01-23-2009, 06:10 PM | #1 |
Rep 20
help a noob - removing center caps
I have a set of sport edition a7's on my 135i (Pilot Alpin PA3's in case anyones' interested, and they rock).
I received the center caps from the dealer *after* the wheels were installed. Is there any way to remove the "Sport Edition" centers and replace them with the BMW ones *without removing the wheel*. I have tried everything short of drilling a hole in the center to remove them. Nothing seems to work. The centers from the BMW summer rims pop out no problem. What am I missing? thanks in advance |
01-23-2009, 06:14 PM | #2 | |
Rep 1,262
01-23-2009, 06:59 PM | #4 |
257
Rep 4,048
01-23-2009, 08:06 PM | #5 |
↓↓↓ Ex-Con ↓↓↓
34
Rep 1,874
I used a large suction cup and they came out a lot easier than I thought they would. I would have thought that they were just sitting in there with how easy it was.
01-23-2009, 08:38 PM | #6 |
Rep 20
Actually yes - I did try a large suction cup (the suction cup is used to screw in halogen bulbs and it fits perfectly). I pulled like crazy but no results.
I will try again tomorrow when the wheel is cool (its supposed to be -20C tonight). I was thinking that if the cavity behind the wheel had been heated from the heat of the brakes, it may be causing some negative pressure. If that does not work, then I will try 4 dabs of glue (one in each quadrant) and some string to then pull it off. |
01-24-2009, 01:23 AM | #7 |
Rep 239
I used a very small screwdriver and very very carefully pried them off.
I have the same wheels for my winter setup. I forgot to change the center caps until I had the new wheels on and realized it looked funky with the SE caps on it, lol |
01-25-2009, 10:15 AM | #8 | |
↓↓↓ Ex-Con ↓↓↓
34
Rep 1,874
01-26-2009, 09:49 AM | #11 |
Rep 1,254
Wow why would they have glued them in??? Wondering if there is something wrong. Very odd.
01-26-2009, 12:22 PM | #13 |
Rep 1,254
why not just try taking one wheel off see if you can pop it off from the inside. At least then you will know for sure they arent' glued in or somthing else.
01-26-2009, 12:56 PM | #14 |
1addict, and proud
40
Rep 1,019
Ronin where did you buy from them?
My winter rims were sport edition. I just took a wooden stick...and put on inside and a small whack and they just poped out. If that doesn't work, then maybe call who you purchased them from and ask them. This is a fist to hear of roundels being glued in. EspressoBoy |
01-26-2009, 11:02 PM | #17 |
Rep 1,262
01-27-2009, 01:47 AM | #19 |
NRA Life Member, BMW CCA 30 year member
181
Rep 2,614
Should Larry's pick ax method fail, and, I can't see why it would, there's always Andy's DIY roundel replacement - http://www.1addicts.com/forums/showthread.php?t=216391
Also, a bit of duct tape to pull the roundel followed by a round toothpick or a disposable plastic knife in the gap thus created works as well.
Resigned 1ADDICTS Moderator
To disarm the people is the best and most effective way to enslave them. George Mason |
01-27-2009, 02:48 PM | #20 |
Rep 20
Thanks Surname - I looked around for a post on removing the center caps, but didn't search "roundels"
As for the posts suggesting I remove the wheel - thanks guys - way to read the OP I'll try again using the suction cup method and the duct tape method. They're jammed in there really tightly (which is why I postulated that they were glued). |
01-27-2009, 04:33 PM | #22 |
1addict, and proud
40
Rep 1,019
Does anyone know where to the get a BMW pick axe for removing the roundel's?
I used an old stick but that just didn't feel right. This reminds me of an old Digial Equipment Co joke... they called the "unit" MAFD Mass Air Flow Device.... (I think it was that...my memory is not what it used to be) I had to ask what it was... answer... FAN! EspressoBoy |
