      02-01-2009, 01:19 AM   #1
rcracer_tx
Drives: BSM 135i
Installing the Remus Quad exhaust (56k killer)
As I got the Remus exhaust, I immediately noticed it was well packed. as I tore it open I was happy with the quality of the setup and the coating was excellent on the exhaust.
A few pics:
The bag of Hardware included...
opened...
You will need for installation:
-Drive Up ramps
-Flashlight/ work light
-Dremel
-set of wrenches
-set of sockets
-needle nose pliers
- Some type of lubricant (I had pool equipment lube around so I used that)
-yourself
-some beer (optional)
      02-01-2009, 01:19 AM   #2
rcracer_tx
Drives: BSM 135i
Start by removing the rear diffuser using this DIY:
http://www.1addicts.com/forums/showthread.php?t=209818
Once taking off the rear diffuser, you will see the mounting points on the muffler. Remove the mounting points as well as the line going to the muffler as pictured here, and put a box under the muffle to support the weight of the muffler
Now go down under the car and remove the bolts connecting the exhaust to the resonator and the last mounting point under the car:
Now remove the exhaust from the car:
      02-01-2009, 01:20 AM   #3
rcracer_tx
Drives: BSM 135i
Cut the Exhaust 2 inches from the muffler on the old exhaust using a dremel or or electric hacksaw and connect piping to the main Remus muffler:
Now it's time to add the mounting bracket for the other side of the exhaust. It simply bolts onto an existing bolt on the other side of the car, after attach the main exhaust by reversing the steps shown:
Now attach the second side of the exhaust piping to the exhaust and tighten all hardware:
Cut the rear diffuser by tracing over the original side of the exhaust and flipping the traced piece over and cutting with a dremel (sorry no pics, but it's pretty easy and self explanatory).
Next a notch for the exhaust needs to be cut with a dremel in this piece (will take picture of notch cut, forgot when installing):
      02-01-2009, 01:20 AM   #4
rcracer_tx
Drives: BSM 135i
After completing all of these steps, replace the diffuser using the DIY posted at the beginning, Fire it up, and take a test drive to enjoy the sound, and check for exhaust leaks.
By this time the sun should be setting, so sit back,crack open a beer, and enjoy looking at your new exhaust...
      02-01-2009, 07:15 AM   #5
Citizen Z
Alpine Master
Citizen Z's Avatar
Drives: '08 135i AW Sport
A+ man. Does it pretty dramatically change the sound or is it just a cosmetic mod?
Alpine White with Taupe Leather 135i, Sports Package, Heated Seats, Comfort Access, iPod Adapter
Fastness: http://www.1addicts.com/forums/showthread.php?t=252727
      02-01-2009, 07:41 AM   #6
MastaMind
I like beer
32
Drives: AW 135
Great write up man! Thanks for taking the time to post this up.
      02-01-2009, 02:32 PM   #7
rcracer_tx
Drives: BSM 135i
Thanks for the compliments guys.
It is still very quiet, but the tone has changed significantly...Its much more aggressive and deeper now. I personally like a little bit louder exhaust so I am going to get a set of downpipes to pair with this.
      02-02-2009, 09:29 AM   #8
CampioniShop
CampioniShop's Avatar
33
Drives: na
Great writeup RC, thanks!
A more centered look is close to impossible with the way the 135i's underbody is layed out. Major modifications of the underbody, the bumper, and the piping are necessary which involves too many variables to make it an affordable quad solution to the market.
If you would like a quote on the 135i QUAD, please PM us!
      02-02-2009, 10:11 AM   #9
SLO
Shane
SLO's Avatar
Drives: M3, RRS, LR4
Are there different options for the tips?
      02-02-2009, 11:16 AM   #10
rcracer_tx
Drives: BSM 135i
From Remus...
Originally Posted by Remus View Post
Our goal with this quad was to make it the most affordable on the market. Which we've succeeded at doing up to this day, going with a M3-like quad requires a lot of modification to the bumper (a complete new one at that) and many more hours of R&D for fitment purposes by REMUS GmbH which would drive the cost through the roof!
We are in discussion with REMUS GmbH directly for change in tips.
