01-16-2009, 10:21 AM | #1 |
Rep 511
Weight saving
Hiya,
How significant would a weight saving of just over 4 pounds be as compared to the stock wheels? Would this result in any performance advantage? Cheers Jack |
01-16-2009, 12:20 PM | #3 |
Rep 2,474
the difference would be more of a feeling from less unsprung weight. It would be a bit less jarring. performance enhancement and gas mileage would have minor improvements if any from what i understand. I also would think you gotta look at the tire too, from company to company tires can vary 3 pounds or so in the same size. Just My opinion.
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks! |
01-16-2009, 07:03 PM | #4 |
Quality is everything
12
Rep 756
I don't remember the exact formula but saving 1 pound of unsprung weight has about the same effect as saving 4 pounds from other parts. The point is saving weight fomr the wheels is GREAT!
01-16-2009, 09:08 PM | #5 |
Let's save military ranks for those who earn it!
45
Rep 1,161
Drives: ...on the Ragged Edge
The car will handle better (bumps, etc...), brake and accelerate faster (less flywheel action to counteract).
Losing that much on a wheel, tire, or brake rotor is always worth it!
Richard
2013 BMW M3 Individual -- Fire Orange (sold) 2013 BMW X1 xDrive35i M-Sport -- Valencia Orange (sold) 2011 BMW 1-series M Coupe (#205/220) -- Valencia Orange (sold) 2009 BMW 135i M-Sport Coupe -- Space Grey (sold) |
01-17-2009, 01:19 PM | #7 |
Alpine Master
111
Rep 1,310
I don't know where I read this by I heard that 100lbs of sprung weight is equivalent to 15ish wheel horsepower. By that ratio, removing 16lbs of unsprung weight is roughly equivalent to about 8-9hp bump.
Alpine White with Taupe Leather 135i, Sports Package, Heated Seats, Comfort Access, iPod Adapter
Fastness: http://www.1addicts.com/forums/showthread.php?t=252727 |
01-17-2009, 02:38 PM | #8 | |
Rep 935
Thanks! |
01-17-2009, 03:12 PM | #9 |
Rep 3,350
Sprung weight is everything "above" the springs. Everything else, including wheels, brakes and axles - below the springs is unsprung.
This explanantion is from Wikepedia. In a ground vehicle with a suspension, the unsprung weight (or, more properly, the unsprung mass) is the mass of the suspension, wheels or tracks (as applicable), and other components directly connected to them, rather than supported by the suspension. (The mass of the body and other components supported by the suspension is the sprung mass.) Unsprung weight includes the mass of components such as the wheel axles, wheel bearings, tires, and a portion of the weight of driveshafts, springs, shock absorbers, and suspension links. If the vehicle's brakes are mounted outboard (i.e., within the wheel), their weight is also part of the unsprung weight. |
01-17-2009, 04:49 PM | #10 |
45
Rep 1,161
Furthermore, unsprung weight (or properly mass) must be overcome to get moving (the power of the engine must start four non-rotating flywheels (wheels, tires, brake rotors, and wheel bearings) and overcome to stop moving (the brakes must stop the same items). The suspension system must overcome the mass upon every irregularity in the road and absorb it's momentum.
Obviously, the less this stuff weighs, the better your car will accelerate, corner, brake, and soak up bumps. Reducing unsprung weight is one of the many arguements against run-flat tires, as they are a lot heavier than normal tires. Forged wheels are better than cast wheels for weight. Some tires weigh a surprising amount less than others. Two-piece brake rotors weigh less than one-piece rotors. Etc... It all comes with a price though...like everything in life.
Richard
01-17-2009, 05:05 PM | #11 |
Rep 2,474
how much do our RFT's weigh?
01-17-2009, 08:27 PM | #13 |
45
Rep 1,161
For a comparison, go to a tire manufacturer's website, compare the weight (many list this) for a run-flat vs. a normal summer tire in the size your car has. It's likelly around 4-5lbs per tire more for the run-flat.
Ya gotta do some of the work yourself! :
Richard
01-18-2009, 09:15 AM | #14 |
Rep 2,474
argh, you search buttoned me! I was assuming they weighed around 26-27 pounds as i have looked on tirerack but I didnt know if anyone knew off the top of their head. I also looked at some other tires on tirerack, but you can get some good rubber at only 22-23 pounds so thats a nice weight saving right there!
01-18-2009, 11:23 AM | #15 |
Rep 2,474
its permanently posted on wikipedia!
01-19-2009, 08:38 AM | #16 |
One Fast 1
53
Rep 747
Stock 264 style wheels are 11kg (24.2 lbs) front and 11.92 (26.2 lbs)kg rear.:wink: |
01-19-2009, 09:23 AM | #17 |
45
Rep 1,161
So you had already anticipated it eh? :biggrin: I couldn't help myself, as the invitation was too big. :wink:
Richard
02-16-2009, 03:13 PM | #18 |
Rep 1,859
from what I've read elsewhere on here, stock 264s- 25lbs front, 26lbs rear, stock bridgestone runflats, 24lbs front, 26lbs rear- tirerack-
I am thinking either breyton gts-r 18s at about 17 front and 18 rear or Enkei RPF1s at 18lbs or OZ Alleggeritas at about 18lbs and contisportcontact3s 235/40 18 all around at 21lbs this would take me to about 39lbs/ corner vs 49 front and 52 rear so a net savings of 20lbs unsprung front and 26 lbs unsrpung rear, or a total of 46lbs!! add on the BMW performance rotors at 3.1lbs less per corner and now I'd be down 58lbs-ish of unsprung weight- so if 16lbs is about 8 whp per above then that's almost 30 whp equivalent!!!, probably optimistic but probably would be able to feel this
E82 N54 6MT 6FL 668 KASW turned in
E92 Crimson/Cream N54 6MT, ZSP, ZPP, ZCW, Nav, Sat radio, HD Radio, Logic7, PDC, Active Steering, Active Cruise, 6FL, CA |
02-17-2009, 11:34 AM | #19 |
Rep 1,159
talking about unsprung weight, anyone know if there's any manufacturer out there planning on a light weight one piece CF drive shaft for the 135?
02-17-2009, 11:48 AM | #20 |
Rep 1,859
^ probably- I saw on e90 or maybe here- Wed Sport I think, in Japan has developed CF WHEELS!!! 6lbs each!!!
