-17-2009, 10:03 PM | #9 |
エアーマンが倒せない
271
Rep 2,041
I always shut manual cars off in 1st or reverse in case the e-brake doesn't hold.
In this car...the e-brake doesn't hold.
03-17-2009, 11:25 PM | #10 |
Victim
Rep 152
What the heck? Page 49 of the manual says to stop the car and then shift into first or reverse. Not shut off the car in first or reverse... Then forcefully apply e-brake and remove key from ignition.
03-17-2009, 11:35 PM | #11 |
Rep 2,295
This is a common BMW design thing. Its inside the gearbox that you hear the rattle/clang - i dont know why BMW dont tell people this
But its got to do with the input shaft. Turn the car OFF in ANY gear, and it will disappear. |
03-18-2009, 05:33 AM | #12 |
Rep 810
03-18-2009, 05:35 AM | #13 |
Rep 810
Sounds like this is probably it. I always rolled to a stop in neutral, turned the car off, and then put it in gear. Just habit from seven years in my old Integra. Guess it's time for some changes.
03-18-2009, 06:48 AM | #14 |
Rep 810
Just drove to work... turned car off to get gas, once at a stoplight as a test, and when I finally got to work and all three times not a peep with the car in gear. It seems that is the solution. I'm still going to call my local dealer to verify this is normal.
Mods, any chance you could change my thread title to "Clanging/shuddering noise at shut down/turn off" (the alternative words just to make it more visible in the search engine) |
03-18-2009, 01:21 PM | #15 | |
formerly izzo/comeback
287
Rep 3,382
03-18-2009, 01:29 PM | #16 |
Rep 1,239
In my g35 I had before the 1'er, I was informed that it was the dual mass flywheel that was making that noise. If you keep the clutch engaged at shutdown (regardless of gear selection), the noise will probably go away.
● 2015 Cayman S (Current), 2011 1M BSM #297 (Sold), 2008 135i (Sold) ● |
03-18-2009, 01:39 PM | #17 | |
Rep 647
