12-08-2008, 12:55 PM | #1 |
Rep 893
Winter Setup / Spacer Help
Hi guys I need to buy wheels and tires for the winter and I have decided on the Breyton GTS-R, Black and the Michelin Pilot PA3 Frt 225/40/18 RR 255/40/18 I am thinking I will need a 5 - 8mm spacer for the front. Where could I buy the spacers? I have never shopped for anything like this in the past and I do not know much about them. Thank you for the help guys
2008 BMW 135i, DINAN / Riss Racing / BMS
12-08-2008, 01:37 PM | #2 |
Rep 4,745
You won't need a spacer on the front to run that size. That will easily clear on the front.
The rear size is just a little tall. Gill
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
12-08-2008, 02:03 PM | #3 |
Rep 893
I want to use the bigger rims in front Gill I won't need a spacer for that? I looked all over tire rack for a winter tire setup that is good in the dry that will fit these rims. I want the bigger front rims because I will be putting bigger rubber on them in the summer, so what winter tires would you recommend I buy I need to order these today so that I can have them before the snow hits this week. Thanks
12-08-2008, 02:23 PM | #4 |
Rep 4,745
Sorry, I thought you were talking about the 7.5" up front. The 8.5" would likely require a spacer with that high offset.
H&R sells them directly. You can reach them at 888-827-8881. Others here might be able to tell you exactly what mm you might need, but I'm not exactly sure, not having tried it myself. Gill
