02-11-2009, 07:19 PM | #1 |
Rep 381
Drives: BMW 128i
sound insulating engine hood
does removing this make the car any louder? if anyone has removed it how much loude?
02-11-2009, 07:24 PM | #2 |
Rep 316
instead of that, if you got an intake that would make the engine louder. then, if you got an exhaust, that would make the exhaust louder so then you've got engine/exhaust sound improvement and a little boost in power.
MY00 S2000 #8712
02-11-2009, 07:53 PM | #3 |
Rep 381
Drives: BMW 128i
true true, but while those two options will run you roughly 800$ a piece, you could just remove the engine cover which is free.
02-11-2009, 08:45 PM | #4 |
Rep 381
Drives: BMW 128i
just looked at my car it seems pointless to do this sry for the dumb question
02-11-2009, 09:38 PM | #5 | |
Rep 504
I think that insulation is actually heat insulation. so that the motor doest cook the paint off the top of the hood. at least i'm pretty sure that's what it's for. |
02-12-2009, 11:51 AM | #7 |
Rep 316
then hold off on the exhaust and get the injen cai for about $475 from bavarianx.com - that could be all you need.
MY00 S2000 #8712
02-12-2009, 12:35 PM | #8 |
Rep 1,609
My 135 did not come with the hood liner and it sounds the same as the ones had.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
02-12-2009, 02:21 PM | #9 |
Rep 309
Yes it makes it noisier, and also it protects from under hood temps that can prematurely age the top of the hood paint.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car 1989 Honda Civic Si-R Current Project 2002 Corolla CE Daily Driver www.TheTunerSource.com |