      02-05-2009, 03:01 PM   #11
rcracer_tx
Drives: BSM 135i
Videos will be up this weekend!
      02-05-2009, 09:57 PM   #12
Papito135
Papito135's Avatar
Puerto Rico
Drives: 2009 BMW 135i
Looks awesome.
US Army 11C 1983-1993
09 Sedona Red Metallic 135i
09 Ford F-150 Platinum
      02-06-2009, 08:22 PM   #13
Add1ct
Add1ct's Avatar
59
Drives: 135i, 335i
i am interested in this but getting used to the tips- how long did this take you- ie how long would it take a shop to do it
E82 N54 6MT 6FL 668 KASW turned in
E92 Crimson/Cream N54 6MT, ZSP, ZPP, ZCW, Nav, Sat radio, HD Radio, Logic7, PDC, Active Steering, Active Cruise, 6FL, CA
      02-07-2009, 06:59 PM   #14
rcracer_tx
Drives: BSM 135i
It took me about 2hrs (including putting the DIY together) It shouldn't take a shop more than an hour for the exhaust and 20-30 minutes for the cutout (took my time and sanded it with a dremel as soon as I got close to the size it should be so it would be more precise)... MAX a shop should charge you is 2 hours.
      06-22-2011, 02:55 PM   #15
scmartin
Drives: 2008 135i m-sport
what are you supposed to do with the vacuum line once you take it off?
*nevermind, i got it.
BMW 135i 08/grey/ m-sport package/red interior/matte black grilles/matte black emblem/BMS DCI/18'gunmetal forgestar f14 wheels/ Toyo T1rs/ bms jb3/bms can tool
      06-22-2011, 11:52 PM   #16
Yito90
Yito90's Avatar
Drives: 135i
WOW Looks good!!
-- 2010 135i -- Alpine White -- Black interior -- ///M-Sport -- iPod --
|| Blacked out Grill || 20% tint all around || BMW Performance Spoiler || Maddad EuroSport Street Exhaust || CF Roof Wrap || Injen Dual Cone Intake ||
      06-27-2011, 09:07 AM   #17
devet14
devet14's Avatar
Drives: '02 M Roadster '02 M3 '72 Bav
2009 135i  [0.00]
Did you modify your stock diffuser?
If so can you take some close up pics?
      05-28-2013, 12:25 PM   #18
MaDoNiOn
MaDoNiOn's Avatar
South Africa
25
Drives: 2008 Bmw 130i E81
wow only saw it now! how much did this all cost you?
Fack i see the guy is banned.... damnit!
this looks like the easiest quad exast setup to do! i want a video of how it sounds.
i dont dig the tips but im sure u can do summin about that.
i found the exaust! and it has waaaay better tips!
There is a before and after sound clip on the website. Sounds pretty awsome i think.
http://www.remususa.com/epages/remus.../0889081584CLR
Wishlist...
Bmw 135i Convertable White...
      05-28-2013, 03:24 PM   #19
Dackelone
European Editor
Dackelone's Avatar
Germany
10539
Drives: N54 e82
IF you run a four pipe exhaust don't forget to use some heatshield material above the battery box area. I remember one poor guy here melted his charcoal cansiter near teh fuel tank. ~$1000 repair bill.
      08-10-2013, 04:13 AM   #20
dashboy
dashboy's Avatar
United Arab Emirates
Drives: 135i M-Sport DCT
Remus Exhaust
Hi,
I have the same on my 2012 135i DCT M-Sport.
I love the quad look.
I installed a Catlass DP and the sound is just amazing.( Kinda loud when in non sport as its mostly in 7th gear)
When in sport mode its kick ass sound.
      09-17-2013, 08:24 AM   #21
MaDoNiOn
MaDoNiOn's Avatar
South Africa
25
Originally Posted by dashboy View Post
Hi,
Hey thats awsome! Do you have a video by any chance?
Wishlist...
      06-15-2016, 07:57 AM   #22
CJ///M
CJ///M's Avatar
13
Drives: 2015 BMW M4
What were the other pieces of hardware in the bag used for? Such as the plastic tubing and the black piece of plastic with notches in it ?
1addicts
