01-29-2009, 03:04 PM | #1 |
AristoCat
40
Rep 676
Inner Headlights, always off!
Hi,
I'm a new 1 series coupé owner "125i Europe" my car got Bi-xenon headlights, no adaptive HL system. I noticed that the inner lights never comes on. some in this forum pointed out that they turn on when in reverse or when cornering, not mine. There's a bulb in there though!!! any idea? |
01-29-2009, 03:16 PM | #3 |
Rep 1,917
The inner light does come on briefly when you signal left or right.
2014 EBII 435i xDrive M-sport
Gone: 2011 TiAg F25 X3 xDrive35i M-sport Gone: 2008 TiAg w/Coral Red E88 135i Cab M-sport |
01-29-2009, 03:24 PM | #4 |
Rep 128
Mine are the same, Bi-xenon without adaptive cornering lights. The inner projectors on mine don't light up either, I believe the bulb you see is the one for the halo rings.
[SIGPIC][/SIGPIC] |
01-29-2009, 03:39 PM | #6 |
AristoCat
40
Rep 676
I don't think the inner headlight bulb has anything to do with the Halo lights "daylight"
they are 2 different light systems. I still can't believe they are there, loaded with a bulb just like their outer brothers and yet they do not turn on!!! I have Daylight active, they look great. |
01-29-2009, 05:45 PM | #7 |
Rep 1,917
Read my post above. They do turn on when you signal left or right.
01-29-2009, 06:35 PM | #8 |
Rep 279
OP, just curious as to why you made two threads on this.
Other thread: http://www.1addicts.com/forums/showthread.php?t=226228 |
01-29-2009, 07:07 PM | #9 | |
Rep 128
rori zahr, The H8 bulb sits directly behind the clear lens of the inner lamp, but it does not light it as there is no reflector in there. The H8 bulb you see though the lens is on whenever the parking/daytime/halo lights are on. The H8 bulb has a painted tip and emits light 360 degrees radially. If used as a headlamp this requires a reflector to focus the light forward and out through the headlamp. Instead there are light tubes around the H8 that transfer the light into the halo rings. The light tubes are like fiber optic cables; clear plastic rods that are used to carry light. If you take the back cover off the headlamp, you can see them. Anyway, the point being the inner lamp on the NON-adaptive xenon headlamps is only cosmetic and doesn't light up.
[SIGPIC][/SIGPIC] Last edited by j8smith; 01-29-2009 at 10:22 PM.. |
01-29-2009, 09:15 PM | #10 |
Rep 1,917
Got it. I didn't even know the 1 came without adaptive headlights.
01-29-2009, 09:50 PM | #11 | |
Rep 959
01-29-2009, 11:23 PM | #13 |
Rep 959
doesn't that light light up when you used the high beam?
01-31-2009, 07:21 AM | #16 |
Throbbing Member
43
Rep 1,433
They also come on when you're turning (regardless of signal). Actually only one will light up at a time though.
2014 Tesla Model S 85kwh
Previous cars: 2011 335d / Deep Sea Blue / Saddle brown / sport / premium 2008 BMW 135i / 6MT 2002 Z06 Corvette |
02-02-2009, 01:38 PM | #17 |
Rep 57
Inner Lamp
02-02-2009, 02:35 PM | #18 |
Rep 959
Yup thats what I meant when I said high beam I was talking about the flasher. Like when you flash somebody with the lights
02-03-2009, 09:22 AM | #19 | |
Rep 57
My E46 330Ci inner set of lamps did flash but the 135 does not. Seems the inner set on the 1 series is decorative -- halos and little else. Don't know about the adaptive lights. I don't have that feature. |
02-03-2009, 10:11 AM | #20 | |
Rep 959
