02-09-2009, 05:30 PM | #1 |
Rep 408
steptronic, hit rev limiter is sport mode?
I am a little confused, I thought the sport mode was supposed to shift when you hit around 6800 and you should not hit the rev limiter unless you are in manual mode.
Can someone clarify? I had it floored and it bounced off the revlimiter. Felt like I hit a wall. This is my first auto, so I dont know what Im doing . David |
02-09-2009, 06:16 PM | #2 |
gone but not forgotten
35
Rep 985
Did it downshift? I ask because there is a resistant point in the pedal. If you pass this point the car downshifts and you hit a wall.
Our Lady of Blessed Acceleration don't fail me now.
02-09-2009, 06:20 PM | #3 | |
Rep 408
If the kick down is causing you to downshift, are you supposed to floor it past the kickdown point and then prior to redline let up on it? Its a just a little confusing thanks! |
02-09-2009, 10:13 PM | #4 |
Molar World
47
Rep 916
I was under the impression the automatic in sport mode will hold a gear regardless of RPM...but it will hit the fuel shut off valve (which I think is the "wall") but will not up- shift. Maybe an automatic owner can verify this or correct me if Im wrong.
Current: 2016 435i Coupe
Previous: 2014 335i Sedan; 2013 328i Cv, 2011 335i Sedan Gone But Not Forgotten: 2008 135i Convertible (my favorite) |
02-09-2009, 10:18 PM | #5 |
35
Rep 985
You know i've always shifted before it hi that point. Around 67 or 6800. I honestly don't know. All I know is that resistance point in the pedal will cause an automatic downshift to the lowest gear that your current speed will allow. Its usually 3rd. but it will shift to 2nd if it needs to.
02-09-2009, 10:50 PM | #6 |
**1er Lover**
10
Rep 201
that's odd that it held the gear at redline (if I understood correctly). I'm positive the step will not hold the gear..the tranny will shift @ redline if you dont upshift with paddles/gear selector...It is the ONLY thing I dislike about the ZF step on the 135. Someone on some thread a few weeks back said that if u upshift at redline and HOLD the gear selector down, that the tranny will hold the gear. I never tried it..it doesnt sound like a smart move..but other than that, it will upshift @ redline in any mode.
02-09-2009, 11:27 PM | #7 | |
Molar World
47
Rep 916
thanks for the info.
02-09-2009, 11:31 PM | #8 | |
35
Rep 985
