03-09-2009, 04:29 AM | #1 |
Rep 82
1st gear on a 135
Hello!
OKm i finally got my 135 on Friday. I am very confused about how hard if at all, I can drive it as its brand new...? Anyone know whats best? ALSO, 1st gear has no power at all...is this normal???? |
03-09-2009, 07:26 AM | #5 |
Rep 2,200
what do you mean 1st has nothing? It should pull so hard the tires will spin and traction control will cut your throttle
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
03-09-2009, 07:47 AM | #6 |
Throbbing Member
43
Rep 1,433
Try pressing the "DTC" button first.
If you're accelerating hard in 1st gear in the default traction control mode, it's probably limiting your power due to wheelspin (particularly if it's cold). However if the car is brand new, maybe you shouldn't do that at all, at least until the break-in period is over.
2014 Tesla Model S 85kwh
Previous cars: 2011 335d / Deep Sea Blue / Saddle brown / sport / premium 2008 BMW 135i / 6MT 2002 Z06 Corvette |
03-09-2009, 08:04 AM | #7 |
Rep 130
Read your owners manual. But if you want the cliffs version... stay under 4500rpm for 1200 miles.
03-09-2009, 08:26 AM | #8 |
Alpine Master
111
Rep 1,310
My CA told me with his German accent, "keep it under 160 kilomters per hour for at least a tousand kilometers and do not allow the engine to reach redline." This was when I took delivery in Germany.
Alpine White with Taupe Leather 135i, Sports Package, Heated Seats, Comfort Access, iPod Adapter
Fastness: http://www.1addicts.com/forums/showthread.php?t=252727 |
03-09-2009, 09:12 AM | #9 |
Rep 82
Crap....yes it is brand new, had about 35miles on the clock when I picked it up Friday.
I have been told different things by different people, some say run it by being carful for 1000miles. Others said you need to rev it to run it in.... Hmmmm I better slow down. |
03-09-2009, 09:21 AM | #10 |
Rep 3,350
Vary the revs, but keep them under 5000. A short burst to 6000 every once in a while for a second or two. When freeway driving shift gears evry minute or so from 6th to 5th to 4th to keep the revs changing. Accelerate at 3/4 throttle through the gears.
03-09-2009, 09:45 AM | #11 |
Rep 774
It is your car, drive it as you want to. ThYou can follow the manual, or you can drive it like you stole it. Over the years I have done both, and never had a problem. Now however, I follow the manual because I am getting old.
03-09-2009, 12:39 PM | #12 |
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
What type of Trany do you have Manual or Automatic Trans? Just curious
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
03-09-2009, 02:09 PM | #13 |
Rep 717
My car (with MT) also feels like it has no power in 1st gear unless I give it 50+% throttle (which then gives me wheel spin). I wish there was a happy medium :/
03-09-2009, 02:33 PM | #14 |
Rep 4,311
Drives: Supercharged E90 M3
Beat the crap out of it, It will become faster that way...
Dang, I get wheel spin all the way thru 3rd gear... Must be nice to only have it in 1st.
03-09-2009, 02:36 PM | #15 |
31
Rep 439
This has been discussed before and everyone will have a different opinion. I just went with what the designer/builder of the car said which is in the book.
You cannot really go wrong then can you?? |
03-09-2009, 02:38 PM | #16 |
Most interesting Roadster
69
Rep 2,224
Drives: '01 Z3.0 Roady;'10 C300 Sport
I'm trying to be good for the most part but I've gotten on it....a couple.....of times
I can't complain, but sometimes I still do........Life's been good to me so far.
- Joe Walsh |
03-09-2009, 03:13 PM | #17 |
1Addict, and Proud
88
Rep 1,024
yea i get wheel spin too all the way to 3rd gear. but in first there is not much power as there is in 2nd or 3rd. but still it pulls.
[SIGPIC][/SIGPIC]
the old look: bmw performance http://www.1addicts.com/forums/showthread.php?t=299703 the new look: Widebody 135i http://www.1addicts.com/forums/showt...98#post7686798 |
03-10-2009, 06:01 AM | #18 |
Rep 82
"untouchableE82: yea i get wheel spin too all the way to 3rd gear. but in first there is not much power as there is in 2nd or 3rd. but still it pulls."
Spot on...thats just link mine! I guess thats just how it is. It might be as im used to a 5 spead gearbox, so with six the powers more spread out. FYI, its a manuel. |
03-10-2009, 09:30 AM | #19 |
Rep 475
Drive it the way you want, but as for me, I'd rather be safe then sorry. under 4000 rmps for a good 1000 - 2000 miles. Don't drive in cruise control for long periods of time. Vary the rpm range. Don't drive it like I stole it.
///M 135i
03-10-2009, 09:35 AM | #20 |
Rep 475
Should drag launches be done in 2nd gear?
///M 135i
03-10-2009, 10:01 AM | #21 |
Rep 5,970
All you guys who think this car doesn't have any power in first gear are confused. The engine produces the same amount of power no matter what gear you're in. The lower gear ratios produce more power/torque to the rear wheels, so there is always more power in first gear than any other. If the car isn't accellerating it's because one of two things is happening:
A) The tires are spinning B) The tires started to spin and the traction/stability control has stepped in and cut the throttle The one's who are spinning the tires well into second gear (and some of you in third), you're either on winter tires, or it's time for a new set. I'm on all seasons right now, running catless DPs and a JB3 and have no problem with the car spinning in second gear when it's not freezing cold outside. |
03-10-2009, 11:33 AM | #22 | |
Rep 5,627
Tom |
