02-25-2009, 03:26 PM | #1 |
Rep 3,110
1st service: no transmission fluid change?
hi
i just had the 1st service, and the rep said all fluids were changed and tested, and the m differential and the filters, but he said the transmission fluid was not, it is good for life,,, is this true, i dont recall whether they are supposed to change it or not? its a manual e92 m Last edited by niqui; 02-25-2009 at 04:03 PM.. |
02-25-2009, 03:29 PM | #2 |
Rep 610
I had mine changed. I believe most people here are having it changed
some may disagree, but i dont think that any fluid used in a car should be lifetime
EDC.....viagra for your car
02-25-2009, 03:50 PM | #3 |
Rep 3,110
so does that mean i should have had it changed?
i assume it cant cause damage to the car or be a big deal, i will check the manual, to see if it says theyre supposed to change that. |
02-25-2009, 04:23 PM | #4 |
Rep 1,027
they did my oil, filter, diff fluid and tranny fluid at 1200.
08 - M3 Sparkling Graphite/blk leather/tech/6 speed
08 - 335i Sport/Prem/Auto White/Terra - AA Exhaust 07 Acura MDX Tech, 07 G35S /Nav |
02-25-2009, 05:19 PM | #8 |
Rep 239
IMHO yes. This problem arised because when DCT came out there were several instances in which the techs changed the DCT fluid (DCT doesnt need the change) and used the manual transmission fluid, ruining the DCT transmission. The confusion was because the SMG transmissions need the same services as the manual one and use the same fluids. My speculation is that to avoid that problem BMW now recommends no oil change at all but I havent seen anything in writing. Check http://www.bimmerfest.com/forums/sho...d.php?t=341406
02-25-2009, 06:06 PM | #9 |
Rep 3,110
thanks guys, ok will do, i take it its not a big rush.
i will drop the car to them this sunday and tell them to do it. thanks anything else i should ask about, filters and oil and differential all done, he said. thanks again |
